1534|0
1140
msp430单片机利用FDC2214测量电容 [复制链接]
#include<io430.h>
#include "oled.h"
#include "bmp.h"
#include "Config.h"
#include "fdc2214.h"
#include "iic.h"
void OLED_JM0(void);
int main( void )
   WDTCTL = WDTPW + WDTHOLD;
    u8 retVal=0;
    unsigned int id;
    unsigned long Buffer[4]={0};
     IIC_Init();
                OLED_Init();                //初始化OLED
                OLED_Clear();
        OLED_ShowString(0,0,"  FDC2214_Demo  ");
       do
                        retVal = 0;
                        retVal = FDC2214_init();  //初始化FDC2214
                        if(retVal==1)OLED_ShowString(2,2," Init Success ");
                        if(retVal==0)OLED_ShowString(2,2," Init defeated ");
                      id=MPU_Read_2Byte(0x2A,LDC13xx16xx_CMD_DEVID);//读设备ID
                      OLED_ShowString(0,4,"FDC_ID:0X");
                      OLED_ShowNum(72,4,id,4,16);//显示ASCII字符的码值
                 }while (retVal!=1);
           delay_ms(1000);
           OLED_Clear();delay_ms(100);
           OLED_ShowString(0,0,"CH0:         pf");
           OLED_ShowString(0,2,"CH1:         pf");
           OLED_ShowString(0,4,"CH2:         pf");
           OLED_ShowString(0,6,"CH3:         pf");
        while(1)
            evm_processDRDY(Buffer);//读取电容值电容的值
            OLED_ShowNum(32,0,Buffer[0],9,16);//显示电容的值
            OLED_ShowNum(32,2,Buffer[1],9,16);//显示电容的值
            OLED_ShowNum(32,4,Buffer[2],9,16);//显示电容的值
            OLED_ShowNum(32,6,Buffer[3],9,16);//显示电容的值
               LED_Clr();
               delay_ms(10);
               LED_Set();
               delay_ms(10);
void OLED_JM0(void)
  OLED_DrawBMP(0,0,128,8,BMP1);  //图片显示(图片显示慎用,生成的字表较大,会占用较多空间,FLASH空间8K以下慎用)
