2815|9
新书推荐《MicroPython Projects》 [复制链接]
这是网友kaiyuan_wang推荐的一本MicroPython新书,书的内容非常不错,涉及到诸多最新的Micropython技术和应用,推荐大家看看。
Explore MicroPython through a series of hands-on projects and learn to design and build your own embedded systems using the MicroPython Pyboard, ESP32, the STM32 IoT Discovery kit, and the OpenMV camera module.
通过一系列实践项目探索MicroPython,并学习使用MicroPython Pyboard、ESP32、STM32 IoT Discovery 套件和OpenMV模块构建自己的嵌入式系统。
好东西啊  详情 回复 发表于 2024-12-2 13:16
Book Description
Explore MicroPython through a series of hands-on projects and learn to  and build your own embedded systems using the MicroPython Pyboard and STM32 IoT Discovery kit
Key Features
  • Learn how to customize and deploy the MicroPython kernel
  • Design and implement drivers to interact with a variety of sensors and devices
  • Build low-cost projects such as DIY automation and IoT-enabled weather stations
Book Description
With the increasing complexity of embedded systems seen over the past few years, developers are looking for ways to manage them easily by solving problems without spending a lot of time on finding supported peripherals. MicroPython is an efficient and lean implementation of the  3 programming language, which is optimized to run on microcontrollers. MicroPython Projects will guide you in building and managing your embedded systems with ease.
This book is a comprehensive project-based guide that will help you build a wide range of projects and give you the confidence to design complex projects spanning new areas of technology such as  applications, automation devices, and IoT applications. While building eight engaging projects, you'll learn how to enable devices to  with each other, access information over the internet, and store and retrieve data. The complexity will increase progressively as you work on different projects, covering areas such as time management,  design, and sensor interfacing.
By the end of this MicroPython book, you'll be able to develop industry-standard embedded systems and keep up with the evolution of the Internet of Things.
What you will learn
  • Develop embedded systems using MicroPython
  • Build a custom debugging tool to visualize sensor data in real time
  • Process and parse GPS and National Marine  Association (NMEA) messages in MicroPython
  • Detect objects using machine learning and MicroPython
  • Discover how to minimize project costs and reduce development time
  • Get to grips with gesture operations and parsing gesture data
Who This Book Is For
This book is for embedded systems developers or anyone who is interested in building embedded systems using MicroPython. Basic understanding of electronics and Python along with some MicroPython experience will be helpful.
  • Title: MicroPython Projects
  • Author: Jacob Beningo
  • Length: 236 pages
  • Edition: 1
  • Language: English
  • Publisher: Packt Publishing
  • Publication Date: 2020-05-11
  • ISBN-10: 1789958032
  • ISBN-13: 9781789958034
198
英语的好啊,国内能买到吗
国内还没有引进。  详情 回复 发表于 2020-5-6 13:11
reayfei 发表于 2020-5-6 10:46 英语的好啊,国内能买到吗
国内还没有引进。
好东西,估计买不到呢
先看英文版  详情 回复 发表于 2020-5-18 15:56
fhygogo 发表于 2020-5-18 15:42 好东西,估计买不到呢
先看英文版
不错
收藏
好东西啊
