2053|1
CircuitPython 5.3.0-rc.0 发布 [复制链接]
自 5.2.0 主要更新:
  • Add support for RGB Matrix displays (#2706, #2775), thanks @jepler @PaintYourDragon
  • Add a fill method to displayio.Bitmap (#2756), thanks @caternuson
  • Make the colors used by the stage library compatible with those used in the displayio library (#2777), thanks @deshipu
  • Multiple improvements to the STM32 port (#2735, #2788), thanks @k0d, @hierophect
  • Improvements to the litex port (#2768), thanks @xobs
  • Improvements to ulab (#2767), thanks @v923z, @jepler
  • Use “checkout@v2” in the circuitpython build process (#2765), thanks @jepler
  • Fix the maximum keycode in keyboard HID descriptor (#2764), thanks @dhalbert
  • Fix bad submodule patk (#2763), thanks @larsks
  • Add the NFC Copy Cat board (#2758), thanks @sabas1080
  • Use Sphinx 3 to build the documentation (#2757), thanks @sommersoft
谢谢分享!   详情 回复 发表于 2020-4-23 10:32
6177
谢谢分享!
【直播时间】5月28日(周三)上午10:00
