2814|1
CCS内存分配问题 [复制链接]
    在下用的是DSP:DM642,编程用C,平台CCS3.1,计算机仿真。程序在TC上能跑,但是到CCS上提示:Trouble running Target CPU:   Memory Map Error: WRITE access by Default to address 0xffffe1c8, which is RESERVED in Hardware.
是不是lnk.cmd的问题,还是DM642sim.gel文件的问题?跪求各位大侠了,在下当以分报之:
附上lnk.cmd文件和DM642sim.gel文件:
-stack 0x500
-heap 0x500
MEMORY
  L2 : o = 00000000h l = 40000h /* all SRAM                     */
  CE0: o = 80000000h l = 2000000h /* external memory   */
SECTIONS
    .cinit      >       L2
    .text       >       L2
    .stack      >       L2
    .bss        >       L2
    .const      >       L2
    .data       >       L2
    .far        >       L2
    .switch     >       L2
    .sysmem     >       L2
    .tables     >       L2
    .cio        >       L2
    /*.external   >       CE0*/
        .syncframebuf        >                CE0
        .sendbytesbuf        >                CE0
        .sendsymsbuf        >                CE0
        .outsendsymsbuf        >                CE0
        .recvbuf                >                CE0
        .highpointbuf        >                CE0
DM642.gel:
emif_init()
    #define EMIFA_GCTL       0x01800000
    #define EMIFA_CE1        0x01800004
    #define EMIFA_CE0        0x01800008
    #define EMIFA_CE2        0x01800010
    #define EMIFA_CE3        0x01800014
    #define EMIFA_SDRAMCTL   0x01800018
    #define EMIFA_SDRAMTIM   0x0180001c
    #define EMIFA_SDRAMEXT   0x01800020
    #define EMIFA_CE1SECCTL  0x01800044
    #define EMIFA_CE0SECCTL  0x01800048
    #define EMIFA_CE2SECCTL  0x01800050
    #define EMIFA_CE3SECCTL  0x01800054
    #define EMIFB_GCTL       0x01A80000
    #define EMIFB_CE1        0x01A80004
    #define EMIFB_CE0        0x01A80008
    #define EMIFB_CE2        0x01A80010
    #define EMIFB_CE3        0x01A80014
    #define EMIFB_SDRAMCTL   0x01A80018
    #define EMIFB_SDRAMTIM   0x01A8001c
    #define EMIFB_SDRAMEXT   0x01A80020
    #define EMIFB_CE1SECCTL  0x01A80044
    #define EMIFB_CE0SECCTL  0x01A80048
    #define EMIFB_CE2SECCTL  0x01A80050
    #define EMIFB_CE3SECCTL  0x01A80054
    /* EMIFA */
    *(int *)EMIFA_GCTL     = 0x00012070;
    *(int *)EMIFA_CE0      = 0xffffffd3;  /* CE0 SDRAM                     */
    *(int *)EMIFA_CE2      = 0x22a28a22;  /* CE2 Daughtercard 32-bit async */
    *(int *)EMIFA_CE3      = 0x22a28a22;  /* CE3 Daughtercard 32-bit async */
    *(int *)EMIFA_SDRAMCTL = 0x47115000;  /* SDRAM control                 */
    *(int *)EMIFA_SDRAMTIM = 0x00000618;  /* SDRAM timing (refresh)        */
    *(int *)EMIFA_SDRAMEXT = 0x000a8529;  /* SDRAM extended control        */
    /* EMIFB */
    *(int *)EMIFB_GCTL     = 0x00002070;
    *(int *)EMIFB_CE0      = 0x22008800;  /* CE0 CPLD 8-bit                */
    *(int *)EMIFB_CE1      = 0x22008800;  /* CE1 Flash 8-bit               */
这个可以  详情 回复 发表于 2010-5-2 15:12
这个可以
