5305|4
wdk编译出错LNK2019:unresolved external symbol _DriverEntry@8 referenced in function [复制链接]
inline hook ObReferenceObjectByHandle保护进程,看雪上的例子,c语言写的,编译错误LNK2019:unresolved external symbol _DriverEntry@8 referenced in function _GsDriverEntry@8。
#include
#include
BYTE  OriginalBytes[5]={0};
BYTE JmpAddress[5]={0xE9,0,0,0,0};
ULONG  CR0VALUE;
extern POBJECT_TYPE *PsProcessType;
NTSTATUS ObReferenceObjectByHandle(
  __in       HANDLE Handle,
  __in       ACCESS_MASK DesiredAccess,
  __in_opt   POBJECT_TYPE ObjectType,
  __in       KPROCESSOR_MODE AccessMode,
  __out      PVOID *Object,
  __out_opt  POBJECT_HANDLE_INFORMATION HandleInformation
NTSTATUS MidObReferenceObjectByHandle(
  __in       HANDLE Handle,
InlineHook()
        KIRQL Irql;
        DbgPrint("Original ObReferenceObjectByHandle Address is 0x%x",ObReferenceObjectByHandle);
        //保存原函数前5字节
        RtlCopyMemory(
  __in  OriginalBytes,
  __in  ObReferenceObjectByHandle,
  __in  5);
*(BYTE*)JmpAddress=(ULONG)MidObReferenceObjectByHandle-(ULONG)ObReferenceObjectByHandle+5;
//关闭内存写保护
_asm
    push eax
      mov eax, cr0
      mov CR0VALUE, eax
      and eax, 0fffeffffh
      mov cr0, eax
      pop eax
  Irql=KeRaiseIrqlToDpcLevel();
RtlCopyMemory(
  __in  (BYTE*)ObReferenceObjectByHandle,
  __in  JmpAddress,
  __in  5
   KeLowerIrql(Irql);
//开启内存写保护
   __asm
    push eax
      mov eax, CR0VALUE
      mov cr0, eax
      pop eax
_declspec (naked) NTSTATUS OriginalObReferenceObjectByHandle(
  __in       HANDLE Handle,
        _asm{
                mov edi,edi
                push ebp
                mov ebp,esp
                mov eax,ObReferenceObjectByHandle
                add eax,5
                jmp eax
  __in       HANDLE Handle,
        NTSTATUS status;
        status=OriginalObReferenceObjectByHandle(Handle,DesiredAccess,ObjectType,AccessMode,Object,HandleInformation);
        if(status==STATUS_SUCCESS&&DesiredAccess==0x0001)
                if(ObjectType==*PsProcessType)
                if(_stricmp((char*)((ULONG)(*Object)+0x174),"notepad.exe")==0)
                          ObDereferenceObject(*Object);
       return STATUS_INVALID_HANDLE;
                return status;
InlineUnHook()
        KIRQL Irql;
  _asm
    push eax
      mov eax, cr0
      mov CR0VALUE, eax
      and eax, 0fffeffffh
      mov cr0, eax
      pop eax
        RtlCopyMemory((BYTE*)ObReferenceObjectByHandle,OriginalBytes,5);
        KeLowerIrql(Irql);
    //开启写保护
  __asm
        push eax
      mov eax, CR0VALUE
      mov cr0, eax
      pop eax
Unload(PDRIVER_OBJECT dricer)
        InlineUnHook();
        DbgPrint("Driver is Unloaded...\r\n");
NTSTATUS DriverEmpty(PDRIVER_OBJECT driver,PUNICODE_STRING reg_string)
        InlineHook();
        driver->DriverUnload=Unload;
搞定了_stricmp写错了  详情 回复 发表于 2010-5-30 11:23
驱动程序要有一个入口函数,程序被加载时自动调用该函数,在该函数中执行程序的初始化,函数名称为DriverEntry,原形为:
NTSTATUS
  DriverEntry(
    IN PDRIVER_OBJECT  DriverObject,
    IN PUNICODE_STRING  RegistryPath
谢谢,还有问题DriverEntry没返回;Unload(PDRIVER_OBJECT dricer)
应该是driver。编译通过了。可是加载后无法保护notepad.exe(XP SP2下)。能帮我看看吗?实在不好意思,又提了个问题
wdk,没搞过,呵呵,,,路过,顺便顶顶!
搞定了_stricmp写错了
