2311|3
multibin的magic number [复制链接]
最近在做multibin....但是我很困惑他的网络端口上读到的magic number是什么。。。是bin的B000FF.还是nb0的N000FF.multibin他的每个文件时跟NK.bin的格式一摸一样吗?
[code]     // The N000FF packet indicates a manifest, which is constructed by Platform     // Builder when we're downloading multiple .bin files or an .nb0 file.     //     if (!memcmp (g_hdr, "N000FF\x0A", BL_HDRSIG_SIZE))     {         KITLOutputDebugString("\r\nBL_IMAGE_TYPE_MANIFEST\r\n\r\n");         rval =  BL_IMAGE_TYPE_MANIFEST;     }     else if (!memcmp (g_hdr, "X000FF\x0A", BL_HDRSIG_SIZE))     {         KITLOutputDebugString("\r\nBL_IMAGE_TYPE_MULTIXIP\r\n\r\n");         rval =  BL_IMAGE_TYPE_MULTIXIP;     }     else if (!memcmp (g_hdr, "B000FF\x0A", BL_HDRSIG_SIZE))     {         KITLOutputDebugString("\r\nBL_IMAGE_TYPE_BIN\r\n\r\n");         rval =  BL_IMAGE_TYPE_BIN;     }     else if (!memcmp (g_hdr, "S000FF\x0A", BL_HDRSIG_SIZE))     {         KITLOutputDebugString("\r\nBL_IMAGE_TYPE_SIGNED_BIN\r\n\r\n");         rval =  BL_IMAGE_TYPE_SIGNED_BIN;     }     else if (!memcmp (g_hdr, "R000FF\x0A", BL_HDRSIG_SIZE))     {         KITLOutputDebugString("\r\nBL_IMAGE_TYPE_SIGNED_NB0\r\n\r\n");         rval =  BL_IMAGE_TYPE_SIGNED_NB0;     }     else     {         KITLOutputDebugString("\r\nBL_IMAGE_TYPE_UNKNOWN\r\n\r\n");         rval =  BL_IMAGE_TYPE_UNKNOWN;     } 代码~  详情 回复 发表于 2009-11-16 15:21
如果通过pb进行download,或者按照samsung的架构走的话,就应该是N000FF
引用 1 楼 guopeixin 的回复:
楼主可以追一下CODE,就知道读的是B000FF还是N000FF了
BLCOMMON.C代码中有这个代码的流程
引用 2 楼 stoneqiang 的回复:
[code]
    else
代码~
