以下信息是从NAND FLASH启动时,过一段时间串口没有输入则直接拷贝FLASH中WINCE系统数据到SDRAM中并运行
USB: IN_ENDPOINT:1 OUT_ENDPOINT:3
FORMAT: +++
NOTE: 1. Power off/on or press the reset button for 1 sec
in order to get a valid USB device address.
2. For additional menu, Press any key.
USB host is not connected yet.
Read chip id = ec76
Nand flash status = c0
Undefined instruction exception!!!
还有一个调试信息如下:
###### Select Menu ######
[0] Download & Run
[1] Download Only
[2] Download From UART
[3] Write File to SST39VF160
[4] Write File to NAND Flash
[5] Boot OS
[6] Erase NAND Flash Partition
[7] Config parameters
[8] Relocate NK.bin
Found single BIN signature.
Image start is 0x80200000, length is 0x01150270
REC start 0x80200000, length 0x4
Dabort exception!!!
