4613|0
473
LTIB介绍和安装(一) [复制链接]
因为eewrold每个帖子指数限制是1万字,只能切开分几个帖子,顺便说下,这个字数限制实在是没理由。
LTIB (Linux Target Image Builder)是飞思卡尔公司开发的一个工具,用于简化嵌入式bsp开发的工具,基本上就是一些脚本加上预先制作成功交叉工具连,由于linux开源世界太多软件版本不断升级,相互兼容极差,不同的软件由不同的志愿者维护,互相根本没有考虑到兼容性,这导致在嵌入式linux上开发的工程师的噩梦。在这种情况下,少数高人干起整合这些乱七八糟开源软件的事情,目标当然是尽量提供一个方便使用的软件包,避免那些琐碎繁杂的配置安装工作。
LTIB是其中之一,当然我觉得它还做的不够好,什么时候能做成如microsoft windows下的那种简单图形化傻瓜化的安装包就好了。
ltib网站:http://savannah.nongnu.org/projects/ltib/
http://www.bitshrine.org/ltib/
Main features
  • Open source (GPL)
  • Runs on most popular Linux host distributions (x86 and some PPC)
  • Command line interface, with curses configuration screens (using LKC)
  • Support for multiple target architectures (PPC, ARM, Coldfire)
  • Target platforms selectable from a menu (CVS version)
  • More than 200 userspace packages selectable
  • Common root filesystem package set across architectures
  • Supports building of bootloaders and kernel images
  • All package building is done as non-root user
  • Configuration/selection of individual packages from a menu
  • Auto package dependency resolution
  • Auto file conflict resolution by package order build scaling
  • Auto re-install/de-install of packages by changes in dependency tree
  • Toolchain selectable at configuration time
  • Configuration of the Linux kernel using it's native config language
  • Kernel selection can easilty be changed from choicelist during configuration
  • Configuration of target system from host (IP address, services etc)
此帖出自NXP MCU论坛
