1378|0
2015
学习MSP430F5529 编程例程 [复制链接]
按下P2.1,LED1亮1s,快速按下P2.1两次,LED2亮1s
//按下P2.1,LED1亮1s,快速按下P2.1两次,LED2亮1s
#include "msp430f5525.h"
unsigned int n=0;
int main(void)
    WDTCTL = WDTPW | WDTHOLD;   // stop watchdog timer
    P1DIR |= BIT0;
    P4DIR |= BIT7;
    P2DIR &= ~BIT1;
    P2REN |= BIT1;
    P2OUT |= BIT1;
    P1OUT &= ~BIT0;
    P4OUT &= ~BIT7;
    P2IE |= BIT1;
    P2IES |= BIT1;
    P2IFG &= ~BIT1;
    _EINT();
    while(1)
        if(n==0)
            P1OUT &= ~BIT0;
            P4OUT &= ~BIT7;
        else if(n==1)
            P1OUT |= BIT0;
            P4OUT &= ~BIT7;
            __delay_cycles(1000000);
            n=0;
        else if(n==2)
            P1OUT &= ~BIT0;
            P4OUT |= BIT7;
            n=0;
    return 0;
#pragma vector = PORT2_VECTOR
__interrupt void Port2()
    unsigned int i=0;
    if(!(P2IN & BIT1))
        __delay_cycles(5000);      //消抖
        if(!(P2IN & BIT1))
            //__delay_cycles(5000);       //如果还是处于按下的状态,即视作未松手,第一次按下
            while(!(P2IN & BIT1)){}           //第一次松手
            n = 1;
            P2IFG &= ~BIT1;
            //__delay_cycles(50000);         //500ms后如果有按键按下,视作第二次按下
            while((P2IN & BIT1))            //500ms-1000ms内如果不按下,视为只按一次
                i++;
                __delay_cycles(1000);
                if(i>1000)
                    return;
             }                              //程序因按下按键在此处跳出
             if(!(P2IN & BIT1))
                 if(!(P2IN & BIT1))
                     while(!(P2IN & BIT1)){}           //第二次松手
                     n = 2;
                     P2IFG &= ~BIT1;
