LTC2208IUP#PBF 模数转换器 原装库存
供应商
Analog Devices
产品类别
模数转换器
说明
1-Channel Single ADC Pipelined 130Msps 16-bit Parallel/LVDS 64-Pin QFN EP Tube
产品技术规格
欧盟限制某些有害物质的使用 |
Compliant |
ECCN (US) |
3A001.a.5.a.5 |
Part Status |
Active |
Converter Type |
General Purpose |
Architecture |
Pipelined |
Resolution |
16bit |
Number of ADCs |
1 |
Number of Input Channels |
1 |
Sampling Rate |
130Msps |
Digital Interface Type |
LVDS|Parallel |
Input Type |
Voltage |
Input Signal Type |
Differential |
Voltage Reference |
Internal|External |
Voltage Supply Source |
Single |
Input Voltage |
1.5Vp-p/2.25Vp-p |
Minimum Single Supply Voltage (V) |
3.135 |
Typical Single Supply Voltage (V) |
3.3 |
Maximum Single Supply Voltage (V) |
3.465 |
Typical Power Dissipation (mW) |
1498 |
Maximum Power Dissipation (mW) |
1782 |
Integral Nonlinearity Error |
±4.5LSB |
Full Scale Error |
±1.5%FSR |
Signal to Noise Ratio |
77.7dBFS(Typ) |
Sample and Hold |
Yes |
Single-Ended Input |
No |
Digital Supply Support |
No |
Minimum Operating Temperature (°C) |
-40 |
Maximum Operating Temperature (°C) |
85 |
Packaging |
Tube |
Supplier Temperature Grade |
Industrial |
Standard Package Name |
QFN |
Pin Count |
64 |
Supplier Package |
QFN EP |
Mounting |
Surface Mount |
Package Height |
0.75(Max) |
Package Length |
9 |
Package Width |
9 |
PCB changed |
64 |
Lead Shape |
No Lead |
