1672|0
2015
c2000 I2C读取寄存器帧格式参考例程 [复制链接]
8位Byte的读方法可以参考以下代码:
  1. unsigned char I2C_Read_Byte(void)
  2. {
  3.     int t,rxData;
  4.     unsigned char receive;
  5.     SDA_Input();
  6.     for(t=0;t<8;t++)
  7.     {
  8.         SCL_Low();   // Clear the SCL
  9.         Delay(I2CDelay);
  10.          SCL_High();   // Set the SCL
  11.          receive<<=1;
  12.          rxData = SDA_Data_Register ;
  13.          if(rxData)
  14.          {
  15.              receive++;
  16.          }
  17.          Delay(I2CDelay);
  18.      }
  19.      return receive;
  20. }
          寄存器的读方法可以参考以下代码:
  1. unsigned char I2C_Read_Register(unsigned char Device_Write,unsigned char Device_Read, unsigned char Register)
  2. {
  3.     unsigned char ReadData;
  4.     I2C_Start();
  5.     I2C_Send_Byte(Device_Write); //Send the device address
  6.     I2C_Wait_Ack();             //Wait for the ack signal
  7.     I2C_Send_Byte(Register);    //Send the register address
  8.     I2C_Wait_Ack();             //Wait for the ack signal
  9.     I2C_Start();
  10.     I2C_Send_Byte(Device_Read); //Send register value
  11.     I2C_Wait_Ack();
  12.     SDA_High();                  // Set the SDA
  13.     ReadData = I2C_Read_Byte();
  14.     I2C_NAck();
  15.     Delay(1);
  16.     I2C_Finish();
  17.     return ReadData;
  18. }
