2671|7
3249
STM32F4串口4标准库程序的问题 [复制链接]
有一个板子,STM32F407VET6,串口4接在PC10和PC11上。
我用标准库写了个程序,通讯不上。
初始化代码如下:
//³õʼ»¯IO ´®¿Ú4
//bound:²¨ÌØÂÊ
void uart_init(u32 bound){
   //GPIO¶Ë¿ÚÉèÖÃ
  GPIO_InitTypeDef GPIO_InitStructure;
USART_InitTypeDef USART_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC,ENABLE); //ʹÄÜGPIOCʱÖÓ
RCC_APB2PeriphClockCmd(RCC_APB1Periph_UART4,ENABLE);//ʹÄÜUART4ʱÖÓ
//´®¿Ú1¶ÔÓ¦Òý½Å¸´ÓÃÓ³Éä
GPIO_PinAFConfig(GPIOC,GPIO_PinSource10,GPIO_AF_UART4); //GPIOC10¸´ÓÃΪUART4
GPIO_PinAFConfig(GPIOC,GPIO_PinSource11,GPIO_AF_UART4); //GPIOC11¸´ÓÃΪUART4
//USART1¶Ë¿ÚÅäÖÃ
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 | GPIO_Pin_10; //GPIOC11ÓëGPIOC10
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;//¸´Óù¦ÄÜ
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //ËÙ¶È50MHz
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //ÍÆÍ츴ÓÃÊä³ö
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; //ÉÏÀ-
GPIO_Init(GPIOC,&GPIO_InitStructure); //³õʼ»¯PC11£¬PC10
   //USART1 ³õʼ»¯ÉèÖÃ
USART_InitStructure.USART_BaudRate = bound;//²¨ÌØÂÊÉèÖÃ
USART_InitStructure.USART_WordLength = USART_WordLength_8b;//×Ö³¤Îª8λÊý¾Ý¸ñʽ
USART_InitStructure.USART_StopBits = USART_StopBits_1;//Ò»¸öֹͣλ
USART_InitStructure.USART_Parity = USART_Parity_No;//ÎÞÆæżУÑéλ
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//ÎÞÓ²¼þÊý¾ÝÁ÷¿ØÖÆ
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //ÊÕ·¢Ä£Ê½
  USART_Init(UART4, &USART_InitStructure); //³õʼ»¯´®¿Ú1
  USART_Cmd(UART4, ENABLE);  //ʹÄÜ´®¿Ú1
USART_ClearFlag(UART4, USART_FLAG_TC);
//#if EN_USART1_RX
// USART_ITConfig(UART4, USART_IT_RXNE, ENABLE);//¿ªÆôÏà¹ØÖжÏ
// //Usart1 NVIC ÅäÖÃ
//  NVIC_InitStructure.NVIC_IRQChannel = UART4_IRQn;//´®¿Ú1ÖжÏͨµÀ
// NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3;//ÇÀÕ¼ÓÅÏȼ¶3
// NVIC_InitStructure.NVIC_IRQChannelSubPriority =3; //×ÓÓÅÏȼ¶3
// NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQͨµÀʹÄÜ
// NVIC_Init(&NVIC_InitStructure); //¸ù¾ÝÖ¸¶¨µÄ²ÎÊý³õʼ»¯VIC¼Ä´æÆ÷¡¢
//#endif
开始我用中断,不行,后来又改成查询,都不行。
中断程序:
void UART4_IRQHandler(void)                 //´®¿Ú1ÖжϷþÎñ³ÌÐò
u8 Res;
#if SYSTEM_SUPPORT_OS  //Èç¹ûSYSTEM_SUPPORT_OSΪÕ棬ÔòÐèÒªÖ§³ÖOS.
OSIntEnter();
#endif
if(USART_GetITStatus(UART4, USART_IT_RXNE) != RESET)  //½ÓÊÕÖжÏ(½ÓÊÕµ½µÄÊý¾Ý±ØÐëÊÇ0x0d 0x0a½áβ)
Res =USART_ReceiveData(UART4);//(UART4->DR); //¶ÁÈ¡½ÓÊÕµ½µÄÊý¾Ý
if((USART_RX_STA&0x8000)==0)//½ÓÊÕδÍê³É
if(USART_RX_STA&0x4000)//½ÓÊÕµ½ÁË0x0d
if(Res!=0x0a)USART_RX_STA=0;//½ÓÊÕ´íÎó,ÖØпªÊ¼
else USART_RX_STA|=0x8000; //½ÓÊÕÍê³ÉÁË
else //»¹Ã»ÊÕµ½0X0D
if(Res==0x0d)USART_RX_STA|=0x4000;
else
USART_RX_BUF[USART_RX_STA&0X3FFF]=Res ;
USART_RX_STA++;
if(USART_RX_STA>(USART_REC_LEN-1))USART_RX_STA=0;//½ÓÊÕÊý¾Ý´íÎó,ÖØпªÊ¼½ÓÊÕ
OSIntExit();
#endif
查询代码:
while (USART_GetFlagStatus(UART4, USART_FLAG_RXNE) == RESET);
data=USART_ReceiveData(UART4);
请大神看看,如何修改代码?谢谢!
此帖出自stm32/stm8论坛
RCC_APB2PeriphClockCmd(RCC_APB1Periph_UART4,ENABLE);// 你这里肯定是有错误的   详情 回复 发表于 2019-12-18 17:46
个人签名为江山踏坏了乌骓马,为社稷拉断了宝雕弓。
3249
有人说要用GPIO_PinRemapConfig()这个函数,可是我不太清楚如何用。
百度搜到,GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);
还是不知道怎么用。说是PA0,PA1映射到PC10,PC11上。
此帖出自stm32/stm8论坛
你选的函数对,但是里面的参数却不对,你这个函数(GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE); )的意思是“改变指定管脚的映射 GPIO_Remap_SWJ_Disable SWJ 完全禁用(JTAG+SW-DP)”因为  详情 回复 发表于 2019-12-18 14:01
875
chenbingjy 发表于 2019-12-7 16:29 有人说要用GPIO_PinRemapConfig()这个函数,可是我不太清楚如何用。 百度搜到,GPIO_PinRemapConfig(GPIO_ ...
你选的函数对,但是里面的参数却不对,你这个函数(GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE); )的意思是“改变指定管脚的映射 GPIO_Remap_SWJ_Disable SWJ 完全禁用(JTAG+SW-DP)”因为“STM32F10x系列的MCU复位后,PA13/14/15 & PB3/4默认配置为JTAG功能。有时我们为了充分利用MCU I/O口的资源,会把这些
端口设置为普通I/O口”你应该用的函数是这个“GPIO_PinRemapConfig(GPIO_PartialRemap_USART4, ENABLE);”这个函数才是将PC10和PC11映射到串口4(注:因该加在 GPIO_Init(GPIOC,&GPIO_InitStructure); 后面)
此帖出自stm32/stm8论坛
3249
谢谢!你说的对
此帖出自stm32/stm8论坛
4008
  /* Peripheral clock enable */
  LL_APB1_GRP1_EnableClock(LL_APB1_GRP1_PERIPH_UART4);
  LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_GPIOC);
  /**UART4 GPIO Configuration
  PC10   ------> UART4_TX
  PC11   ------> UART4_RX
  GPIO_InitStruct.Pin = LL_GPIO_PIN_10|LL_GPIO_PIN_11;
  GPIO_InitStruct.Mode = LL_GPIO_MODE_ALTERNATE;
  GPIO_InitStruct.Speed = LL_GPIO_SPEED_FREQ_VERY_HIGH;
  GPIO_InitStruct.OutputType = LL_GPIO_OUTPUT_PUSHPULL;
  GPIO_InitStruct.Pull = LL_GPIO_PULL_UP;
  GPIO_InitStruct.Alternate = LL_GPIO_AF_8;
  LL_GPIO_Init(GPIOC, &GPIO_InitStruct);
  USART_InitStruct.BaudRate = 115200;
  USART_InitStruct.DataWidth = LL_USART_DATAWIDTH_8B;
  USART_InitStruct.StopBits = LL_USART_STOPBITS_1;
  USART_InitStruct.Parity = LL_USART_PARITY_NONE;
  USART_InitStruct.TransferDirection = LL_USART_DIRECTION_TX_RX;
  USART_InitStruct.HardwareFlowControl = LL_USART_HWCONTROL_NONE;
  USART_InitStruct.OverSampling = LL_USART_OVERSAMPLING_16;
  LL_USART_Init(UART4, &USART_InitStruct);
  LL_USART_ConfigAsyncMode(UART4);
  LL_USART_Enable(UART4);
帮你剪了一段
此帖出自stm32/stm8论坛
3249
谢谢!
此帖出自stm32/stm8论坛
4008
闂傚倸鍊搁崐鎼佸磹閹间礁纾归柟闂寸绾剧懓顪冪€n亝鎹i柣顓炴閵嗘帒顫濋敐鍛婵°倗濮烽崑鐐烘偋閻樻眹鈧線寮撮姀鐘栄囨煕閳╁啨浠︾紒顔瑰墲娣囧﹪鎮欓鍕ㄥ亾閺嶎厼绀夌憸蹇曞垝婵犳艾绠i柣妯烘▕濡粓姊虹粔鍡楀濞堟洟鏌i幘瀛樼闁哄瞼鍠栭弻鍥晝閳ь剟鎮橀柆宥嗙厱闁靛牆鎷嬮崕鏃堟煛鐏炶鈧繂顕i崼鏇炵閹肩补鈧弶妯婇梻鍌欑閹碱偊寮甸鍌滅煓闁硅揪绠戦悡鈥愁熆鐠哄彿鍫ュ几鎼淬劍鐓欓梺顓ㄧ畱閺嬨倝鏌嶇拠鑼婵﹨娅i幏鐘诲箵閹烘繂濡烽梻浣哄帶缂嶅﹦绮婚弽顒侇棨濠电偞娼欓崥瀣缚濞嗘劦鏀伴梻鍌欑閹测€趁洪敃鍌氬瀭闁规鍠氭稉宥夋煙閹澘袚闁绘挻娲熼弻宥夊煛娴e憡娈ф繛瀵稿缁犳垿鈥︾捄銊﹀枂闁告洦鍓涢ˇ顓犵磽娴d粙鍝洪柟鐟版搐閻g兘骞掗幋鏃€鐎婚梺鐟扮摠缁诲倿鈥栨径瀣╃箚闁绘劦浜滈埀顒佸灴瀹曟繄浠︽潪鎸庣☉閳规垹鈧綆浜濋悗顒勬⒑閸涘﹤濮﹂柛鐘崇墵閿濈偤宕ㄧ€涙ḿ鍘藉┑鈽嗗灥濞咃絾绂掑☉娆戠闁割偆鍠庨崝銈夋煃鐟欏嫬鐏︽鐐诧躬閺屾稒绻濋崘鈺冾槹濡ょ姷鍋涢敃銉╁箚閺冨牆顫呴柣妯诲絻椤﹪姊婚崒姘偓鎼佸磹妞嬪海鐭嗗〒姘e亾闁诡喖娼″畷鎯邦檨婵炲瓨鐗犻弻鏇熺箾瑜嶉幊鎰版倿閸忚偐绠鹃弶鍫濆⒔缁夘剚銇勯銏╂█鐎规洩缍€缁犳稑鈽夊▎鎴濆妇闂備礁澹婇崑鍛崲瀹ュ憘锝堛亹閹烘挾鍘介梺瑙勫礃濞夋盯寮稿☉銏$厸鐎光偓鐎n剙鍩屽銈庡亝缁捇宕洪埀顒併亜閹哄秷鍏屾い鈺傜叀閹娼幏宀婂妳闂佽楠搁悥濂稿蓟閿濆绠i柨婵嗘啗閹剧粯鐓熼柟鎯х摠缁€瀣煛瀹€瀣瘈鐎规洘甯掗埞鎴﹀炊閳瑰簱鍋撴繝鍕=濞达絽鎼暩缂備緡鍣崹鑸典繆閻㈢ǹ绀嬫い鏍ㄥ嚬濞煎﹪姊洪幐搴b槈閻庢凹鍙冨畷鎶藉级鐠囩偓妫冮幃鈺呮濞戞鎹曟俊鐐€栭崹鐢杆囬棃娑卞殨妞ゆ劧绠戠壕濂告煟閹邦厽缍戞繛鍫㈠枛濮婃椽妫冨☉杈€嗘繝纰樷偓铏┛闁靛洦鍔欐俊鎼佸煛閸屾瀚奸梺鑽ゅТ濞诧箓鎮¢敓鐙€鏁佹俊銈呮噺閻撴洘淇婇婵嗗惞闁活厽甯為埀顒冾潐濞叉﹢宕归崸妤冨祦婵☆垵鍋愮壕鍏间繆椤栨粌甯舵鐐茬墦濮婄粯鎷呴崫銉ㄩ梺绋款儏閿曨亜鐣烽姀锛勯檮缂佸娉曢ˇ顕€姊洪棃娑氬婵☆偅绋撶划缁樸偅閸愨晝鍘卞銈嗗姦閸嬪嫭鏅堕鐐村€垫慨妯煎亾鐎氾拷闂傚倸鍊搁崐鎼佸磹閹间礁纾归柟闂寸绾惧湱鈧懓瀚崳纾嬨亹閹烘垹鍊炲銈嗗笂缁€渚€宕滈鐑嗘富闁靛牆妫楁慨褏绱掗悩鍐茬伌闁绘侗鍣f慨鈧柕鍫濇閸樻捇鏌℃径灞戒沪濠㈢懓妫濆畷婵嗩吋閸℃劒绨婚梺鍝勫€搁悘婵嬵敂椤愩倗纾奸弶鍫涘妽瀹曞瞼鈧娲樼敮鎺楋綖濠靛鏁勯柦妯侯槷婢规洟姊洪崨濠勭細闁稿孩濞婇幆灞解枎閹惧鍘遍梺鍝勬储閸斿矂鎮橀悩鐢电<闁绘瑢鍋撻柛銊ョ埣瀵濡搁埡鍌氫簽闂佺ǹ鏈粙鎴︻敂閿燂拷闂傚倸鍊搁崐鎼佸磹閹间礁纾归柟闂寸绾惧綊鏌i幋锝呅撻柛銈呭閺屾盯顢曢敐鍡欘槬缂備胶濮锋繛鈧柡宀€鍠栧畷婊嗩槾閻㈩垱鐩弻娑氣偓锝冨妼閳ь剚绻堝濠氬即閻旇櫣顔曢梺缁樺姦閸撴岸鎮甸弴銏♀拺缂佸顑欓崕蹇斻亜閹存繍妯€鐎殿喖顭烽弫鎰緞婵犲嫮鏉告俊鐐€栫敮濠囨倿閿曞倸纾块柟鍓х帛閳锋垹绱撴担濮戭亞绮幒妤佺厽闊洦鏌ㄩ崫鍝勨攽閿涘嫭鏆€规洜鍠栭、娑橆潩妲屾牕鏁介梻鍌欐祰椤骞嗗畝鍕瀭闂侇剙绉撮弸浣肝旈敐鍛殲闁绘挾鍠栭獮鏍庨鈧悘顕€鏌涢悢鍝ュ弨闁哄瞼鍠栧畷娆撳Χ閸℃浼�婵犵數濮烽弫鍛婃叏閻戣棄鏋侀柛娑橈攻閸欏繘鏌i幋锝嗩棄闁哄绶氶弻鐔兼⒒鐎靛壊妲紒鎯у⒔缁垳鎹㈠☉銏犵闁哄啠鍋撻柛銈呯Ч閺屾盯濡烽鐓庘拻闂佽桨绀佸ú顓㈠蓟閺囷紕鐤€闁哄洨鍊妷锔轰簻闁挎棁顕у▍宥夋煙椤旂瓔娈滅€规洘顨嗗鍕節娴e壊妫滈梻鍌氬€风粈渚€骞夐垾瓒佹椽鏁冮崒姘憋紱婵犮垼鍩栭崝鏇㈠及閵夆晜鐓熼柟閭﹀枛閸斿鏌嶉柨瀣伌闁诡喖缍婇獮渚€骞掗幋婵愮€虫繝鐢靛仜閹冲繘宕濆▎鎾宠摕闁绘梻鍘х粈鍕煏閸繃顥滄い蹇ユ嫹
此帖出自stm32/stm8论坛
3249
此帖出自stm32/stm8论坛
快来报名!
