1409|0
3836
基于51单片机的简单方波发生器 [复制链接]
一个按键可以调整频率的简易方波信号发生器,当频率超出范围时LED亮,频率范围是100-1000hz。
#include <reg52.h>
sbit PWMOUT = P1^0;
sbit LED1 = P2^3;
sbit LED2 =    P2^2;
sbit LED3 =    P2^1;
sbit LED4 =    P2^0;
sbit KEY1 = P3^2;
sbit KEY2 = P3^3;
unsigned char HighRH = 0;  //高电平重载值的高字节
unsigned char HighRL = 0;  //高电平重载值的低字节
unsigned char LowRH  = 0;  //低电平重载值的高字节
unsigned char LowRL  = 0;  //低电平重载值的低字节
void ConfigPWM(unsigned int fr, unsigned char dc);
void ClosePWM();
void delay();
void main()
    unsigned int i;
    bit backup1 = 1;
    bit backup2 = 1;
    bit keybuf1 = 1;  //按键值暂存,临时保存按键的扫描值
    bit keybuf2 = 1;  //按键值暂存,临时保存按键的扫描值
    unsigned int a=100;
    EA=1;
    while (1)
        keybuf1 = KEY1;            //把当前扫描值暂存
        if (keybuf1 != backup1)     //当前值与前次值不相等说明此时按键有动作
            delay();              //延时大约10ms
            if (keybuf1 == KEY1)   //判断扫描值有没有发生改变,即按键抖动
               if (backup1 == 0)  //如果前次值为0,则说明当前是弹起动作
                    a = a-10;
                backup1 = keybuf1;  //更新备份为当前值,以备进行下次比较
        keybuf2 = KEY2;            //把当前扫描值暂存
        if (keybuf2 != backup2)     //当前值与前次值不相等说明此时按键有动作
            delay();              //延时大约10ms
            if (keybuf2 == KEY2)   //判断扫描值有没有发生改变,即按键抖动
                if (backup2 == 0)  //如果前次值为0,则说明当前是弹起动作
                    a = a+10;
                backup2 = keybuf2;  //更新备份为当前值,以备进行下次比较
             ConfigPWM(a, 50);
             for (i=0; i<40000; i++);
             ClosePWM();
              if ((a <= 50)||(a >= 150))
                    LED1 = 0;
                    LED2 = 0;
                    LED3 = 0;
                    LED4 = 0;
              else
                      LED1 = 1;
                    LED2 = 1;
                    LED3 = 1;
                    LED4 = 1;
/* 配置并启动PWM,fr-频率,dc-占空比 */
    unsigned int  high, low;
    unsigned long tmp;
    tmp  = ((11059200/12) / fr) ;  //计算一个周期所需的计数值
    high = (tmp*dc) / 100;      //计算高电平所需的计数值
    low  = tmp - high;          //计算低电平所需的计数值
    high = 65536 - high + 12;   //计算高电平的重载值并补偿中断延时
    low  = 65536 - low  + 12;   //计算低电平的重载值并补偿中断延时
    HighRH = (unsigned char)(high>>8); //高电平重载值拆分为高低字节
    HighRL = (unsigned char)high;
    LowRH  = (unsigned char)(low>>8);  //低电平重载值拆分为高低字节
    LowRL  = (unsigned char)low;
    TMOD &= 0xF0;   //清零T0的控制位
    TMOD |= 0x01;   //配置T0为模式1
    TH0 = HighRH;   //加载T0重载值
    TL0 = HighRL;
    ET0 = 1;        //使能T0中断
    TR0 = 1;        //启动T0
    PWMOUT = 1;     //输出高电平
/* 关闭PWM */
void ClosePWM()
    TR0 = 0;     //停止定时器
    ET0 = 0;     //禁止中断
    PWMOUT = 1;  //输出高电平
/* T0中断服务函数,产生PWM输出 */
void InterruptTimer0() interrupt 1
    if (PWMOUT == 1)  //当前输出为高电平时,装载低电平值并输出低电平
        TH0 = LowRH;
        TL0 = LowRL;
        PWMOUT = 0;
    else              //当前输出为低电平时,装载高电平值并输出高电平
        TH0 = HighRH;
        TL0 = HighRL;
        PWMOUT = 1;
/* 软件延时函数,延时约10ms */
void delay()
    unsigned int j = 1000;
    while (j--);
