1227|0
3836
MSP430F5529 生成PWM波 with CCS [复制链接]
大概就是通过时钟来产生某个确定频率的PWM波
用FPGA可以得到更完美的波形,不过如果只是提供一个CLK波的话F5529LP就完全可以做到
#include <msp430.h>
unsigned int temp;
int main(void) {
    WDTCTL = WDTPW | WDTHOLD;                      //关闭看门狗
    //Initialize
    P1DIR |= BIT0;
    P1OUT |= BIT0;
    P1SEL |= BIT2;                                             //从P1.2输出
    P1DIR |= BIT2;
    //初始化定时器
    TA0CTL |= TASSEL_2 + ID_0 ;
    TA0CCTL1 = OUTMOD_7;
    TA0CCR0 = /*Period*/; //Change me
    TA0CCR1 = /*Duty*/;   //Change me
    __delay_cycles(2000);
    __bis_SR_register(LPM4_bits + GIE);
    return 0;
