5)生成文件 The design files are located at F:/Spartan605/ddr3:
- mig_33.veo: veo template file containing code that can be used as a model for instantiating a CORE Generator module in a HDL design.
- mig_33.xco: CORE Generator input file containing the parameters used to regenerate a core.
- mig_33_flist.txt: Text file listing all of the output files produced when a customized core was generated in the CORE Generator.
- mig_33_readme.txt: Text file indicating the files generated and how they are used.
- mig_33_xmdf.tcl: ISE Project Navigator interface file. ISE uses this file to determine how the files output by CORE Generator for the core can be integrated into your ISE project.
- mig_33 directory.
In the mig_33 directory, three folders are created: - docs: This folder contains user guide.
- example_design: This folder includes the design with synthesizable test bench.
- user_design: This folder includes the design without test bench modules.
The example_design and user_design folders contain several other folders and files. All these output folders are discussed in more detail in Spartan-6 FPGA Memory Controller user guide (ug388.pdf) located in docs folder.
