2026|1
3836
完成CCS v5中烧写Flash记录 [复制链接]
环境:Win7 + CCS v5 + XDS100v2仿真器 + TMS320CF2812芯片
烧写方法:将SRAM.cmd替换成FLASH.cmd。一个通用的用于F2812的 FLASH.cmd  例子为
MEMORY
PAGE 0 :
   OTP         : origin = 0x3D7800, length = 0x000800
   FLASHJ      : origin = 0x3D8000, length = 0x002000
   FLASHI      : origin = 0x3DA000, length = 0x002000
   FLASHH      : origin = 0x3DC000, length = 0x004000
   FLASHG      : origin = 0x3E0000, length = 0x004000
   FLASHF      : origin = 0x3E4000, length = 0x004000
   FLASHE      : origin = 0x3E8000, length = 0x004000
   FLASHD      : origin = 0x3EC000, length = 0x004000
   FLASHC      : origin = 0x3F0000, length = 0x004000
   FLASHB      : origin = 0x3F4000, length = 0x002000
   FLASHA      : origin = 0x3F6000, length = 0x001FF6
   BEGIN       : origin = 0x3F7FF6, length = 0x000002
   PASSWDS     : origin = 0x3F7FF8, length = 0x000008
   ROM         : origin = 0x3FF000, length = 0x000FC0
   VECTORS     : origin = 0x3FFFC2, length = 0x00003E
PAGE 1 :
   /* SARAM                     */
   RAMM0M1    : origin = 0x000000, length = 0x000800
   /* Peripheral Frame 0:   */
   DEV_EMU    : origin = 0x000880, length = 0x000180
   FLASH_REGS : origin = 0x000A80, length = 0x000060
   CSM        : origin = 0x000AE0, length = 0x000010
   XINTF      : origin = 0x000B20, length = 0x000020
   CPU_TIMER0 : origin = 0x000C00, length = 0x000008
   CPU_TIMER1 : origin = 0x000C08, length = 0x000008
   CPU_TIMER2 : origin = 0x000C10, length = 0x000008
   PIE_CTRL   : origin = 0x000CE0, length = 0x000020
   PIE_VECT   : origin = 0x000D00, length = 0x000100
   /* Peripheral Frame 1:   */
   ECAN_A     : origin = 0x006000, length = 0x000100
   ECAN_AMBOX : origin = 0x006100, length = 0x000100
   /* Peripheral Frame 2:   */
   SYSTEM     : origin = 0x007010, length = 0x000020
   SPI_A      : origin = 0x007040, length = 0x000010
   SCI_A      : origin = 0x007050, length = 0x000010
   XINTRUPT   : origin = 0x007070, length = 0x000010
   GPIOMUX    : origin = 0x0070C0, length = 0x000020
   GPIODAT    : origin = 0x0070E0, length = 0x000020
   ADC        : origin = 0x007100, length = 0x000020
   EV_A       : origin = 0x007400, length = 0x000040
   EV_B       : origin = 0x007500, length = 0x000040
   SPI_B      : origin = 0x007740, length = 0x000010
   SCI_B      : origin = 0x007750, length = 0x000010
   MCBSP_A    : origin = 0x007800, length = 0x000040
   /* CSM Password Locations */
   CSM_PWL    : origin = 0x3F7FF8, length = 0x000008
   /* SARAM                    */
   RAML0L1    : origin = 0x008000, length = 0x002000
   RAMH0      : origin = 0x3F8000, length = 0x002000
SECTIONS
   /* Allocate program areas: */
   .reset              : > BEGIN       PAGE = 0
   vectors             : > VECTORS     PAGE = 0
   .cinit              : > FLASHJ      PAGE = 0
   .text               : > FLASHA       PAGE = 0
   /* Allocate data areas: */
   .stack              : > RAMM0M1     PAGE = 1
   .bss                : > RAML0L1     PAGE = 1
   .ebss               : > RAML0L1     PAGE = 1
   .const:            load =     FLASHB PAGE 0, run = RAML0L1 PAGE 1
        /* Get Run Address    */
        __const_run = .;
        /* Mark Load Address*/
        *(.c_mark)
        /* Allocate .const    */
        *(.const)
        /* Compute Length    */
        __const_length = .-__const_run;
   .econst:            load =     FLASHB PAGE 0, run = RAML0L1 PAGE 1
        __econst_run = .;
        *(.ec_mark)
        *(.econst)
        __econst_length = .-__econst_run;
   .sysmem             : > RAMH0       PAGE = 1
   /* Allocate IQ math areas: */
   IQmath              : > FLASHI      PAGE = 0   /* Math Code */
   IQmathFastTables    : > FLASHI      PAGE = 0   /* Math Tables in fast memory */
   IQmathTables        : > ROM         PAGE = 0   /* Math Tables In ROM */
   /* Allocate Peripheral Frame 0 Register Structures:   */
   DevEmuRegsFile      : > DEV_EMU     PAGE = 1
   FlashRegsFile       : > FLASH_REGS  PAGE = 1
   CsmRegsFile         : > CSM         PAGE = 1
   XintfRegsFile       : > XINTF       PAGE = 1
   CpuTimer0RegsFile   : > CPU_TIMER0  PAGE = 1
   CpuTimer1RegsFile   : > CPU_TIMER1  PAGE = 1
   CpuTimer2RegsFile   : > CPU_TIMER2  PAGE = 1
   PieCtrlRegsFile     : > PIE_CTRL    PAGE = 1
   PieVectTable        : > PIE_VECT    PAGE = 1
   /* Allocate Peripheral Frame 2 Register Structures:   */
   ECanaRegsFile       : > ECAN_A      PAGE = 1
   ECanaMboxesFile     : > ECAN_AMBOX  PAGE = 1
   /* Allocate Peripheral Frame 1 Register Structures:   */
   SysCtrlRegsFile     : > SYSTEM      PAGE = 1
   SpiaRegsFile        : > SPI_A       PAGE = 1
   SciaRegsFile        : > SCI_A       PAGE = 1
   XIntruptRegsFile    : > XINTRUPT    PAGE = 1
   GpioMuxRegsFile     : > GPIOMUX     PAGE = 1
   GpioDataRegsFile    : > GPIODAT     PAGE = 1
   AdcRegsFile         : > ADC         PAGE = 1
   EvaRegsFile         : > EV_A        PAGE = 1
   EvbRegsFile         : > EV_B        PAGE = 1
   ScibRegsFile        : > SCI_B       PAGE = 1
   McbspaRegsFile      : > MCBSP_A     PAGE = 1
   CsmPwlFile          : > CSM_PWL     PAGE = 1
重新编译OK!
点击Debug进入调试,点击Load Program...选择刚编译生成的*.out文件进行烧写!然后会出现Erase……
烧写成功!
=============== 悲剧 ================
为了调试方便,我设置了点击Debug按钮后自动装载程序,悲剧就在这时发生了!
在一次烧写时由于鼠标抖动,连续点了两次Debug,弹出两个烧写进度条,结果发大了,直接烧写失败,Flash锁死!如下
C28xx: Flash Programmer: Device is locked or not connected. Operation cancelled.
C28xx: Trouble Writing Memory Block at 0x3f7ff6 on Page 0 of Length 0x2
C28xx: GEL: File: E:\dsp\zx_dsp2000\zx_project_c2000\Debug\zx_project_c2000.out: Load failed.
为吸取经验教训,总结了Flash锁死的可能原因,以后注意这些方面:
(1)由于PC的原因,这里就是这样,中途打断了Flash的烧写过程造成Flash锁死。仿真器在烧写时挂起也会造成Flash锁死,比如有些仿真器速度比较慢,很容易发生挂起的现象。
(2)由于DSP的原因,DSP的电压、时钟等操作条件不对容易造成锁死。
另外,顺便注意DSP与JTAG的上电顺序:
关闭电源开关 ——> JTAG连接DSP ——> DSP连接PC,JTAG连接PC ——> 开启DSP电源开关,给DSP上电
原则:JTAG不能热插拔
不错的分享。   详情 回复 发表于 2019-8-12 09:13
2618
不错的分享。
