2290|1
52
APWM例程 [复制链接]
请问谁能共享一份28335中ECAP模块用作APWM功能时的例程?
本帖最后由 littleshrimp 于 2019-7-31 21:12 编辑   C:\ti\c2000\C2000Ware_1_00_06_00\device_support\f2833x\examples\ecap_apwm [attach]425373[/attach] // // Included Files // #include "DSP28x_Project.h" // Device Headerfile and Examples Include File // // Globals // Uint16 direction = 0; // // Main // void main(void) { // // Step 1. Initialize System Control: // PLL, WatchDog, enable Peripheral Clocks // This example function is found in the DSP2833x_SysCtrl.c file. // InitSysCtrl(); // // Step 2. Initialize GPIO: // This example function is found in the DSP2833x_Gpio.c file and // illustrates how to set the GPIO to it's default state. // // InitGpio(); // Skipped for this example // // Initialize the GPIO pins for eCAP. // This function is found in the DSP2833x_ECap.c file // InitECapGpio(); // // Step 3. Clear all interrupts and initialize PIE vector table: // Disable CPU interrupts // DINT; // // Initialize the PIE control registers to their default state. // The default state is all PIE interrupts disabled and flags // are cleared. // This function is found in the DSP2833x_PieCtrl.c file. // InitPieCtrl(); // // Disable CPU interrupts and clear all CPU interrupt flags // IER = 0x0000; IFR = 0x0000; // // Initialize the PIE vector table with pointers to the shell Interrupt // Service Routines (ISR). // This will populate the entire table, even if the interrupt // is not used in this example. This is useful for debug purposes. // The shell ISR routines are found in DSP2833x_DefaultIsr.c. // This function is found in DSP2833x_PieVect.c. // InitPieVectTable(); // // Interrupts that are used in this example are re-mapped to // ISR functions found within this file. // No interrupts used for this example. // // // Step 4. Initialize all the Device Peripherals: // This function is found in DSP2833x_InitPeripherals.c // // InitPeripherals(); // Not required for this example // // Step 5. User specific code // Setup APWM mode on CAP1, set period and compare registers // ECap1Regs.ECCTL2.bit.CAP_APWM = 1; // Enable APWM mode ECap1Regs.CAP1 = 0x01312D00; // Set Period value ECap1Regs.CAP2 = 0x00989680; // Set Compare value ECap1Regs.ECCLR.all = 0x0FF; // Clear pending interrupts ECap1Regs.ECEINT.bit.CTR_EQ_CMP = 1; // enable Compare Equal Int // // Setup APWM mode on CAP2, set period and compare registers // ECap2Regs.ECCTL2.bit.CAP_APWM = 1; // Enable APWM mode ECap2Regs.CAP1 = 0x01312D00; // Set Period value ECap2Regs.CAP2 = 0x00989680; // Set Compare value ECap2Regs.ECCLR.all = 0x0FF; // Clear pending interrupts ECap1Regs.ECEINT.bit.CTR_EQ_CMP = 1; // enable Compare Equal Int // // Setup APWM mode on CAP3, set period and compare registers // ECap3Regs.ECCTL2.bit.CAP_APWM = 1; // Enable APWM mode ECap3Regs.CAP1 = 0x05F5E100; // Set Period value ECap3Regs.CAP2 = 0x02FAF080; // Set Compare value ECap3Regs.ECCLR.all = 0x0FF; // Clear pending interrupts ECap1Regs.ECEINT.bit.CTR_EQ_CMP = 1; // enable Compare Equal Int // // Setup APWM mode on CAP4, set period and compare registers // ECap4Regs.ECCTL2.bit.CAP_APWM = 1; // Enable APWM mode ECap4Regs.CAP1 = 0x00001388; // Set Period value ECap4Regs.CAP2 = 0x000009C4; // Set Compare value ECap4Regs.ECCLR.all = 0x0FF; // Clear pending interrupts ECap1Regs.ECEINT.bit.CTR_EQ_CMP = 1; // enable Compare Equal Int // // Start counters // ECap1Regs.ECCTL2.bit.TSCTRSTOP = 1; ECap2Regs.ECCTL2.bit.TSCTRSTOP = 1; ECap3Regs.ECCTL2.bit.TSCTRSTOP = 1; ECap4Regs.ECCTL2.bit.TSCTRSTOP = 1; for(;;) { // // set next duty cycle to 50% // ECap1Regs.CAP4 = ECap1Regs.CAP1 >> 1; // // vary freq between 7.5 Hz and 15 Hz (for 150MHz SYSCLKOUT) // 5 Hz and 10 Hz (for 100 MHz SYSCLKOUT) // if(ECap1Regs.CAP1 >= 0x01312D00) { direction = 0; } else if (ECap1Regs.CAP1 <= 0x00989680) { direction = 1; } if(direction == 0) { ECap1Regs.CAP3 = ECap1Regs.CAP1 - 500000; } else { ECap1Regs.CAP3 = ECap1Regs.CAP1 + 500000; } } }     详情 回复 发表于 2019-7-31 21:10
9797
24
Example_2833xECap_apwm.c (7.74 KB, 下载次数: 2)
// Included Files
// Globals
// Main
void main(void)
    InitSysCtrl();
    InitECapGpio();
    DINT;
    // are cleared.
    InitPieCtrl();
    IER = 0x0000;
    IFR = 0x0000;
    InitPieVectTable();
    // Start counters
    for(;;)
            direction = 0;
            direction = 1;
        if(direction == 0)
        else
个人签名虾扯蛋,蛋扯虾,虾扯蛋扯虾
