3068|1
6892
分析外国代码-产生随机时钟的CODE! [复制链接]
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity decim_al2 is
Generic(
        num : integer range 0 to 1022 := 7; -- numerateur du rapport de decimation
        den : integer range 0 to 1023 := 25; -- denominateur du rapport de decimation
        Wdata : integer range 0 to 64 := 12;
        Wfeed : integer range 0 to 10 := 5 -- ceil(log2(den)), adresse du tableau (urne)
Port(
        clk : in std_logic;
        data_in : in std_logic_vector(Wdata-1 downto 0);
        data_out : out std_logic_vector(Wdata-1 downto 0);
        delta_t : out std_logic_vector(Wfeed-1 downto 0);
        clk_out : out std_logic;
        feed : in std_logic_vector(Wfeed-1 downto 0)
end decim_al2;
architecture Behavioral of decim_al2 is
SIGNAL var_clk_out : std_logic := '0';
SIGNAL var_data_out : std_logic_vector(Wdata-1 downto 0);
SIGNAL delta_t_inter : std_logic_vector(Wfeed-1 downto 0);
SIGNAL inter2,inter3 : integer range 0 TO den-1;
begin
-- tirage aleatoire sans remise
tr : PROCESS(clk) IS
        VARIABLE num_case : integer range 0 TO den-1;
        VARIABLE var_delta : integer range 0 TO 2*(num+1);
        VARIABLE n_tir : integer range 0 TO den-1;
        VARIABLE inter1 : integer range 0 TO den-1;
        VARIABLE urne_1 : std_logic := '0';
        VARIABLE urne_0 : std_logic := '0';
        VARIABLE var_feed : std_logic_vector(Wfeed-1 downto 0);
        VARIABLE tmp_feed : integer;
        VARIABLE Nfeed : integer range -1 TO Wfeed-1;
        VARIABLE urne : std_logic_vector(den-1 DOWNTO 0) := (others => '0');
        VARIABLE init : boolean;
        VARIABLE visu : std_logic;
BEGIN
        IF rising_edge(clk) THEN
                IF not init THEN
                        urne(den-1 DOWNTO den-num-1) := (others => '1');
                        urne(den-num-2 DOWNTO 0) := (others => '0');
                        init := true;
                ELSE
                        inter3 <= inter2;
                        --delta_t <= delta_t_inter; -- delta_t : intervalle entre 2 閏hantillons al閍toires
                        data_out <= var_data_out; -- Synchro de data_out sur clk_out
                        var_feed := feed;
                        urne_1 := urne_0;
                        IF n_tir = 0 THEN
                                n_tir := den-1;
                                --inter2 := n_tir;
                                inter1 := n_tir;
                                var_feed := (others => '0');
                        ELSE
                                n_tir := n_tir - 1;
--                                WHILE conv_integer((not(var_feed(Wfeed-1))&var_feed(Wfeed-2 DOWNTO 0))) > n_tir LOOP
--                                WHILE conv_integer(unsigned(var_feed)) > n_tir LOOP
                                FOR i in Wfeed-1 DOWNTO 0 LOOP
                                        IF var_feed(Nfeed) = '1' THEN
                                                var_feed(Nfeed) := not(var_feed(Nfeed));
                                        END IF;
--                                        Nfeed := Nfeed-1;
                                IF conv_integer(unsigned(var_feed)) > n_tir THEN
                                        exit;
                                END IF;
                                END LOOP;
                        END IF;
                        num_case := conv_integer(var_feed);
                        Nfeed := Wfeed-1;
                        urne_0 := urne(num_case);
                        IF urne_0 = '1' THEN
                                --data_out <= data_in; -- modif 08/12/06
                                var_data_out <= data_in;
                                var_clk_out <= '1';
                                inter2 <= inter1 - n_tir;
                                inter1 := n_tir;
                                --delta_t_inter <= CONV_STD_LOGIC_VECTOR(conv_unsigned(var_delta,Wfeed),Wfeed); -- Rajout 08/12/06
                                --var_delta := 0; -- Rajout 08/12/06
                        ELSE
                                var_clk_out <= '0';
                                --var_delta := var_delta + 1; -- Rajout 08/12/06
                        END IF;
                        -- Mis en commentaires 08/12/06
                        --IF urne(num_case) = not(urne_1) THEN
                        --        delta_t <= CONV_STD_LOGIC_VECTOR(conv_unsigned(var_delta,Wfeed),Wfeed);
                        --        var_delta := 0;
                        --ELSE
                        --        var_delta := var_delta + 1;
                        --END IF;
                        urne(num_case) := urne(n_tir);
                        urne(n_tir) := urne_0;
                END IF;
        END IF;
        clk_out <= clk AND var_clk_out;
END PROCESS tr;
delta_t <= CONV_STD_LOGIC_VECTOR(conv_unsigned(inter3,Wfeed),Wfeed); -- Rajout 12/12/06
end Behavioral;
研究别人的代码,增加我们的见识!
此帖出自FPGA/CPLD论坛
哈哈,很久没有看VHDL语言了,重新回味。是否可以介绍应用场合。  详情 回复 发表于 2010-6-18 12:23
个人签名一个为理想不懈前进的人,一个永不言败人!
欢迎光临网上店铺!
775
此帖出自FPGA/CPLD论坛
