901|0
290
禁止发言
MY-IMX6-A9 Linux-3.0.35 编译参考手册 v3.0(2) [复制链接]
【接上一章节MY-IMX6-A9 Linux-3.0.35 编译参考手册 v3.01)】
4  内核编译
4.1  编译前的准备
创建编译工作目录
=====> Input:
mkdir ~/my-work/02_source/ -p
解压源码包到工作目录
=====> Input:
tar xf linux-3.0.35-svn*.tar.bz2 -C ~/my-work/02_source/
4.2  编译内核目标文件
进入源码目录
=====> Input:
cd ~/my-work/02_source/linux-3.0.35
生成目标平台的 .config 文件
=====> Input:
make myimx6a9_defconfig
=====> Output:
  HOSTCC  scripts/basic/fixdep
  HOSTCC  scripts/kconfig/conf.o
  SHIPPED scripts/kconfig/zconf.tab.c
  SHIPPED scripts/kconfig/lex.zconf.c
  SHIPPED scripts/kconfig/zconf.hash.c
  HOSTCC  scripts/kconfig/zconf.tab.o
  HOSTLD  scripts/kconfig/conf
# configuration written to .config
Note: 如果有“Can't find default configuration "arch/x86/configs” 的错误,是因为交叉编译工具链的配置没有生效,可以按前面 “交叉编译工具链安装” 中的 “source 工具链配置文件” 操作一次后再执行此步骤
编译内核目标文件
=====> Input:
make zImage
=====> Output:
scripts/kconfig/conf --silentoldconfig Kconfig
  CHK     include/linux/version.h
  UPD     include/linux/version.h
  CHK     include/generated/utsrelease.h
  UPD     include/generated/utsrelease.h
  Generating include/generated/mach-types.h
  CC      kernel/bounds.s
  AS      arch/arm/boot/compressed/piggy.gzip.o
  LD      arch/arm/boot/compressed/vmlinux
  OBJCOPY arch/arm/boot/zImage
  Kernel: arch/arm/boot/zImage is ready
内核目标文件
arch/arm/boot/zImage 即内核目标文件
4.4  编译内核模块包
执行编译
=====> Input:
make modules
=====> Output:
make[1]: “include/generated/mach-types.h”是最新的。
  CALL    scripts/checksyscalls.sh
  CC [M]  fs/autofs4/init.o
  LD [M]  drivers/usb/gadget/g_serial.ko
  LD [M]  fs/nls/nls_ascii.ko
  LD [M]  fs/autofs4/autofs4.ko
  LD [M]  fs/nls/nls_utf8.ko
创建内核模块的保存目录
=====> Input:
mkdir modules
安装内核模块到指定目录
=====> Input:
make modules_install INSTALL_MOD_PATH=./modules
=====> Output:
  INSTALL crypto/tcrypt.ko
  INSTALL drivers/gpu/drm/drm.ko
  INSTALL drivers/gpu/drm/vivante/vivante.ko
  INSTALL fs/autofs4/autofs4.ko
  INSTALL fs/nls/nls_ascii.ko
  INSTALL fs/nls/nls_utf8.ko
  DEPMOD  3.0.35-myimx6a9-svn42
打包内核模块文件
=====> Input:
tar cjf kernel-modules.tar.bz2 -C modules lib
4.5  目标文件
zImage 和 kernel-modules.tar.bz2 即编译得到的目标文件,保存这两个文件
5  Linux C程序编译
5.1  准备源码
打开网盘到 5_MY-Demo -> MY-Linux-C-Demo,下载 hello.c 文件,并复制到虚拟机。
5.2  编译目标文件
=====> Input:
${CROSS_COMPILE}gcc hello.c -o hello.out
Note: 如果有“未找到命令”的信息,是因为交叉编译工具链的配置没有生效,可以按前面 “交叉编译工具链安装” 中的 “source 工具链配置文件” 操作一次后再执行此步骤
5.3  运行Linux C目标程序
把编译得到的 hello.out 复制到开发板上
在开发板上运行Linux C目标程序
=====> Input:
chmod +x ./hello.out
./hello.out
=====> Output:
MYZR Technology Co.,Ltd.
Tel: 0756-3628023/3628021
6  Linux QT5程序编译
6.1  准备源码
打开网盘到 5_MY-Demo,下载 MY-Linux-QT5-Demo-AboutUs-svn*.tar.bz2 文件,并复制到虚拟机。
解压源码包到工作目录
=====> Input:
tar xf MY-Linux-QT5-Demo-AboutUs-svn*.tar.bz2 -C ~/my-work/02_source/
6.2  QT程序编译
进入源码目录
=====> Input:
cd ~/my-work/02_source/AboutUs/
生成Makefile文件
=====> Input:
qmake
Note: 如果有“未找到 'qamke' 命令”的信息,是因为交叉编译工具链的配置没有生效,可以按前面 “交叉编译工具链安装” 中的 “source 工具链配置文件” 操作一次后再执行此步骤
编译目标文件
=====> Input:
make
=====> Output:
/home/myzr/my-work/03_toolchain/fsl-imx-fb-glibc-x86_64-meta-toolchain-qt5-cortexa9hf-vfp-neon-toolchain-3.14.52-1.1.1/sysroots/x86_64-pokysdk-linux/usr/bin/qt5/uic widget.ui -o ui_widget.h
arm-poky-linux-gnueabi-g++  -march=armv7-a -mfloat-abi=hard -mfpu=neon -mtune=cortex-a9 --sysroot=/home/myzr/my-work/03_toolchain/fsl-imx-fb-glibc-x86_64-meta-toolchain-qt5-cortexa9hf-vfp-neon-toolchain-3.14.52-1.1.1/sysroots/cortexa9hf-vfp-neon-poky-linux-gnueabi -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -Wl,-O1 -o AboutUs main.o widget.o qrc_source.o moc_widget.o   -lQt5Widgets -lQt5Gui -lQt5Core -lGLESv2 -lEGL -lpthread
6.3   MY-IMX6-A9 设备上运行
把编译得到的 AboutUs 复制到开发板上
在开发板上运行QT5目标程序
=====> Input:
chmod +x ./AboutUs
./AboutUs -platform eglfs
6.4  运行结果
可以看到开发板显示屏上输出了 MYZR 的 Logo 和一些信息。
个人签名明远智睿 您的一站式 嵌入式 方案提供商
