8581|4
6892
请教高手问题:后仿真老出现这些错误是咋回事? [复制链接]
# Loading instances from F:/QIIpractice/count4_simulation/count4_v.sdo
# ** Error: (vsim-SDF-3250) count4_v.sdo(39): Failed to find INSTANCE '\clk~I '.
# ** Error: (vsim-SDF-3250) count4_v.sdo(39): Failed to find INSTANCE 'asynch_inst'.
# ** Error: (vsim-SDF-3250) count4_v.sdo(48): Failed to find INSTANCE '\clk~clkctrl '.
# ** Error: (vsim-SDF-3250) count4_v.sdo(57): Failed to find INSTANCE 'extena0_reg'.
# ** Error: (vsim-SDF-3250) count4_v.sdo(72): Failed to find INSTANCE '\out[0]~12 '.
# ** Error: (vsim-SDF-3250) count4_v.sdo(248): Failed to find INSTANCE '\out[0]~I '.
# ** Error: (vsim-SDF-3250) count4_v.sdo(248): Failed to find INSTANCE 'asynch_inst'.
# ** Error: (vsim-SDF-3250) count4_v.sdo(114): Failed to find INSTANCE '\out[0]~reg0 '.
# ** Error: (vsim-SDF-3250) count4_v.sdo(130): Failed to find INSTANCE '\out[1]~4 '.
# ** Error: (vsim-SDF-3250) count4_v.sdo(258): Failed to find INSTANCE '\out[1]~I '.
# ** Error: (vsim-SDF-3250) count4_v.sdo(258): Failed to find INSTANCE 'asynch_inst'.
# ** Error: (vsim-SDF-3250) count4_v.sdo(145): Failed to find INSTANCE '\out[1]~reg0 '.
# ** Error: (vsim-SDF-3250) count4_v.sdo(161): Failed to find INSTANCE '\out[2]~6 '.
# ** Error: (vsim-SDF-3250) count4_v.sdo(268): Failed to find INSTANCE '\out[2]~I '.
# ** Error: (vsim-SDF-3250) count4_v.sdo(268): Failed to find INSTANCE 'asynch_inst'.
# ** Error: (vsim-SDF-3250) count4_v.sdo(175): Failed to find INSTANCE '\out[2]~reg0 '.
# ** Error: (vsim-SDF-3250) count4_v.sdo(191): Failed to find INSTANCE '\out[3]~8 '.
# ** Error: (vsim-SDF-3250) count4_v.sdo(278): Failed to find INSTANCE '\out[3]~I '.
# ** Error: (vsim-SDF-3250) count4_v.sdo(278): Failed to find INSTANCE 'asynch_inst'.
# ** Error: (vsim-SDF-3250) count4_v.sdo(205): Failed to find INSTANCE '\out[3]~reg0 '.
# ** Error: (vsim-SDF-3250) count4_v.sdo(221): Failed to find INSTANCE '\out[4]~10 '.
# ** Error: (vsim-SDF-3250) count4_v.sdo(288): Failed to find INSTANCE '\out[4]~I '.
# ** Error: (vsim-SDF-3250) count4_v.sdo(288): Failed to find INSTANCE 'asynch_inst'.
# ** Error: (vsim-SDF-3250) count4_v.sdo(232): Failed to find INSTANCE '\out[4]~reg0 '.
# ** Error: (vsim-SDF-3250) count4_v.sdo(81): Failed to find INSTANCE '\reset~I '.
# ** Error: (vsim-SDF-3250) count4_v.sdo(81): Failed to find INSTANCE 'asynch_inst'.
# ** Error: (vsim-SDF-3250) count4_v.sdo(90): Failed to find INSTANCE '\reset~clkctrl '.
# ** Error: (vsim-SDF-3250) count4_v.sdo(99): Failed to find INSTANCE 'extena0_reg'.
# ** Error: (vsim-SDF-3894) : Errors occured in reading and resolving instances from compiled SDF file(s).
# ** Warning: (vsim-3015) F:/QIIpractice/count4_simulation/count4_test.v(6): [PCDPC] - Port size (5 or 5) does not match connection size (4) for port 'out'.
#         Region: /count4_test/c
# Loading work.CYCLONEII_PRIM_DFFE
# ** Fatal: SDF files require Altera primitive library
#    Time: 0 ps  Iteration: 0  Instance: /count4_test File: F:/QIIpractice/count4_simulation/count4_test.v
# FATAL ERROR while loading design
# Error loading design
此帖出自FPGA/CPLD论坛
重复了啊  详情 回复 发表于 2011-9-23 19:51
个人签名一个为理想不懈前进的人,一个永不言败人!
欢迎光临网上店铺!
190
仿真文件需要ALTER 的私有库支持。意思是不是说,你没有加ALTERA的器件库!
此帖出自FPGA/CPLD论坛
回复 楼主 eeleader 的帖子
你好,请问你现在这个问题解决了吗?我也遇到同样地问题
此帖出自FPGA/CPLD论坛
我就只知道这个
95
重复了啊
此帖出自FPGA/CPLD论坛
