1756|0
2015
DSP的IIR数字滤波器实现程序源码 [复制链接]
亲测有效的IIR数字滤波器C程序实现,输入与输出有明显的滤波效果,如图
附录(C程序源码):
#include "DSP2833x_Device.h"     // DSP2833x Headerfile Include File
#include "DSP2833x_Examples.h"   // DSP2833x Examples Include File
#include
#define IIRNUMBER 2
#define SIGNAL1F 1000
#define SIGNAL2F 4500
#define SAMPLEF  10000
#define PI       3.1415926
float InputWave();
float IIR();
float fBn[IIRNUMBER]={ 0.0,0.7757 };
float fAn[IIRNUMBER]={ 0.1122,0.1122 };
float fXn[IIRNUMBER]={ 0.0 };
float fYn[IIRNUMBER]={ 0.0 };
float fInput,fOutput;
float fSignal1,fSignal2;
float fStepSignal1,fStepSignal2;
float f2PI;
int i;
float fin[256],fout[256];
//输入fIn毛刺正弦波,输出fOut较光滑正弦波,Graph: 256,32-bit floating integer,
int nIn,nOut;
main()
    nIn=0; nOut=0;
    fInput=fOutput=0;
    f2PI=2*PI;
    fSignal1=0.0;
    fSignal2=PI*0.1;
//  fStepSignal1=2*PI/30;
//  fStepSignal2=2*PI*1.4;
    fStepSignal1=2*PI/50;
    fStepSignal2=2*PI/2.5;
    while ( 1 )
        fInput=InputWave();
        fin[nIn]=fInput;
        nIn++; nIn%=256;
        fOutput=IIR();
        fout[nOut]=fOutput;
        nOut++;             // break point
        if ( nOut>=256 )
            nOut=0;
float InputWave()
    for ( i=IIRNUMBER-1;i>0;i-- )
        fXn=fXn[i-1];
        fYn=fYn[i-1];
    fXn[0]=sin((double)fSignal1)+cos((double)fSignal2)/6.0;
    fYn[0]=0.0;
    fSignal1+=fStepSignal1;
    if ( fSignal1>=f2PI )   fSignal1-=f2PI;
    fSignal2+=fStepSignal2;
    if ( fSignal2>=f2PI )   fSignal2-=f2PI;
    return(fXn[0]);
float IIR()
    float fSum;
    fSum=0.0;
    for ( i=0;i
        fSum+=(fXn*fAn);
        fSum+=(fYn*fBn);
    return(fSum);
