- * Copyright 2003 by Spectrum Digital Incorporated.
- * All rights reserved. Property of Spectrum Digital Incorporated.
- * ======== evmdm642.c ========
- * EVMDM642 board initializion implementation.
- #include
- #include
- #include
- #include
- #include
- #include "evmdm642.h"
- #include "evmdm642_apll.h"
- /* I2C handle */
- I2C_Handle EVMDM642_I2C_hI2C;
- /* GPIO handle */
- GPIO_Handle EVMDM642_GPIO_hGPIO;
- /* Initialize the board APIs */
- void EVMDM642_init()
- volatile Uint32 test;
- EMIFA_Config emifaCfg0 = {
- EMIFA_FMKS(GBLCTL, EK2RATE, HALFCLK) |
- EMIFA_FMKS(GBLCTL, EK2HZ, CLK) |
- EMIFA_FMKS(GBLCTL, EK2EN, ENABLE) |
- EMIFA_FMKS(GBLCTL, BRMODE, MRSTATUS) |
- EMIFA_FMKS(GBLCTL, NOHOLD, DISABLE) |
- EMIFA_FMKS(GBLCTL, EK1HZ, HIGHZ) |
- EMIFA_FMKS(GBLCTL, EK1EN, ENABLE) |
- EMIFA_FMKS(GBLCTL, CLK4EN, ENABLE) |
- EMIFA_FMKS(GBLCTL, CLK6EN, ENABLE),
- EMIFA_FMKS(CECTL, WRSETUP, DEFAULT) |
- EMIFA_FMKS(CECTL, WRSTRB, DEFAULT) |
- EMIFA_FMKS(CECTL, WRHLD, DEFAULT) |
- EMIFA_FMKS(CECTL, RDSETUP, DEFAULT) |
- EMIFA_FMKS(CECTL, TA, DEFAULT) |
- EMIFA_FMKS(CECTL, RDSTRB, DEFAULT) |
- EMIFA_FMKS(CECTL, MTYPE, SDRAM64) |
- EMIFA_FMKS(CECTL, RDHLD, DEFAULT),
- EMIFA_FMKS(CECTL, WRSETUP, OF(7)) |
- EMIFA_FMKS(CECTL, WRSTRB, OF(14)) |
- EMIFA_FMKS(CECTL, WRHLD, OF(2)) |
- EMIFA_FMKS(CECTL, RDSETUP, OF(2)) |
- EMIFA_FMKS(CECTL, TA, OF(2)) |
- EMIFA_FMKS(CECTL, RDSTRB, OF(14)) |
- EMIFA_FMKS(CECTL, MTYPE, ASYNC8) |
- EMIFA_FMKS(CECTL, RDHLD, OF(1)),
- EMIFA_FMKS(CECTL, WRSETUP, OF(2)) |
- EMIFA_FMKS(CECTL, WRSTRB, OF(10)) |
- EMIFA_FMKS(CECTL, RDSTRB, OF(10)) |
- EMIFA_FMKS(CECTL, MTYPE, ASYNC32) |
- EMIFA_FMKS(CECTL, RDHLD, OF(2)),
- EMIFA_FMKS(CECTL, MTYPE, SYNC32) |
- EMIFA_FMKS(SDCTL, SDBSZ, 4BANKS) |
- EMIFA_FMKS(SDCTL, SDRSZ, 12ROW) |
- EMIFA_FMKS(SDCTL, SDCSZ, 8COL) |
- EMIFA_FMKS(SDCTL, RFEN, ENABLE) |
- EMIFA_FMKS(SDCTL, INIT, YES) |
- EMIFA_FMKS(SDCTL, TRCD, OF(1)) |
- EMIFA_FMKS(SDCTL, TRP, OF(1)) |
- EMIFA_FMKS(SDCTL, TRC, OF(5)) |
- EMIFA_FMKS(SDCTL, SLFRFR, DISABLE),
- EMIFA_FMKS(SDTIM, XRFR, OF(0)) |
- EMIFA_FMKS(SDTIM, PERIOD, OF(2075)),
- EMIFA_FMKS(SDEXT, WR2RD, OF(1)) |
- EMIFA_FMKS(SDEXT, WR2DEAC, OF(3)) |
- EMIFA_FMKS(SDEXT, WR2WR, OF(1)) |
- EMIFA_FMKS(SDEXT, R2WDQM, OF(3)) |
- EMIFA_FMKS(SDEXT, RD2WR, OF(2)) |
- EMIFA_FMKS(SDEXT, RD2DEAC, OF(3)) |
- EMIFA_FMKS(SDEXT, RD2RD, OF(1)) |
- EMIFA_FMKS(SDEXT, THZP, OF(2)) |
- EMIFA_FMKS(SDEXT, TWR, OF(2)) |
- EMIFA_FMKS(SDEXT, TRRD, OF(0)) |
- EMIFA_FMKS(SDEXT, TRAS, OF(6)) |
- EMIFA_FMKS(SDEXT, TCL, OF(1)),
- EMIFA_CESEC_DEFAULT,
- EMIFA_FMKS(CESEC, SNCCLK, ECLKOUT2) |
- EMIFA_FMKS(CESEC, RENEN, READ) |
- EMIFA_FMKS(CESEC, CEEXT, ACTIVE) |
- EMIFA_FMKS(CESEC, SYNCWL, 0CYCLE) |
- EMIFA_FMKS(CESEC, SYNCRL, 3CYCLE)
- I2C_Config i2cCfg = {
- 0x0000007f, /* I2COAR - Not used if master */
- 0x00000000, /* I2CIER - Disable interrupts, use polling */
- 0x0000001b, /* I2CCLKL - Low period for 100KHz operation */
- 0x0000001b, /* I2CCLKH - High period for 100KHz operation */
- 0x00000002, /* I2CCNT - Data words per transmission */
- 0x0000001a, /* I2CSAR - Slave address */
- 0x00004680, /* I2CMDR - Mode */
- 0x00000019 /* I2CPSC - Prescale 300MHz to 12MHz */
- /* Initialize CSL */
- CSL_init();
- /* Unlock PERCFG through PCFGLOCK */
- *((unsigned long *)0x1b3f018) = 0x10c0010c;
- /* Enable VP0-VP2, I2C and McASP0 in PERCFG */
- *((unsigned long *)0x1b3f000) = 0x79;
- /* Read back PERCFG */
- test = *((unsigned long *)0x1b3f000);
- /* Wait at least 128 CPU cycles */
- EVMDM642_wait(128);
- /* Initialize EMIFA */
- EMIFA_config(&emifaCfg0);
- /* Open I2C handle */
- EVMDM642_I2C_hI2C = I2C_open(I2C_PORT0, I2C_OPEN_RESET);
- /* Configure I2C controller */
- I2C_config(EVMDM642_I2C_hI2C, &i2cCfg);
- /* Take I2C out of reset */
- I2C_outOfReset(EVMDM642_I2C_hI2C);
- /* Open the GPIO handle */
- EVMDM642_GPIO_hGPIO = GPIO_open(GPIO_DEV0, GPIO_OPEN_RESET);
- /* Enable caching of SDRAM */
- CACHE_enableCaching(CACHE_EMIFA_CE00);
- CACHE_enableCaching(CACHE_EMIFA_CE01);
- /* Load the FPGA from Flash */
- EVMDM642_fpgaLoad(EVMDM642_FPGAFLASH_BASE);
- /* Configure APLL in default state */
- EVMDM642_APLL_rset(EVMDM642_APLL_FSG0);
- /* Read an 8-bit value from a CPLD register */
- Uint8 EVMDM642_rget(Int16 regnum)
- Uint8 *pdata;
- /* Return lower 8 bits of register */
- pdata = (Uint8 *)(EVMDM642_CPLD_BASE + regnum);
- return (*pdata & 0xff);
- /* Write an 8-bit value to a CPLD register */
- void EVMDM642_rset(Int16 regnum, Uint8 regval)
- Uint8 *pdata;
- /* Write lower 8 bits of register */
- *pdata = (regval & 0xff);
- /* Spin in a delay loop for delay iterations */
- void EVMDM642_wait(Uint32 delay)
- volatile Uint32 i, n;
- n = 0;
- for (i = 0; i < delay; i++)
- n = n + 1;
- /* Spin in a delay loop for delay microseconds */
- void EVMDM642_waitusec(Uint32 delay)
- EVMDM642_wait(delay * 21);
- evmdm642_aic23_loopback.c
- * ======== evmdm642_aic23_loopback.c ========
- * EVMDM642_AIC23_loopback() implementation
- #include
- #include
- * ======== EVMDM642_AIC23_loopback ========
- * Enable/disable codec loopback mode
- void EVMDM642_AIC23_loopback(EVMDM642_AIC23_CodecHandle hCodec, Int16 mode)
- int regval;
- /* Set bypass bit if mode is true */
- regval = (mode) ? 0x8 : 0x0;
- /* Write to codec register */
- EVMDM642_AIC23_rset(hCodec, EVMDM642_AIC23_ANAPATH,
- (EVMDM642_AIC23_rget(hCodec, EVMDM642_AIC23_ANAPATH) & 0xfff7 | regval));
- evmdm642_aic23_mute.c
- * ======== evmdm642_aic23_mute.c ========
- * EVMDM642_AIC23_mute() implementation
- #include
- #include
- * ======== EVMDM642_AIC23_mute ========
- * Enable/disable codec mute mode
- void EVMDM642_AIC23_mute(EVMDM642_AIC23_CodecHandle hCodec, Int16 mode)
- int regval;
- /* Enable mute if mode is true */
- regval = (mode) ? 0x08 : 0x00;
- /* Write to codec registers (left and right) */
- EVMDM642_AIC23_rset(hCodec, EVMDM642_AIC23_DIGPATH,
- (EVMDM642_AIC23_rget(hCodec, EVMDM642_AIC23_DIGPATH) & 0xfff7) | regval);
- evmdm642_aic23_opencodec.c
- * ======== evmdm642_aic23_openCodec.c ========
- * EVMDM642_AIC23_openCodec() implementation
- #include
- #include
- #include
- #include
- #include
- /* AIC23 handles */
- MCASP_Handle EVMDM642_AIC23_hMcASP;
- MCASP_ConfigGbl mcaspCfgDataGbl = {
- 0x00000000, /* PFUNC - All pins as McASP */
- 0x00000001, /* PDIR - XMT DATA output, rest are inputs */
- 0x00000000, /* DITCTL - DIT mode disable */
- 0x00000000, /* DLBCTL - Loopback disabled */
- 0x00000000 /* AMUTE - Never drive AMUTE */
- MCASP_ConfigRcv mcaspCfgDataRcv = {
- 0xffffffff, /* RMASK - Use all 32 bits */
- 0x000080f8, /* RFMT - MSB first, 32-bit slots, CPU bus, 0 bit delay */
- 0x00000000, /* AFSRCTL - burst, single bit frame sync, ext FS */
- 0x00000080, /* ACLKRCTL - Sample on rising CLK, divide by 1, ext CLK */
- 0x00000000, /* AHCLKRCTL - External HCLK */
- 0x00000001, /* RTDM - Slots 0-31 are active */
- 0x00000000, /* RINTCTL - No interrupts */
- 0x00000000 /* RCLKCHK - Not used */
- MCASP_ConfigXmt mcaspCfgDataXmt = {
- 0xffffffff, /* XMASK - Use all 32 bits */
- 0x000080f8, /* XFMT - MSB first, 32-bit slots, CPU bus, 0 bit delay */
- 0x00000000, /* AFSXCTL - burst, single bit frame sync, ext FS */
- 0x000000c0, /* ACLKXCTL - Sample on falling CLK, divide by 1, ext CLK */
- 0x00000000, /* AHCLKXCTL - External HCLK */
- 0x00000001, /* XTDM - Slots 0-31 are active */
- 0x00000000, /* XINTCTL - No interrupts */
- 0x00000000 /* XCLKCHK - Not used */
- MCASP_ConfigSrctl mcaspCfgDataSrctl = {
- 0x0000000d, /* SRCTL0 - Transmit, active high */
- 0x0000000e, /* SRCTL1 - Receive, active high */
- 0x00000000, /* SRCTL2 - Inactive */
- 0x00000000, /* SRCTL3 - Inactive */
- 0x00000000, /* SRCTL4 - Inactive */
- 0x00000000, /* SRCTL5 - Inactive */
- 0x00000000, /* SRCTL6 - Inactive */
- 0x00000000 /* SRCTL7 - Inactive */
- MCASP_Config mcaspCfgData = {
- &mcaspCfgDataGbl,
- &mcaspCfgDataRcv,
- &mcaspCfgDataXmt,
- &mcaspCfgDataSrctl
- * ======== EVMDM642_AIC23_openCodec ========
- * Open the codec and return a codec handle
- EVMDM642_AIC23_CodecHandle EVMDM642_AIC23_openCodec(Int16 id, EVMDM642_AIC23_Config *Config, Int16 direction)
- Uint32 gblctl;
- /* Configure the AIC23 */
- EVMDM642_AIC23_config(id, Config);
- /* Open and configure the McASP */
- EVMDM642_AIC23_hMcASP = MCASP_open(MCASP_DEV0, MCASP_OPEN_RESET);
- MCASP_config(EVMDM642_AIC23_hMcASP, &mcaspCfgData);
- /* Clear transmit and receive status */
- MCASP_RSETH(EVMDM642_AIC23_hMcASP, RSTAT, 0xffff);
- MCASP_RSETH(EVMDM642_AIC23_hMcASP, XSTAT, 0xffff);
- /* Clear GBLCTL */
- gblctl = 0;
- MCASP_RSETH(EVMDM642_AIC23_hMcASP, GBLCTL, gblctl);
- /* Enable transmit/receive serializers */
- if ((direction & EVMDM642_AIC23_INPUT) != 0)
- gblctl |= 0x4;
- if ((direction & EVMDM642_AIC23_OUTPUT) != 0)
- gblctl |= 0x400;
- /* Enable transmit/receive state machines */
- gblctl |= 0x8;
- MCASP_RSETH(EVMDM642_AIC23_hMcASP, XBUF0, 0);
- gblctl |= 0x800;
- return TRUE;
- evmdm642_aic23_read.c
- * ======== evmdm642_aic23_read16.c ========
- * EVMDM642_AIC23_read() implementation
- #include
- #include
- * ======== EVMDM642_AIC23_read ========
- * Read a 32-bit value from the codec
- Int16 EVMDM642_AIC23_read(EVMDM642_AIC23_CodecHandle hCodec, Uint32 *val)
- /* If McASP doesn't have new data available, return false */
- if ((MCASP_RGETH(EVMDM642_AIC23_hMcASP, SRCTL1) & 0x20) == 0) {
- return (FALSE);
- /* Read the data */
- *val = MCASP_RGETH(EVMDM642_AIC23_hMcASP, XBUF1);
- return (TRUE);
- evmdm642_aic23_registers.c
- * ======== evmdm642_aic23_registers.c ========
- * EVMDM642_AIC23_rset() and EVMDM642_AIC23_rget() implementation
- #include
- #include
- #include
- #include
- /* Internal codec state used to simulate read/write functionality */
- static EVMDM642_AIC23_Config codecstate = EVMDM642_AIC23_DEFAULTCONFIG;
- static I2C_Config aic23XmtCfg = {
- 0x00004ea0, /* I2CMDR - Mode */
- * ======== EVMDM642_AIC23_rset ========
- * Set codec register regnum to value regval
- void EVMDM642_AIC23_rset(EVMDM642_AIC23_CodecHandle hCodec, Uint16 regnum, Uint16 regval)
- Uint16 data;
- I2C_Config prevI2CCfg;
- /* Mask off lower 9 bits */
- regval &= 0x1ff;
- /* Set transmit data */
- data = (regnum << 9) | regval;
- /* Wait until bus is free */
- while (I2C_bb(EVMDM642_I2C_hI2C));
- /* Save old settings */
- I2C_getConfig(EVMDM642_I2C_hI2C, &prevI2CCfg);
- /* Restore settings for AIC23 */
- I2C_config(EVMDM642_I2C_hI2C, &aic23XmtCfg);
- /* Submit the MSB for transmit */
- I2C_RSETH(EVMDM642_I2C_hI2C, I2CDXR, (data >> 8) & 0xff);
- /* Generate start condition, starts transmission */
- I2C_start(EVMDM642_I2C_hI2C);
- /* Wait until MSB transmit is done */
- while(!I2C_xrdy(EVMDM642_I2C_hI2C));
- /* Submit the LSB for transmit */
- I2C_writeByte(EVMDM642_I2C_hI2C, data & 0xff);
- /* Generate stop condition */
- I2C_sendStop(EVMDM642_I2C_hI2C);
- /* Save register value if regnum is in range */
- if (regnum < EVMDM642_AIC23_NUMREGS)
- codecstate.regs[regnum] = regval;
- /* Short delay for AIC23 to accept command */
- EVMDM642_waitusec(20);
- /* Reconfigure I2C with old settings */
- I2C_config(EVMDM642_I2C_hI2C, &prevI2CCfg);
- * ======== EVMDM642_AIC23_rget ========
- * Return value of codec register regnum
- Uint16 EVMDM642_AIC23_rget(EVMDM642_AIC23_CodecHandle hCodec, Uint16 regnum)
- return codecstate.regs[regnum];
- else
- return 0;
- * ======== EVMDM642_AIC23_config ========
- * Set the default codec register config values
- void EVMDM642_AIC23_config(EVMDM642_AIC23_CodecHandle hCodec, EVMDM642_AIC23_Config *Config)
- int i;
- /* Use default parameters if none are given */
- if (Config == NULL)
- Config = &codecstate;
- /* Reset the codec */
- EVMDM642_AIC23_rset(hCodec, 15, 0);
- /* Assign each register */
- for (i = 0; i < EVMDM642_AIC23_NUMREGS; i++)
- if (i != 6)
- EVMDM642_AIC23_rset(hCodec, i, Config -> regs);
- EVMDM642_AIC23_rset(hCodec, 6, Config -> regs[6]);
