4276|5
81
2.8寸TFTLCD无法显示 [复制链接]
2.8寸TFTLCD屏不仅无法显示,连背光都不能工作,驱动背光在LCD初始化代码里,我把部分重要的代码贴下来,恳请大佬帮我过目一下,我寻找了好几天还是查找不出来了,开始怀疑是不是硬件方面出现的问题了,小弟在此谢过了!!!
我用的是NE1,地址线是A16,
基地址设置为:
#define LCD_BASE        ((u32)(0x60000000 | 0x0001FFFE))
#define LCD             ((LCD_TypeDef *) LCD_BASE)
PE1口接的LCD背光
PD7接LCD_CS
PD11接LCD_RS
其他设置和原子哥的模板一模一样的
FSMC初始化配置如下:
        GPIO_InitTypeDef GPIO_InitStructure;
        FSMC_NORSRAMInitTypeDef  FSMC_NORSRAMInitStructure;
        FSMC_NORSRAMTimingInitTypeDef  readWriteTiming;
        FSMC_NORSRAMTimingInitTypeDef  writeTiming;
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_FSMC,ENABLE);        //使能FSMC时钟
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE|RCC_APB2Periph_GPIOD ,ENABLE);//使能PORTE,PORTD
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;                                 //PE1 推挽输出 背光
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;                  //推挽输出
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_Init(GPIOE, &GPIO_InitStructure);
        //PORTD复用推挽输出
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_14|GPIO_Pin_15;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;                  //复用推挽输出
        GPIO_Init(GPIOD, &GPIO_InitStructure);
        //PORTE复用推挽输出
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
          //PORTD12复用推挽输出 A16
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7|GPIO_Pin_11;         //        //PORTD复用推挽输出
        readWriteTiming.FSMC_AddressSetupTime = 0x01;         //地址建立时间(ADDSET)为2个HCLK 1/36M=27ns
        readWriteTiming.FSMC_AddressHoldTime = 0x00;         //地址保持时间(ADDHLD)模式A未用到
        readWriteTiming.FSMC_DataSetupTime = 0x0f;                 // 数据保存时间为16个HCLK,因为液晶驱动IC的读数据的时候,速度不能太快,尤其对1289这个IC。
        readWriteTiming.FSMC_BusTurnAroundDuration = 0x00;
        readWriteTiming.FSMC_CLKDivision = 0x00;
        readWriteTiming.FSMC_DataLatency = 0x00;
        readWriteTiming.FSMC_AccessMode = FSMC_AccessMode_A;         //模式A
        writeTiming.FSMC_AddressSetupTime = 0x00;         //地址建立时间(ADDSET)为1个HCLK
        writeTiming.FSMC_AddressHoldTime = 0x00;         //地址保持时间(A
        writeTiming.FSMC_DataSetupTime = 0x03;                 ////数据保存时间为4个HCLK
        writeTiming.FSMC_BusTurnAroundDuration = 0x00;
        writeTiming.FSMC_CLKDivision = 0x00;
        writeTiming.FSMC_DataLatency = 0x00;
        writeTiming.FSMC_AccessMode = FSMC_AccessMode_A;         //模式A
  FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM1;//  这里我们使用NE1 。
  FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable; // 不复用数据地址
  FSMC_NORSRAMInitStructure.FSMC_MemoryType =FSMC_MemoryType_SRAM;// FSMC_MemoryType_SRAM;  //SRAM
  FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;//存储器数据宽度为16bit
  FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode =FSMC_BurstAccessMode_Disable;// FSMC_BurstAccessMode_Disable;
  FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
  FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait=FSMC_AsynchronousWait_Disable;
  FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
  FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
  FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable;        //  存储器写使能
  FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
  FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Enable; // 读写使用不同的时序
  FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
  FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &readWriteTiming; //读写时序
  FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &writeTiming;  //写时序
  FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);  //初始化FSMC配置
  FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM1, ENABLE);  // 使能BANK1
MP3播放器原理图&PCB.rar
2.7 MB, 下载次数: 14
基于是stm32的MP3播放器code.rar
2.34 MB, 下载次数: 12
此帖出自stm32/stm8论坛
你的问题比较大。 用的MCU确定是STM32F103VB吗? 如果是的话,那么这是一款中密度产品,没有FSMC总线。   详情 回复 发表于 2018-12-21 15:48
点赞 关注(1)
672
PE1代码里操作了吗? 你只贴了初始化的代码,一般fsmc没问题的。还有问题就把完整点的代码及硬件放上来吧
此帖出自stm32/stm8论坛
PE1单独拿出来进行配置的话是可以操作的,但是放在LCD_Init()里进行配置就没有反应了。后续我把原理图和所以代码打包上来  详情 回复 发表于 2018-12-21 13:02
81
此帖出自stm32/stm8论坛
664
104
你的问题比较大。
此帖出自stm32/stm8论坛
把MCU换成STM32F103VET6,用Bank1的NE1去操作还是可以的把?  详情 回复 发表于 2018-12-21 16:49
用的还真是STM32F103VB。。。。 之前还在想有没有FSMC总线来着,经你这么一说,哎。不过还是谢谢你啊  详情 回复 发表于 2018-12-21 16:22
81
gs001588 发表于 2018-12-21 15:48
你的问题比较大。
此帖出自stm32/stm8论坛
81
你的问题比较大。
此帖出自stm32/stm8论坛
