2354|0
通过stm32对lmx2582寄存器操作,工程文件在附件 [复制链接]
写动作
void WriteOneByte(unsigned int InstruAndData)
           int temp;
    CLR_CS;                   //bring CS low
    CLR_SCLK;
    delay(1);
    for(temp=0x800000;temp;temp>>=1)//24bit
                        if(InstruAndData&temp)
                                SET_SDIO;                    //Send 1 to SDIO pin
      else
                                CLR_SDIO;                  //Send 0 to SDIO pin
      delay(1);
      SET_SCLK;                   //SCLK Rising
      delay(2);
      CLR_SCLK;                  //SCLK falling
      delay(1);
    SET_CS;                           //bring CS high again
此内容由EEWORLD论坛网友poo11原创,如需转载或用于商业用途需征得作者同意并注明出处
STM32-LMX2582 (2).zip
14.45 MB, 下载次数: 359
