GD32F350使用Timer1,参照例程,通道1、2、3产生PWM信号正常,当不使用通道2、3时,PB10引脚有不固定的波形输出,怀疑是干扰信号。
void timer_config(void)
TIMER1 configuration: generate 3 PWM signals with 3 different duty cycles:
TIMER1CLK is 1MHz
TIMER1 channel1 duty cycle = (4000/ 16000)* 100 = 25%
TIMER1 channel2 duty cycle = (8000/ 16000)* 100 = 50%
TIMER1 channel3 duty cycle = (12000/ 16000)* 100 = 75%
timer_oc_parameter_struct timer_ocintpara;
timer_parameter_struct timer_initpara;
rcu_periph_clock_enable(RCU_TIMER1);
timer_deinit(TIMER1);
/* TIMER1 configuration */
#ifdef GD32F330
timer_initpara.prescaler = 83;
#endif /* GD32F330 */
#ifdef GD32F350
timer_initpara.prescaler = 107;
#endif /* GD32F350 */
timer_initpara.alignedmode = TIMER_COUNTER_EDGE;
timer_initpara.counterdirection = TIMER_COUNTER_UP;
timer_initpara.period = 15999;
timer_initpara.clockdivision = TIMER_CKDIV_DIV1;
timer_initpara.repetitioncounter = 0;
timer_init(TIMER1,&timer_initpara);
/* CH1,CH2 and CH3 configuration in PWM mode0 */
timer_ocintpara.ocpolarity = TIMER_OC_POLARITY_HIGH;
timer_ocintpara.outputstate = TIMER_CCX_ENABLE;
timer_channel_output_config(TIMER1,TIMER_CH_1,&timer_ocintpara);
timer_channel_output_pulse_value_config(TIMER1,TIMER_CH_1,3999);
timer_channel_output_mode_config(TIMER1,TIMER_CH_1,TIMER_OC_MODE_PWM0);
timer_channel_output_shadow_config(TIMER1,TIMER_CH_1,TIMER_OC_SHADOW_DISABLE);
/* auto-reload preload enable */
timer_auto_reload_shadow_enable(TIMER1);
timer_enable(TIMER1);
void gpio_config(void)
/*Configure PB3 PB10 PB11(TIMER1 CH1 CH2 CH3) as alternate function*/
gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_3);
gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_3);
gpio_af_set(GPIOB, GPIO_AF_2, GPIO_PIN_3);
