3649|3
31
GD32F350定时器14与定时器2有什么不同? [复制链接]
用Timer2产生PWM正常,但用类似的程序,Timer14没有PWM输出。void timer2_config(void)
     timer_oc_parameter_struct timer_ocintpara;
    timer_parameter_struct timer_initpara;
    rcu_periph_clock_enable(RCU_TIMER2);
    timer_deinit(TIMER2);
    timer_initpara.prescaler         = 539;
    timer_initpara.alignedmode       = TIMER_COUNTER_EDGE;
    timer_initpara.counterdirection  = TIMER_COUNTER_UP;
    timer_initpara.period            = 199;
    timer_initpara.clockdivision     = TIMER_CKDIV_DIV1;
    timer_initpara.repetitioncounter = 0;
    timer_init(TIMER2, &timer_initpara);
    /* CH1, CH2 and CH3 configuration in PWM mode0 */
    timer_ocintpara.ocpolarity  = TIMER_OC_POLARITY_HIGH;
    timer_ocintpara.outputstate = TIMER_CCX_ENABLE;
    timer_channel_output_config(TIMER2, TIMER_CH_0, &timer_ocintpara);
    timer_channel_output_pulse_value_config(TIMER2, TIMER_CH_0, 100);
    timer_channel_output_mode_config(TIMER2, TIMER_CH_0, TIMER_OC_MODE_PWM0);
    timer_channel_output_shadow_config(TIMER2, TIMER_CH_0, TIMER_OC_SHADOW_DISABLE);
    /* auto-reload preload enable */
    timer_auto_reload_shadow_enable(TIMER2);
    timer_enable(TIMER2);
此帖出自GD32 MCU论坛
我就是过来看看的  详情 回复 发表于 2018-11-17 19:19
点赞 关注(1)
个人签名科技飞速发展,学习永无止境。变压器有载调压,一小时万次切换。
31
void timer14_config(void)
    rcu_periph_clock_enable(RCU_TIMER14);
    timer_deinit(TIMER14);
    timer_init(TIMER14, &timer_initpara);
    timer_channel_output_config(TIMER14, TIMER_CH_0, &timer_ocintpara);
    timer_channel_output_pulse_value_config(TIMER14, TIMER_CH_0, 100);
    timer_channel_output_mode_config(TIMER14, TIMER_CH_0, TIMER_OC_MODE_PWM0);
    timer_channel_output_shadow_config(TIMER14, TIMER_CH_0, TIMER_OC_SHADOW_DISABLE);
    timer_auto_reload_shadow_enable(TIMER14);
    timer_enable(TIMER14);
此帖出自GD32 MCU论坛
31
void gpio_config(void)
    /*Configure PB3 PB10 PB11(TIMER1 CH1 CH2 CH3) as alternate function*/
    gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_3);
    gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_3);
    gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_10);
    gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_10);
    gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_11);
    gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_11);
    gpio_af_set(GPIOB, GPIO_AF_2, GPIO_PIN_3);
    gpio_af_set(GPIOB, GPIO_AF_2, GPIO_PIN_10);
    gpio_af_set(GPIOB, GPIO_AF_2, GPIO_PIN_11);
    //配置 PB4(TIMER2 CH0) 为复用功能
    gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_4);
    gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_4);
    gpio_af_set(GPIOB, GPIO_AF_1, GPIO_PIN_4);
    //配置 PB14(TIMER14 CH0) 为复用功能
    gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_14);
    gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_14);
    gpio_af_set(GPIOB, GPIO_AF_1, GPIO_PIN_14);
此帖出自GD32 MCU论坛
我就是过来看看的
此帖出自GD32 MCU论坛
个人签名北京玻璃隔断www.bjtjblgd.com 法兰厂家www.zsfl888.com 丁基胶带www.djjd8.com 薄膜开关www.hbhksjdz.com
