3539|4
170
以太网的一个程序(经典) [复制链接]
以太网的一个程序(经典)
// ZT018 Driver // 引入相关芯片的头文件 #include #include "types.h" #define BIT(x) (1 << x) #define I2C_EN BIT(6) #define I2C_STA BIT(5) #define I2C_STO BIT(4) #define I2C_SI BIT(3) #define I2C_AA BIT(2) #define LCD_WRITE 0x50 #define LCD_READ 0x51 void LCD_I2C0Init(void) { PINSEL0 |= 0x00000050; I2C0SCLH = (60000000/400000 + 1) / 2; I2C0SCLL = (60000000/400000) / 2; I2C0CONCLR = I2C_STA | I2C_STO | I2C_SI | I2C_AA; I2C0CONSET = I2C_EN; }//I2C0Init void I2CwriteByte( U8 data ) { I2C0DAT = data; //load x0 I2C0CONCLR = I2C_SI; //send data while (~I2C0CONSET & I2C_SI); //wait } void I2CwriteWord( U16 data ) { I2C0DAT = data>>8; //load x0 I2C0CONCLR = I2C_SI; //send data while (~I2C0CONSET & I2C_SI); //wait I2C0DAT = data; //load x0 I2C0CONCLR = I2C_SI; //send data while (~I2C0CONSET & I2C_SI); //wait } void I2Cstop(void) { I2C1CONSET = I2C_STO; //setup stop condition I2C1CONCLR = I2C_SI; //start sending stop while (I2C1CONSET & I2C_STO); //wait for stop to be sent } void LCD_WriteCmd( U8 Cmd ) { volatile unsigned int s; do { I2C0CONSET = I2C_STA | I2C_SI; //setup start condition I2C0CONCLR = I2C_SI; //send start condition s = I2C0CONSET; while (~I2C0CONSET & I2C_SI) s=I2C0CONSET; //wait for start to be sent I2C0DAT = LCD_WRITE; //load the LCD address I2C0CONCLR = I2C_STA | I2C_SI; //send EEPROM address while (~I2C0CONSET & I2C_SI); //wait for address to be sent s=I2C0STAT; }while (I2C0STAT != 0x18); //repeat if no ACK received I2CwriteByte( Cmd ); } unsigned char I2CReadByte (U8 Cmd) { volatile unsigned int s; unsigned char Data; LCD_WriteCmd( Cmd ); do { I2C0CONSET = I2C_STA | I2C_SI; //setup start condition I2C0CONCLR = I2C_SI; //send start condition while (~I2C0CONSET & I2C_SI); //wait for start to be sent I2C0DAT = LCD_READ; //load address of eeprom I2C0CONCLR = I2C_STA | I2C_SI; //start sending address while (~I2C0CONSET & I2C_SI); //wait for address to be sent } while (I2C0STAT != 0x40); //repeat if no ack received I2C0CONCLR = I2C_SI; //start reading data while (~I2C0CONSET & I2C_SI); //wait for data to be received Data = I2C0DAT; I2C0CONSET = I2C_STO; //setup stop condition I2C0CONCLR = I2C_SI; //send stop condition while (I2C0CONSET & I2C_STO); //wait for stop to be sent return Data; //return the data }//ReadEEPROM U8 LCD_Status_Read( void ) { return I2CReadByte(0); } void LCD_Write1coor( U8 Cmd, U8 x0, U8 y0 ) { LCD_WriteCmd( Cmd ); I2CwriteByte( x0 ); I2CwriteByte( y0 ); } void LCD_Write2coor( U8 Cmd, U8 x0, U8 y0, U8 x1, U8 y1 ) { LCD_WriteCmd( Cmd ); I2CwriteByte( x0 ); I2CwriteByte( y0 ); I2CwriteByte( x1 ); I2CwriteByte( y1 ); } void LCD_BMP( U8 x0, U8 y0, U8 x1, U8 y1 , U8 * Bmp ) { S16 i,j; while( LCD_Status_Read()&0x80 ); // wait while lcd busy LCD_Write2coor( 0x10, x0,y0,x1,y1 ); for( i = y1 - y0 + 1; i >= 0; i-- ) for( j = 0; j <= x1 - x0; j++ ) { U16* PixP = (U16*)(Bmp+0x46+i*(x1-x0+1)*2); U16 Pix = *(PixP+j); I2C0DAT = Pix>>8; //load high I2C0CONCLR = I2C_SI; //send data while (~I2C0CONSET & I2C_SI); //wait I2C0DAT = Pix; //load high I2C0CONCLR = I2C_SI; //send data while (~I2C0CONSET & I2C_SI); //wait } I2Cstop(); } void LCD_Pixel( U8 x, U8 y, U16 Color ) { while( LCD_Status_Read()&0x80 ); // wait while lcd busy LCD_Write1coor( 0x11, x, y ); I2CwriteWord( Color ); I2Cstop(); } void LCD_Line( U8 x0, U8 y0, U8 x1, U8 y1 , U16 Color ) { while( LCD_Status_Read()&0x80 ); // wait while lcd busy LCD_Write2coor( 0x12, x0,y0,x1,y1 ); I2CwriteWord( Color ); I2Cstop(); } void LCD_Rectangle( U8 x0, U8 y0, U8 x1, U8 y1 , U16 Color ) { while( LCD_Status_Read()&0x80 ); // wait while lcd busy LCD_Write2coor( 0x13, x0,y0,x1,y1 ); I2CwriteWord( Color ); I2Cstop(); } void LCD_RectangleFill( U8 x0, U8 y0, U8 x1, U8 y1 , U16 Color ) { while( LCD_Status_Read()&0x80 ); // wait while lcd busy LCD_Write2coor( 0x14, x0,y0,x1,y1 ); I2CwriteWord( Color ); I2Cstop(); } void LCD_Circle( U8 x0, U8 y0, U8 r, U16 Color ) { while( LCD_Status_Read()&0x80 ); // wait while lcd busy LCD_Write1coor( 0x15, x0,y0 ); I2CwriteByte( r ); I2CwriteWord( Color ); I2Cstop(); } void LCD_CircleFill( U8 x0, U8 y0, U8 r, U16 Color ) { while( LCD_Status_Read()&0x80 ); // wait while lcd busy LCD_Write1coor( 0x16, x0,y0 ); I2CwriteByte( r ); I2CwriteWord( Color ); I2Cstop(); } void LCD_Ellipse( U8 x0, U8 y0, U8 x1, U8 y1 , U16 Color ) { while( LCD_Status_Read()&0x80 ); // wait while lcd busy LCD_Write2coor( 0x17, x0,y0,x1,y1 ); I2CwriteWord( Color ); I2Cstop(); } void LCD_EllipseFill( U8 x0, U8 y0, U8 x1, U8 y1 , U16 Color ) { while( LCD_Status_Read()&0x80 ); // wait while lcd busy LCD_Write2coor( 0x18, x0,y0,x1,y1 ); I2CwriteWord( Color ); I2Cstop(); } void LCD_Pieslice( U8 x0, U8 y0, U8 r, U16 start, U16 end, U16 Color ) { while( LCD_Status_Read()&0x80 ); // wait while lcd busy LCD_Write1coor( 0x19, x0,y0 ); I2CwriteByte( r ); I2CwriteWord( start ); I2CwriteWord( end ); I2CwriteWord( Color ); I2Cstop(); } void LCD_MoveTo( U8 x, U8 y ) { while( LCD_Status_Read()&0x80 ); // wait while lcd busy LCD_Write1coor( 0x30, x, y ); I2Cstop(); } void LCD_PrintU8( U8 data ) { while( LCD_Status_Read()&0x80 ); // wait while lcd busy LCD_WriteCmd( 0x61 ); I2CwriteByte( data ); I2Cstop(); } void LCD_PrintX8( U8 data ) { while( LCD_Status_Read()&0x80 ); // wait while lcd busy LCD_WriteCmd( 0x63 ); I2CwriteByte( data ); I2Cstop(); } void LCD_SetFcolor( U16 Color ) { while( LCD_Status_Read()&0x80 ); // wait while lcd busy LCD_WriteCmd( 0x31 ); I2CwriteWord( Color ); I2Cstop(); } void LCD_SetBcolor( U16 Color ) { while( LCD_Status_Read()&0x80 ); // wait while lcd busy LCD_WriteCmd( 0x32 ); I2CwriteWord( Color ); I2Cstop(); } void LCD_SetFont( U8 data ) { while( LCD_Status_Read()&0x80 ); // wait while lcd busy LCD_WriteCmd( 0x80 ); I2CwriteByte( data ); I2Cstop(); } void LCD_PutString( char *s ) { while( *s ) { while( LCD_Status_Read()&0x80 ); // wait while lcd busy LCD_WriteCmd( 0x60 ); I2CwriteByte( *s ); ++s; I2Cstop(); } } void putch( char c ) { while( LCD_Status_Read()&0x80 ); // wait while lcd busy LCD_WriteCmd( 0x81 ); I2CwriteByte( c ); I2Cstop(); } void PutString( U8 x, U8 y, char *s, U16 F, U16 B ) { LCD_MoveTo( x, y ); LCD_SetFcolor( F ); LCD_SetBcolor( B ); LCD_PutString( s ); } void LCD_Clear_Screen( U16 B ) { LCD_RectangleFill( 0, 0, 159, 127, B ); } void printStr( char *s ) { while( *s ) { putch( *s++ ); } }
此帖出自电子竞赛论坛
本帖最后由 paulhyde 于 2014-9-15 09:21 编辑 好呀~~~~~~~~~~~~~~~~~~···    详情 回复 发表于 2010-5-19 20:46
在做以太网数据传输,虽然不懂,还是顶顶
此帖出自电子竞赛论坛
大家看怎么样 我认为很好.
此帖出自电子竞赛论坛
哈哈。。。很好很强大。。。
此帖出自电子竞赛论坛
此帖出自电子竞赛论坛
电源解决方案和技术 | DigiKey 应用探索站
