3030|0
265
Altera参考设计-10Gbps Ethernet Loopback Reference Design [复制链接]
The Altera® Stratix® IIGX 10 Gigabit Ethernet (10GbE) loopback reference design provides a sample design that demonstrates wire-speed operation of the 10GbE reference design described in AN516:10-Gbps Ethernet Reference Design. The loopback reference design is an SOPC Builder system that includes two instances of the custom 10GbE component from the earlier reference design and a 10 Gigabit Attachment Unit Interface (XAUI) transceiver for each. This design provides a general platform on which you can control, test, and monitor 10GbE operations.
an561.pdf
548.54 KB, 下载次数: 15
此帖出自FPGA/CPLD论坛
