7037|7
559
【藏书阁】开关电源完整的EMI和热设计 [复制链接]
This work presents the modeling and analysis of EMI and thermal performance
for switch power supply by using the CAD tools. The methodology and design guidelines
are developed.
By using a boost PFC circuit as an example, an equivalent circuit model is built
for EMI noise prediction and analysis. The parasitic elements of circuit layout and
components are extracted analytically or by using CAD tools. Based on the model, circuit
layout and magnetic component design are modified to minimize circuit EMI. EMI filter
can be designed at an early stage without prototype implementation.
In the second part,  thermal analyses are conducted for the circuit  by using the
software  Flotherm,  which includes the mechanism of conduction, convection and
radiation. Thermal models are built for  the components. Thermal performance of the
circuit and the temperature profile of components are predicted.  Improved thermal
management and winding arrangement are investigated to reduce temperature.
In the third part, several circuit layouts and inductor design examples are checked
from both the EMI and thermal point of view. Insightful information is obtained.
开关电源完整的EMI和热设计 128页 1.5M 英.pdf
1.55 MB, 下载次数: 651
此帖出自电源技术论坛
感谢楼主 好好学习  详情 回复 发表于 2012-11-20 20:31
51
全英文,阅读难度很大啊~
此帖出自电源技术论坛
1180
无奈 英文不好
此帖出自电源技术论坛
181
谢谢楼主的慷慨,楼主辛苦了
此帖出自电源技术论坛
32
谢谢!!!!!!!!!
此帖出自电源技术论坛
90
学好英语很重要啊···
此帖出自电源技术论坛
要好好学习
此帖出自电源技术论坛
84
感谢楼主 好好学习
此帖出自电源技术论坛
