3451|0
280
XL2000步进电机完整版C程序(带正反转与加减速) [复制链接]
#include        //51芯片管脚定义头文件
#include          //内部包含延时函数 _nop_();
#define uchar unsigned char
#define uint  unsigned int
uchar code FFW[8]={0xf1,0xf3,0xf2,0xf6,0xf4,0xfc,0xf8,0xf9};
uchar code REV[8]={0xf9,0xf8,0xfc,0xf4,0xf6,0xf2,0xf3,0xf1};
unsigned int speed=5;
sbit  K1   = P2^0;       //正转
sbit  K2   = P2^1;       //反转
sbit  K3   = P2^2;       // +
sbit  K4   = P2^3;       // -
sbit  K5   = P2^4;         // 停止
sbit  BEEP = P3^3;       //蜂鸣器
/* 延时t毫秒
/* 11.0592MHz时钟,延时约1ms
//char code SST516[3] _at_ 0x003b;
void delay(uint t)
   uint k;
   while(t--)
     for(k=0; k<125; k++)
void delayB(uchar x)    //x*0.14MS
   uchar i;
   while(x--)
     for (i=0; i<100; i++)
void beep()
   uchar i;
   for (i=0;i<100;i++)
     delayB(4);
     BEEP=!BEEP;                 //BEEP取反
     BEEP=1;                    //关闭蜂鸣器
/*步进电机正转
void  motor_ffw()
   uchar i;
   uint  j;
   for (j=0; j<12; j++)         //转1*n圈
            if(K5==0)
        {break;}                //退出此循环程序
      for (i=0; i<8; i++)       //一个周期转30度
          P1 = FFW;          //取数据
          delay(speed);            //调节转速
/*步进电机反转
void  motor_rev()
     uchar i;
         uint  j;
         for (j=0; j<12; j++)       //转1×n圈
            if(K5==0)
         {break;}               //退出此循环程序
          P1 = REV;          //取数据
*  主程序
main()
      uchar r,N=100;               //N 步进电机运转圈数
   while(1)
      if(K1==0)
        beep();
        while(N==100)
                   motor_ffw();           //电机正转
                   if(K5==0)
                  {beep();break;}       //退出此循环程序
                if(K3==0)                        //加速开关
                     unsigned int dou;
                     for(dou=0;dou<20;dou++)
                         speed--;               //加速
                         if(speed==0)
                         { break;}
                             speed=2;
                    if(K4==0)            //减速开关
                        speed++;                //减速
          else if(K2==0)
            beep();
           while(N==100)
               motor_rev();       //电机反转
                   if(K5==0)
            if(K3==0)                           //加速开关
                   {unsigned int dd;
                   for(dd=0;dd<20;dd++)
                   speed--;
                   if(speed==0)
                   {break;}
                   speed=2;
                   if(K4==0)
                   speed++;  //减速
          else
                 P1 = 0xf0;
此帖出自单片机论坛
