5960|8
3416
【GD32F350 LogicKids】基本外设驱动 [复制链接]
撸完PCB后
花了几天时间,调试了一下基本的片上外设
1、GPIO
输出:
  1. #define MCU_LED_PORT GPIOC
  2. #define USR_LED_PORT GPIOA
  3. #define MCU_LED_PIN GPIO_PIN_13
  4. #define USR_LED_PIN GPIO_PIN_15
  5. #define MCU_LED_RCU RCU_GPIOC
  6. #define USR_LED_RCU RCU_GPIOA
  7. #define USR_LED_ON GPIO_BC(USR_LED_PORT) = USR_LED_PIN
  8. #define USR_LED_OFF GPIO_BOP(USR_LED_PORT) = USR_LED_PIN
  9. #define USR_LED_TG GPIO_TG(USR_LED_PORT) = USR_LED_PIN
  10. #define MCU_LED_ON GPIO_BC(MCU_LED_PORT) = MCU_LED_PIN
  11. #define MCU_LED_OFF GPIO_BOP(MCU_LED_PORT) = MCU_LED_PIN
  12. #define MCU_LED_TG GPIO_TG(MCU_LED_PORT) = MCU_LED_PIN
  13. /* enable the led clock */
  14. rcu_periph_clock_enable(MCU_LED_RCU);
  15. rcu_periph_clock_enable(USR_LED_RCU);
  16. /* configure mcu_led GPIO port */
  17. gpio_mode_set(MCU_LED_PORT, GPIO_MODE_OUTPUT, GPIO_PUPD_NONE, MCU_LED_PIN);
  18. gpio_output_options_set(MCU_LED_PORT, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, MCU_LED_PIN);
  19. GPIO_BOP(MCU_LED_PORT) = MCU_LED_PIN;
  20. /* configure user_led GPIO port */
  21. gpio_mode_set(USR_LED_PORT, GPIO_MODE_OUTPUT, GPIO_PUPD_NONE, USR_LED_PIN);
  22. gpio_output_options_set(USR_LED_PORT, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, USR_LED_PIN);
  23. GPIO_BOP(USR_LED_PORT) = USR_LED_PIN; //拉高
  24. GPIO_BC(USR_LED_PORT) = USR_LED_PIN;//拉低
复制代码
输入:
  1. #define SYS_FACTORYRESET_PORT GPIOB
  2. #define SYS_WA_SEL_PORT GPIOA
  3. #define SYS_FACTORYRESET_PIN GPIO_PIN_9
  4. #define SYS_WA_SEL_PIN GPIO_PIN_0
  5. #define SYS_FACTORYRESET_RCU RCU_GPIOB
  6. #define SYS_WA_SEL_RCU RCU_GPIOA
  7. rcu_periph_clock_enable(SYS_FACTORYRESET_RCU);
  8. rcu_periph_clock_enable(SYS_WA_SEL_RCU);
  9. gpio_mode_set(SYS_FACTORYRESET_PORT, GPIO_MODE_INPUT, GPIO_PUPD_NONE, SYS_FACTORYRESET_PIN);
  10. gpio_mode_set(SYS_WA_SEL_PORT, GPIO_MODE_INPUT, GPIO_PUPD_NONE, SYS_WA_SEL_PIN);
复制代码
然后gpio_input_bit_get(SYS_FACTORYRESET_PORT, SYS_FACTORYRESET_PIN);
就能读pin的电平鸟
基本上比较好理解
时钟—端口—模式,很常规的配置过程
比较好的是,官方demo中,每句关键代码、每个函数都会有对应的注释
虽然是国际接轨文
也算是比较贴心了
2、usart
  1. /* enable COM GPIO clock */
  2. rcu_periph_clock_enable(RCU_GPIOA);
  3. /* enable USART clock */
  4. rcu_periph_clock_enable(RCU_USART0);
  5. /* connect port to USARTx_Tx */
  6. gpio_af_set(GPIOA, GPIO_AF_1, GPIO_PIN_9);
  7. /* connect port to USARTx_Rx */
  8. gpio_af_set(GPIOA, GPIO_AF_1, GPIO_PIN_10);
  9. /* configure USART Tx as alternate function push-pull */
  10. gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_9);
  11. gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_10MHZ, GPIO_PIN_10);
  12. /* configure USART Rx as alternate function push-pull */
  13. gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_10);
  14. gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_10MHZ, GPIO_PIN_10);
  15. /* USART configure */
  16. usart_deinit(USART0);
  17. usart_baudrate_set(USART0, 115200U);
  18. usart_receive_config(USART0, USART_RECEIVE_ENABLE);
  19. usart_transmit_config(USART0, USART_TRANSMIT_ENABLE);
  20. usart_enable(USART0);
复制代码
没有采用填充结构体的方式
而是很简单粗暴地直接通过调用各种函数来配置
也是时钟—端口—复用功能这样的配置套路
在实际使用中,没有出现发送时,类似STM32首个字符丢失的问题
估计GD对Usart外设逻辑有一定的优化
发送和接受分别是
  1. usart_data_transmit(uint32_t usart_periph, uint32_t data)
  2. usart_data_receive(uint32_t usart_periph)
复制代码
如果要发送字符串,就得需要手写一个发送函数了
这里直接重定向,使用printf
  1. /* retarget the C library debug function to the USART */
  2. int fputc(int ch, FILE *f)
  3. {
  4. usart_data_transmit(USART0, (uint8_t)ch);
  5. while(RESET == usart_flag_get(USART0, USART_FLAG_TBE));
  6. return ch;
  7. }
复制代码
3、SPI
GD32F350CBT6支持2路SPI
分别是SPI0和SPI1
  1. rcu_periph_clock_enable(RCU_GPIOA);
  2. rcu_periph_clock_enable(RCU_SPI0);
  3. gpio_af_set(GPIOA, GPIO_AF_0, GPIO_PIN_5 | GPIO_PIN_6 | GPIO_PIN_7);
  4. gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_5 | GPIO_PIN_6 | GPIO_PIN_7);
  5. /* SPI0 parameter config */
  6. spi_init_struct.trans_mode = SPI_TRANSMODE_FULLDUPLEX;
  7. spi_init_struct.device_mode = SPI_MASTER;
  8. spi_init_struct.frame_size = SPI_FRAMESIZE_8BIT;
  9. spi_init_struct.clock_polarity_phase = SPI_CK_PL_HIGH_PH_2EDGE;
  10. spi_init_struct.nss = SPI_NSS_SOFT;
  11. spi_init_struct.prescale = SPI_PSC_8;
  12. spi_init_struct.endian = SPI_ENDIAN_MSB;
  13. spi_init(spi_periph, &spi_init_struct);
  14. spi_enable(spi_periph);
复制代码
呃,开始填充结构体了
其中SPI1是可以支持QSPI
并且官方外设库中也放出了相关的配置代码
B10和B11可以用作IO2和IO3
  1. gpio_af_set(GPIOB, GPIO_AF_6, GPIO_PIN_10 | GPIO_PIN_11);
  2. qspi_io23_output_enable(SPI1);
  3. qspi_read_enable(SPI1);
  4. qspi_write_enable(SPI1);
  5. qspi_enable(SPI1);
复制代码
但是楼主配置后并没有成功
似乎和板载的GD25Q16有关
貌似需要对其进行配置后再进行QSPI的通信
相对比较麻烦
度娘了一下,很多网友反馈QSPI的实际性能受到FLASH性能的影响
读写速度提高有限
最后还是在使用普通的三线SPI
发送一字节
  1. uint8_t SPI_SendByte(uint32_t spi_periph, uint8_t byte)
  2. {
  3. /* Loop while DR register in not emplty */
  4. while (spi_i2s_flag_get(spi_periph, SPI_FLAG_TBE) == RESET);
  5. /* Send byte through the SPI1 peripheral */
  6. spi_i2s_data_transmit(spi_periph, byte);
  7. /* Wait to receive a byte */
  8. while (spi_i2s_flag_get(spi_periph, SPI_FLAG_RBNE) == RESET);
  9. /* Return the byte read from the SPI bus */
  10. return spi_i2s_data_receive(spi_periph);
  11. }
复制代码
接收一字节
  1. #define Dummy_Byte 0xFF
  2. uint8_t SPI_ReadByte(uint32_t spi_periph)
  3. {
  4. return (SPI_SendByte(spi_periph, Dummy_Byte));
  5. }
复制代码
4、IIC
有坑
特别是多字节连续读取的时候
官方文档给出了A、B两种读取方式
GD32F350的IIC在每次接收一个字节后
都会硬件产生一个ACK信号
所以在接收多个字节的时候要记得把ACK信号给Disable掉
配置代码
  1. rcu_periph_clock_enable(RCU_GPIOB);
  2. rcu_periph_clock_enable(RCU_I2C0);
  3. gpio_af_set(GPIOB, GPIO_AF_1, GPIO_PIN_6);
  4. gpio_af_set(GPIOB, GPIO_AF_1, GPIO_PIN_7);
  5. gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_PULLUP,GPIO_PIN_6);
  6. gpio_output_options_set(GPIOB, GPIO_OTYPE_OD, GPIO_OSPEED_50MHZ,GPIO_PIN_6);
  7. gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_PULLUP,GPIO_PIN_7);
  8. gpio_output_options_set(GPIOB, GPIO_OTYPE_OD, GPIO_OSPEED_50MHZ,GPIO_PIN_7);
  9. i2c_clock_config(I2C0, 400000, I2C_DTCY_2);
  10. i2c_mode_addr_config(I2C0, I2C_I2CMODE_ENABLE, I2C_ADDFORMAT_7BITS, I2C0_OWN_ADDRESS7);
  11. i2c_enable(i2c_periph);
  12. i2c_ack_config(i2c_periph, I2C_ACK_ENABLE);
复制代码
发送一个字节
  1. void IIC_SendByte(uint32_t i2c_periph, uint32_t slave_addr, uint32_t sub_addr, uint8_t data)
  2. {
  3. while(i2c_flag_get(i2c_periph, I2C_FLAG_I2CBSY));
  4. i2c_start_on_bus(i2c_periph);
  5. while(!i2c_flag_get(i2c_periph, I2C_FLAG_SBSEND));
  6. i2c_master_addressing(i2c_periph, slave_addr, I2C_TRANSMITTER);
  7. while(!i2c_flag_get(i2c_periph, I2C_FLAG_ADDSEND));
  8. i2c_flag_clear(i2c_periph, I2C_FLAG_ADDSEND);
  9. while(!i2c_flag_get(i2c_periph, I2C_FLAG_TBE));
  10. i2c_data_transmit(i2c_periph, sub_addr);
  11. while(!i2c_flag_get(i2c_periph, I2C_FLAG_BTC));
  12. i2c_data_transmit(i2c_periph, data);
  13. while(!i2c_flag_get(i2c_periph, I2C_FLAG_BTC));
  14. i2c_stop_on_bus(i2c_periph);
  15. while(I2C_CTL0(i2c_periph)&0x0200);
  16. }
复制代码
接收一个字节
  1. uint8_t IIC_ReadByte(uint32_t i2c_periph, uint32_t slave_addr, uint32_t sub_addr)
  2. {
  3. uint8_t i2c_receiver;
  4. while(i2c_flag_get(i2c_periph, I2C_FLAG_I2CBSY));
  5. i2c_start_on_bus(i2c_periph);
  6. while(!i2c_flag_get(i2c_periph, I2C_FLAG_SBSEND));
  7. i2c_master_addressing(i2c_periph, slave_addr, I2C_TRANSMITTER);
  8. while(!i2c_flag_get(i2c_periph, I2C_FLAG_ADDSEND));
  9. i2c_flag_clear(i2c_periph, I2C_FLAG_ADDSEND);
  12. i2c_start_on_bus(i2c_periph);
  13. while(!i2c_flag_get(i2c_periph, I2C_FLAG_SBSEND));
  14. i2c_master_addressing(i2c_periph, slave_addr, I2C_RECEIVER);
  15. while(!i2c_flag_get(i2c_periph, I2C_FLAG_ADDSEND));
  16. i2c_flag_clear(i2c_periph, I2C_FLAG_ADDSEND);
  17. i2c_ack_config(i2c_periph, I2C_ACK_DISABLE);
  18. while(!i2c_flag_get(i2c_periph, I2C_FLAG_RBNE));
  19. i2c_receiver = i2c_data_receive(i2c_periph);
  20. i2c_stop_on_bus(i2c_periph);
  21. while(I2C_CTL0(i2c_periph)&0x0200);
  22. i2c_ack_config(i2c_periph, I2C_ACK_ENABLE);
  23. return i2c_receiver;
  24. }
复制代码
发送一堆字节
  1. void IIC_SendBuffer(uint32_t i2c_periph, uint32_t slave_addr, uint32_t sub_addr, uint8_t *buffer, uint16_t send_nums)
  2. {
  3. uint16_t i=0;
  10. while(!i2c_flag_get(i2c_periph, I2C_FLAG_TBE));
  11. i2c_data_transmit(i2c_periph, sub_addr);
  12. while(!i2c_flag_get(i2c_periph, I2C_FLAG_BTC));
  13. for(i=0; i<send_nums; i++)
  14. {
  15. i2c_data_transmit(i2c_periph, buffer[i]);
  16. while(!i2c_flag_get(i2c_periph, I2C_FLAG_BTC));
  17. }
  18. i2c_stop_on_bus(i2c_periph);
  19. while(I2C_CTL0(i2c_periph)&0x0200);
  20. }
复制代码
接收一堆字节
  1. void IIC_ReadBuffer(uint32_t i2c_periph, uint32_t slave_addr, uint32_t sub_addr, uint8_t *buffer, uint16_t read_nums)
  2. {
  3. uint16_t cnt = 0;
  17. if(read_nums > 2)
  18. {
  19. for(cnt = 0; cnt < read_nums; cnt++)
  20. {
  21. if((read_nums > 1) && (cnt == read_nums-1))
  22. {
  23. while(!i2c_flag_get(I2C0, I2C_FLAG_BTC));
  24. i2c_ack_config(I2C0, I2C_ACK_DISABLE);
  25. }
  26. while(!i2c_flag_get(i2c_periph, I2C_FLAG_RBNE));
  27. buffer[cnt] = i2c_data_receive(i2c_periph);
  28. }
  29. }
  30. else
  31. {
  32. for(cnt = 0; cnt < read_nums; cnt++)
  33. {
  34. while(!i2c_flag_get(i2c_periph, I2C_FLAG_RBNE));
  35. buffer[cnt] = i2c_data_receive(i2c_periph);
  36. i2c_ack_config(i2c_periph, I2C_ACK_DISABLE);
  37. }
  38. }
  39. i2c_stop_on_bus(i2c_periph);
  40. while(I2C_CTL0(i2c_periph)&0x0200);
  41. i2c_ack_config(i2c_periph, I2C_ACK_ENABLE);
  42. }
复制代码
5、PWM
抄库
  1. void PWM_INIT(void)
  2. {
  3. timer_oc_parameter_struct timer_ocintpara;
  4. timer_parameter_struct timer_initpara;
  5. /*Configure PB3 PB4 PB5(TIMER1-CH1 TIMER2-CH0 TIMER2-CH1) as alternate function*/
  6. gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_3);
  7. gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_3);
  8. gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_4);
  9. gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_4);
  10. gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_5);
  11. gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_5);
  12. gpio_af_set(GPIOB, GPIO_AF_2, GPIO_PIN_3);
  13. gpio_af_set(GPIOB, GPIO_AF_1, GPIO_PIN_4);
  14. gpio_af_set(GPIOB, GPIO_AF_1, GPIO_PIN_5);
  15. rcu_periph_clock_enable(RCU_TIMER1);
  16. rcu_periph_clock_enable(RCU_TIMER2);
  17. timer_deinit(TIMER1);
  18. timer_deinit(TIMER2);
  19. /* TIMER1 configuration */
  20. timer_initpara.prescaler = 107;
  21. timer_initpara.alignedmode = TIMER_COUNTER_EDGE;
  22. timer_initpara.counterdirection = TIMER_COUNTER_UP;
  23. timer_initpara.period = 15999;
  24. timer_initpara.clockdivision = TIMER_CKDIV_DIV1;
  25. timer_initpara.repetitioncounter = 0;
  26. timer_init(TIMER1,&timer_initpara);
  27. /* TIMER2 configuration */
  28. timer_initpara.prescaler = 107;
  29. timer_initpara.alignedmode = TIMER_COUNTER_EDGE;
  30. timer_initpara.counterdirection = TIMER_COUNTER_UP;
  31. timer_initpara.period = 15999;
  32. timer_initpara.clockdivision = TIMER_CKDIV_DIV1;
  33. timer_initpara.repetitioncounter = 0;
  34. timer_init(TIMER2,&timer_initpara);
  35. /*configuration in PWM mode0 */
  36. timer_ocintpara.ocpolarity = TIMER_OC_POLARITY_HIGH;
  37. timer_ocintpara.outputstate = TIMER_CCX_ENABLE;
  38. timer_channel_output_pulse_value_config(TIMER1,TIMER_CH_1,15999);
  39. timer_channel_output_mode_config(TIMER1,TIMER_CH_1,TIMER_OC_MODE_PWM0);
  40. timer_channel_output_shadow_config(TIMER1,TIMER_CH_1,TIMER_OC_SHADOW_DISABLE);
  41. timer_channel_output_pulse_value_config(TIMER2,TIMER_CH_0,15999);
  42. timer_channel_output_mode_config(TIMER2,TIMER_CH_0,TIMER_OC_MODE_PWM0);
  43. timer_channel_output_shadow_config(TIMER2,TIMER_CH_0,TIMER_OC_SHADOW_DISABLE);
  44. timer_channel_output_pulse_value_config(TIMER2,TIMER_CH_1,15999);
  45. timer_channel_output_mode_config(TIMER2,TIMER_CH_1,TIMER_OC_MODE_PWM0);
  46. timer_channel_output_shadow_config(TIMER2,TIMER_CH_1,TIMER_OC_SHADOW_DISABLE);
  47. /* auto-reload preload enable */
  48. timer_auto_reload_shadow_enable(TIMER1);
  49. timer_auto_reload_shadow_enable(TIMER2);
  50. /* auto-reload preload enable */
  51. timer_enable(TIMER1);
  52. timer_enable(TIMER2);
  53. timer_channel_output_config(TIMER1,TIMER_CH_1,&timer_ocintpara);
  54. timer_channel_output_config(TIMER2,TIMER_CH_0,&timer_ocintpara);
  55. timer_channel_output_config(TIMER2,TIMER_CH_1,&timer_ocintpara);
  56. }
复制代码
修改了几个端口和TimerX
重载timer_channel_output_pulse_value_config 中15999的值就能调整占空比了
上个测试视频
需要使用的外设基本上就是这么多了
先到这
此帖出自GD32 MCU论坛
非常详细,谢谢分享   详情 回复 发表于 2022-12-3 11:50
点赞 关注(3)
So TM what......?
3416
我在长沙发现了楼主
顺道消灭没有人回复
此帖出自GD32 MCU论坛
So TM what......?
639
楼主写的非常好留个标记,后边就可以做个参考少入坑
此帖出自GD32 MCU论坛
嗯,收藏了
此帖出自GD32 MCU论坛
顶一个
此帖出自GD32 MCU论坛
6107
赞一个
此帖出自GD32 MCU论坛
932
花了几天时间调串口,还是无法接收电脑的信息,楼主的资料正好可以参考,谢谢!
此帖出自GD32 MCU论坛
很详细的资料,Thank you!
此帖出自GD32 MCU论坛
非常详细,谢谢分享
此帖出自GD32 MCU论坛
