3456|4
257
请教STEVAL-IDB007V1用BLE_SensorDemo修改的读ADC没成功的问题 [复制链接]
刚有在keil 下用BLE_SensorDemo 加入读ADC的功能,但是读出的值为0;
app用iOS :lightblue  android:nRF Connect
程序是在BLE_SensorDemo基础上,参看工程  Project\BlueNRG1_Periph_Examples\ADC\Polling   里的ADC的使用;
1 在文件BlueNRG1_conf.h 里加入
   #include "BlueNRG1_adc.h"    // RK ADD
2  定义函数与数据
  1. ADC_InitType xADC_InitType;
  2. void ADC_Configuration(void)
  3. {
  4.   SysCtrl_PeripheralClockCmd(CLOCK_PERIPH_ADC, ENABLE);
  5.
  6.   /* Configure ADC */
  7.   /* ADC_Input_AdcPin1 == ADC1 */
  8.   /* ADC_Input_AdcPin2 == ADC2 */
  9.   /* ADC_Input_AdcPin12 == ADC1 - ADC2 */
  10.   xADC_InitType.ADC_OSR = ADC_OSR_200;
  11.   //ADC_Input_BattSensor; //ADC_Input_TempSensor;// ADC_Input_AdcPin1 // ADC_Input_AdcPin12 // ADC_Input_AdcPin2
  12.   xADC_InitType.ADC_Input = ADC_Input_AdcPin12; //ADC_Input_AdcPin12;
  13.   xADC_InitType.ADC_ConversionMode = ADC_ConversionMode_Single;
  14.   xADC_InitType.ADC_ReferenceVoltage = ADC_ReferenceVoltage_0V6;
  15.   xADC_InitType.ADC_Attenuation = ADC_Attenuation_9dB54;
  16.
  17.   ADC_Init(&xADC_InitType);
  18.
  19.   /* Enable auto offset correction */
  20.   ADC_Calibration(ENABLE);
  21.   ADC_AutoOffsetUpdate(ENABLE);
  22. }
复制代码
3  在main()函数中调用ADC相关的设置函数
  1.   /* ADC Initialization */
  2.   ADC_Configuration();
  3.   /* Start new conversion */
  4.   ADC_Cmd(ENABLE);
复制代码
4 在 main()中的while(1)里读取ADC值;
if( ADC_GetFlagStatus(ADC_FLAG_EOC)) {
      /* Read converted data */
      adc_value = ADC_GetConvertedData(xADC_InitType.ADC_Input, xADC_InitType.ADC_ReferenceVoltage);
            //SdkDelayMs(100);
            adc_value = adc_value/1000;
            Clock_Wait(100);
            //adc_value = 0x2345;  //用这个直接可传到App上;
            ADC_Cmd(ENABLE);
5 将adc_value的值传到App里,这里,我将3D sensor 的传数据的函数修改为传adc_value的值,再用App去读值;
  1. extern         float adc_value;
  2. tBleStatus Acc_Update(AxesRaw_t *data)
  3. {
  4.   uint8_t buff[6];
  5.
  6.   tBleStatus ret;
  7.   HOST_TO_LE_16(buff,-data->AXIS_Y);
  8.   HOST_TO_LE_16(buff+2,data->AXIS_X);
  9.   HOST_TO_LE_16(buff+4,-data->AXIS_Z);
  10.
  11.         //adc_value
  12.         buff[0]= 0xfe;
  13.         buff[1]= 0xff;
  14.         buff[2]= 0xff;
  15.         buff[3]= 0xfe;
  16.         buff[4]= adc_value/256;
  17.         buff[5]= adc_value;
  18.   ret = aci_gatt_update_char_value(accServHandle, accCharHandle, 0, 6, buff);
  19.   if (ret != BLE_STATUS_SUCCESS){
  20.     PRINTF("Error while updating Acceleration characteristic: 0x%02X\n",ret) ;
  21.     return BLE_STATUS_ERROR ;
  22.   }
  23.   return BLE_STATUS_SUCCESS;
  24.
  25. }
复制代码
6  结果显示,ADC的值一直为0,现在还没有找出问题所在,来网上请教下;
代码是卡哪里了还是ADC_GetFlagStatus(ADC_FLAG_EOC)一直返回0?  详情 回复 发表于 2018-1-27 18:30
9798
24
1、确定AdcPin12有电压输入
2、可以先下一个ADC\Polling试试看能否读到
3、然后在你修改的BLE_SensorDemo代码里用调试模式下看adc_value 的值看是否正确
4、如果ADC\Polling正常BLE_SensorDemo不正常再对比一下2个例程在ADC配置和读取方面的区别
刚有加入UART DEBUG log, 发现如果只在读ADC打印下ADC值,只能看到打印一次;代码如下, [mw_shl_code=c,true]if( ADC_GetFlagStatus(ADC_FLAG_EOC)) { /* Read converted data */ adc_value =  详情 回复 发表于 2018-1-27 17:29
个人签名虾扯蛋,蛋扯虾,虾扯蛋扯虾
257
littleshrimp 发表于 2018-1-26 19:41
1、确定AdcPin12有电压输入
3、然后在你修改的BLE_SensorDemo ...
刚有加入UART DEBUG log,
  1. if( ADC_GetFlagStatus(ADC_FLAG_EOC))
  2.                 {
  3.       /* Read converted data */
  4.       adc_value = ADC_GetConvertedData(xADC_InitType.ADC_Input, xADC_InitType.ADC_ReferenceVoltage);
  5.                         PRINTF("ADC value: %.0f mV\r\n", adc_value*1000.0); //uart log
  6.                         adc_value = adc_value*1000.0;
  7.                         Clock_Wait(100);
  8.                         ADC_Cmd(ENABLE);
  9.                         timeRun++;
  10.                 }
复制代码
但是如果再在主循环里加入一条打印信息,则可以一直跑,
  1. /* Application Tick */
  2.     APP_Tick();
  3.     PRINTF("BlueNRG-1 BLE Sensor Demo APP_Tick() TIME=%d \n",timeRun);
复制代码
目前,将就着用这个测试了下,APP可以读到数据,
也用电容测试了下,断开STEVAL-IDB007V1开发板的JP1和JP2路线,将超级电容(此电容由论坛统一提供)负极接在上JP1的3脚,正极通过JP1的1脚充电至3.3V,再将正极切换到JP2的2脚;
初步测试了下,耗电很快,可能没有关LED,还有其它IO没配置;后面再优化吧
9798
24
viphotman 发表于 2018-1-27 17:29
刚有加入UART DEBUG log,
[mw_shl_code ...
当时的测试时复位后只打印一次ADC的值,像是ADC_GetFlagStatus(ADC_FLAG_EOC)一直返回0,但是现在我修改了一些代码,没有问题了,具体原因还在查找到;  详情 回复 发表于 2018-1-29 10:32
个人签名虾扯蛋,蛋扯虾,虾扯蛋扯虾
257
