2098|0
2015
mps430与rc522模块 [复制链接]
#include "msp430x14x.h"
#include "PIN_DEF.H"
#include "RC522.H"
#include "UART0_Func.c"
#include "ctype.h"
#include "BoardConfig.h"
unsigned char UID[5],Temp[4]                                       ;
unsigned char RF_Buffer[18]                                        ;
unsigned char Password_Buffer[6]={0xFF,0xFF,0xFF,0xFF,0xFF,0xFF}   ; // Mifare One 缺省密码
char          MBRX[30]                                             ;
char          MBKeyTP[30]                                          ;
char          Event                                                ;
unsigned char DISP_MODE,i                                            ; // 编辑控件显示模式
unsigned char des_on       = 0                                     ; // DES加密标志
void Key_TP_Task(void)                                             ;
//                 初始化主时钟: MCLK = XT1×(FLL_FACTOR+1)                  //
void Init_CLK(void)
  unsigned int qq;
  WDTCTL     = WDTPW + WDTHOLD                                     ; // 关看门狗
  BCSCTL1 &= ~XT2OFF;           //打开XT2高速晶体振荡器
  do
    IFG1 &= ~OFIFG;           //Clear oscFault flag清除振荡器失效标志
    for(qq=0xff;qq>0;qq--);
  }while((IFG1&OFIFG));       //oscFault flag still set
  BCSCTL2 |= SELM_2;          //MCLK=XT2
  //BCSCTL2 |= DIVM_0;        //控制MCLK不分频,默认
  BCSCTL2 |= SELS;            //SMCLK=XT2
  //BCSCTL2 |= DIVS_0;        //控制SMCLK不分频,默认
void Delay(unsigned int time)
  unsigned int i,k                             ;
  for(i=0;i<255;i++)
    for(k=0;k
      _NOP()                                   ;
void Auto_Reader(void)
  while(1)
    if(PcdRequest(0x52,Temp)==MI_OK)
      if(Temp[0]==0x04&&Temp[1]==0x00)
          PutString("MFOne-S50");
        else if(Temp[0]==0x02&&Temp[1]==0x00)
          PutString("MFOne-S70");
        else if(Temp[0]==0x44&&Temp[1]==0x00)
          PutString("MF-UltraLight");
        else if(Temp[0]==0x08&&Temp[1]==0x00)
          PutString("MF-Pro");
        else if(Temp[0]==0x44&&Temp[1]==0x03)
          PutString("MF Desire");
        else
          PutString("Unknown");
      if(PcdAnticoll(UID)==MI_OK)
        PutString0("Card Id is:");
        tochar(UID[0]);
        tochar(UID[1]);
        tochar(UID[2]);
        tochar(UID[3]);
        while (!(IFG1 & UTXIFG0));
        TXBUF0 = '\n';                              //发送换行指令
        RED_LED_ON                                            ;
        Delay(200)                                           ;
        RED_LED_OFF                                           ;
        Delay(200)                                           ;
  else GRE_LED_OFF                                            ;
void Find_Card(void)
        else
        PutString("SUCCESS!");
    else PutString("Faile!");
void Init_Port(void)
  P4DIR   =   RF_LPCTL + RF_SS   + RF_SCLK  + RF_DATA_OUT                     ;
  P2DIR |= BIT0+RF_LPCTL + RF_SS   + RF_SCLK  + RF_DATA_OUT;
  P1DIR   =   RF_LPCTL + RF_SS   + RF_SCLK  + RF_DATA_OUT                     ;
函数名称:HandleConfigMenu
功    能:处理PC的配置函数
参    数:inputvalue--接收到的来自PC机的字符
返回值  :无
void HandleConfigMenu(uchar inputvalue)
    switch(toupper(inputvalue))
    case 'A':
              Auto_Reader();
              break;
    case 'F':
              Find_Card();
              break;
    default:
              DisplayConfigMenu();
void main( void )
  BoardConfig(0xf0);
  Init_Port();
  InitUART();
  _EINT()                                            ;
  PcdReset();//复位RC522
  PcdAntennaOn();//开启天线发射
  while(1)
        Send1Char('>');
        Send1Char('\n');
        i=Get1Char();
        HandleConfigMenu(i);
