2165|0
6802
MSP430单片机和GPRS模块MC52i的应用 [复制链接]
1.先看连接图示
2     程序例程
2.    #include
3.    #include “string.h”
4.
5.    typedefunsigned short int    u16
6.    typedef unsigned char       u8
7.    typedef signed short int      s16
8.    typedef signed char         s8
9.
10.   #define SYS_SUCCESS    0
11.   #define SYS_FAIL          1
12.  //==============================================================
13.   // DTU Pin define
14.   #define DTU_IGT_PORT_DIR           P1DIR
15.   #defineDTU_IGT_PORT_OUT     P1OUT
16.   #define DTU_IGT_PIN             BIT6
17.
18.   #define DTU_RTS_PORT_DIR            P1DIR
19.   #define DTU_RTS_PORT_OUT    P1OUT
20.   #define DTU_RTS_PIN             BIT2
21.
22.   #define DTU_CTS_PORT_DIR            P1DIR
23.   #define DTU_CTS_PORT_IN       P1IN
24.   #define DTU_CTS_PIN             BIT4
25.
26.   #define DTU_IGT_FIRE      DTU_IGT_PORT_DIR  |= DTU_IGT_PIN;\
27.                              DTU_IGT_PORT_OUT  |= DTU_IGT_PIN
28.   #define DTU_IGT_SHUT     DTU_IGT_PORT_DIR  |= DTU_IGT_PIN;\
29.                              DTU_IGT_PORT_OUT  &= ~DTU_IGT_PIN
30.   #define DTU_RTS_HIGH     DTU_RTS_PORT_DIR |= DTU_RTS_PIN;\
31.                              DTU_RTS_PORT_OUT |= DTU_RTS_PIN
32.   #define DTU_RTS_LOW      DTU_RTS_PORT_DIR |=DTU_RTS_PIN;\
33.                              DTU_RTS_PORT_OUT &=~DTU_RTS_PIN
34.   #define DTU_CTS_FLAG    DTU_CTS_PORT_DIR &= ~ DTU_CTS_PIN ;
35.   #DTU_CTS                 (DTU_CTS_PORT_IN& DTU_CTS_PIN)
36.
37.   #define DTU_DAT_LEN    100
38.
39.   u8g_rec_buf[DTU_DAT_LEN] ;
40.   u16g_count = 0 ;
41.   u8g_sys_error = SYS_SUCCESS ;
42.
43.   /***********************************************************************************************
44.   ** Function Name :Delay                                                 **
45.   ** Parameter     : uTime                                                 **
46.    ** Return     :
47.    ********************************************************************************************/
48.    void Delay(u16 uTime)
49.    {
50.        u16 i=0;
51.        u16 j=0;
52.        for (i = 0 ; I <1000; i++)
53.        {
54.             for (j = 0; j< uTime; j++);
55.        }
56.    }
57.
58.   /***********************************************************************************************
59.   ** Function Name : InitClock                                               **
60.   ** Parameter     : None                                                 **
61.   ** Return        :                                                       **
62.   ***********************************************************************************************/
63.    void InitClock()
64.    {
65.        u8 i= 0;
66.
67.        BCSCTL1 &=~XT2OFF;
68.        BCSCTL2 |=SELM1+SELS;       // MCLK 8M, SMCLK1M
69.
70.        do
71.        {
72.            IFG1 &=~OFIFG;
73.            for (i = 0; I< 100; i++)
74.            {
75.                _NOP();
76.            }
77.        } while(0 != (IFG1& OFIFG));
78.        IFG1 &= ~OFIFG;
79.    }
80.
81.  /***********************************************************************************************
82.   ** Function Name : InitUart1                                               **
83.   ** Parameter     : None                                                 **
84.   ** Return        :                                                       **
85.   ***********************************************************************************************/
86.   void InitUart1(void)
87.   {
88.       U1CTL |= SWRST;    // Rest UART1
89.       U1CTL |= CHAR;     // 8bit data
90.       U1TCTL |= SSEL1;    // set SMCLK as uart1 clock
91.       UBR01 = 0x8A;          // Baud rate 19200bps
92.       UBR11 = 0x00;
93.
94.       UMCTL1 = 0xDE;
95.       ME2 |= 0x30;
96.       uctl1 &=~SWRST;  //
97.
98.       IE2 |= URXIE1;
99.       P3SEL = 0XC0;   // P3.6 and P3.7 as TXD and RXD
100.              P3DIR = 0x40;
101.          }
102.
103.          ***********************************************************************************************
104.          ** Function Name : UART1_RX_ISR                                        **
105.          ** Parameter     : None                                                  **
106.          ** Return        :                                                      **
107.          **********************************************************************************************/
108.          #pragma vector = UART1RX_VECTOR
109.          __interrupt void UART1_RX_ISR(void)
110.          {
111.              char dat = 0 ;
112.              data = U1RXBUF ;
113.              g_rec_buf[g_count] = data ;
114.              if (g_count > (DTU_DAT_LEN -1))
115.              {
116.                  g_count = 0;
117.              }
118.          }
119.
120.          ***********************************************************************************************
121.          ** Function Name : Uart1SendByte                                         **
122.          ** Parameter     : u8 dat                                                **
123.          ** Return        :                                                      **
124.          **********************************************************************************************/
125.           void Uart1SendByte(u8 dat)
126.           {
127.               while(0 == (IFG2 & UTXIFG1);
128.               U1TXBUF = dat;
129.           }
130.
131.           *********************************************************************************************
132.          ** Function Name : ClearDtuBuf                                            **
133.          ** Parameter     :                                                      **
134.          ** Return        :                                                      **
135.          **********************************************************************************************/
136.           void ClearDtuBuf(void)
137.           {
138.               u8 len = 0;
139.               g_count = 0;
140.
141.               IE2 &= ~URXIE1; // Close receiveinterrupt
142.               for (; len < DTU_DAT_LEN; len++)
143.               {
144.                   g_rec_buf[len] = ‘\0’ ;
145.               }
146.               IE2 |= URXIE1;
147.           }
148.
149.           void SendDat(s8 * strptr)
150.           {
151.               u8 i.j;
152.               j = strlen(strptr);
153.               for (i=0;i
154.               {
155.                   Uart1SendByte((u8)strptr);
156.               }
157.           }
158.           *********************************************************************************************
159.          **  DTUMODULE: Start, Shut, Initialize
160.          **********************************************************************************************/
161.           void StartDtu(void)
162.           {
163.               DTU_IGT_FIRE;
164.               Delay(1);
165.               DTU_IGT_SHUT;
166.               Delay(100);
167.               DTU_IGT_FIRE;
168.           }
169.
170.          void ShutdownDtu(void)
171.           {
172.               Delay(100);
173.               SendDat(“AT^smso\r\n”);
174.               Delay(100);
175.           }
176.
177.          void InitDtu(void)
178.           {
179.               SendDat(“AT\\Q3\r\n”);
180.               Delay(1000);
181.               SendDat(“ATE0\r\n”);
182.               Delay(100);
183.               SendDat(“AT+CMGF=1\r\n”);
184.               Delay(100);
185.               SendDat(“AT+CFUN=7\r\n”);
186.               Delay(100);
187.               SendDat(“AT+CFUN\?\r\n”);
188.               Delay(100);
189.           }
190.
191.          void SendDtuMsg(char *num, char * msg)
192.          {
193.              char instruct[] = “AT+CMGS=\””;
194.              char numinstuct[27];
195.
196.              strcpy(numinstuct, instruct);
197.              strcat(numinstuct, num);
198.              strcat(numinstuct, “\”\r\n”);
199.              SendDat(numinstuct);
200.              SendDat(msg);
201.              Uart1SendByte(0x1A);   // CTRL+Z
202.
203.          }
204.
205.          void main()
206.          {
207.             WDTCTL = WDTPW + WDTHOLD; // close WATCHDOG
208.             InitClock();
209.             InitUart1();
210.             DTU_RTS_LOW ;
211.
212.             StartDtu() ;
213.             _EINT() ;
214.             Delay(2000) ;
215.             InitDtu() ;
216.
217.             SendDat(“AT\r\n“) ;
218.             SendDtuMsg ( ”18615771975”,”Hello world! Just a Test!”);
219.             CloseDtu();
220.
221.             while(1)
222.              {
223.              }
224.          }
225.
