4605|1
5968
基于iperf的Altera SoC千兆网测试 [复制链接]
作者:chenzhufly QQ:36886052
本文的目的是测试一下Embest SoC的千兆网功能和性能,使用常用网络测试工具的Iperf。
Iperf是一个网络性能测试工具。可以测试TCP和UDP带宽质量,可以测量最大TCP带宽,具有多种参数和UDP特性,可以报告带宽,延迟抖动和数据包丢失。Iperf在linux和windows平台均有二进制版本供自由使用。
Iperf was developed by NLANRDAST as a modern alternative for measuring maximum TCP and UDP bandwidth performance. Iperf allows the tuning of various parameters and UDP characteristics. Iperf reports bandwidth, delay jitter, datagram loss.
1、环境搭建
硬件平台:Embest SoC --LarkBoard
软件平台:开发板-基于linux-3.10.31的debian系统,PC机WIN8系统
开发板和PC机直连
开发板IP信息:192.168.1.11
PC机IP信息:192.168.1.7
2、Iperf下载与安装
1) iperf下载地址
Iperf 2.0.5-3 (1421 Kio) - The latest version of Iperf 2(2014). New: Fixed some performance issues with iperf on windows byIuliu Rus (Google)
2) Embest SoC下的Iperf安装
由于自带的的系统是debian系统,所以安装起来就方便多了,不需要进行源码的移植和编译,减轻了很多的工作量。
  1. root@arm:~# apt-get install iperf
    Reading package lists... Done
    Building dependency tree
    Reading state information... Done
    The following NEW packages will be installed:
    iperf
    0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
    Need to get 51.1 kB of archives.
    After this operation, 148 kB of additional disk space will be used.
    Get:1 http://ftp.us.debian.org/debian/ wheezy/main iperf armhf 2.0.5-3 [51.1 kB]
    Fetched 51.1 kB in 1s (33.7 kB/s)
    Selecting previously unselected package iperf.
    (Reading database ... 56671 files and directories currently installed.)
    Unpacking iperf (from .../iperf_2.0.5-3_armhf.deb) ...
    Processing triggers for man-db ...
    Setting up iperf (2.0.5-3) ...
    root@arm:~# iperf
    Usage: iperf [-s|-c host] [options]
    Try `iperf --help' for more information.
复制代码
复制代码
3、相关测试结果:
1)UDP测试,开发板作为服务器,PC机作为客户端
开发板作为服务器,输入:
  1. root@arm:~#iperf -u -s
复制代码
PC机作为客户端:
  1. iperf -u -c 192.168.1.11 -b 1000M -i1 -t10
复制代码
2)UDP测试,开发板作为客户端PC机作为服务器
开发板作为客户端,输入:
  1. root@arm:~#iperf -u -c 192.168.1.7 -b 1000M -i1 -t10
复制代码
PC机作为服务器:
  1. iperf -u -s
复制代码
3)TCP测试,开发板作为服务器,PC机作为客户端
开发板作为服务器,输入:
  1. root@arm:~# iperf -s
复制代码
PC机作为客户端:
  1. iperf -c 192.168.1.11 -b -i1 -t10
复制代码
4)TCP测试,开发板作为客户端PC机作为服务器
开发板作为客户端,输入:
  1. root@arm:~#iperf -c 192.168.1.7 -i1 -t10
复制代码
PC机作为服务器:
  1. iperf -s
复制代码
测试数据汇总:
服务器
客户端
速率
UDP测试
开发板
PC机
394Mbps
PC机
开发板
493 Mbps
TCP测试
开发板
PC机
409 Mbps
PC机
开发板
310 Mbps
4、测试总结
1) Embest SoC自带的debian系统开发环境不完善,头文件之类的都无法安装;值得一提的是这个文件系统应该是从Beaglebone Black的debian系统修改过来的,整个文件系统中还留有BBB的痕迹
2) 网络配置不完善,需要修改/etc/network/interfaces
把iface eth0 inet static 改为 iface eth0 inet dhcp,这样系统启动的时候才可以自动获取IP
3) 经过以上测试,可以看出Altera SoC的千兆网在UDP和TCP下的测试结果还是比较不错的,但测试的环境不够完善,测试结果仅供参考,有兴趣的可以深入的开展相关工作
此帖出自FPGA/CPLD论坛
不错,期待更多分享。  详情 回复 发表于 2015-2-20 20:35
赞赏
查看全部赞赏
个人签名生活就是油盐酱醋再加一点糖,快活就是一天到晚乐呵呵的忙
做一个简单的人,踏实而务实,不沉溺幻想,不庸人自扰
384
不错,期待更多分享。
此帖出自FPGA/CPLD论坛
有奖直播:当AI遇见仿真,会有什么样的电子行业革新之路?
首场直播:Simcenter AI 赋能电子行业研发创新
直播时间:04月15日14:00-14:50
站点相关: 国产芯 安防电子 汽车电子 手机便携 工业控制 家用电子 医疗电子 测试测量 网络通信 物联网 12
