2108|0
142
TIVA C Launchpad周计划——第一周(点亮LED) [复制链接]
收到的板子也是Stellaris LM4F120 Launchpad,发现最新的Energia正好支持这块板子,弄了个小程序,三色LED轮流闪。
感觉用Arduino这样的开发环境方便很多啊,简单,占用空间少
  1. // the setup routine runs once when you press reset:
  2. void setup() {
  3.   // initialize the digital pin as an output.
  4.   pinMode(RED_LED, OUTPUT);
  5.   pinMode(BLUE_LED, OUTPUT);
  6.   pinMode(GREEN_LED, OUTPUT);
  7. }
  8. // the loop routine runs over and over again forever:
  9. void loop() {
  10.   digitalWrite(RED_LED, HIGH);   // turn the LED on (HIGH is the voltage level)
  11.   delay(1000);               // wait for a second
  12.   digitalWrite(RED_LED, LOW);    // turn the LED off by making the voltage LOW
  13.   delay(1000);               // wait for a second
  14.
  15.   digitalWrite(BLUE_LED, HIGH);   // turn the LED on (HIGH is the voltage level)
  16.   delay(1000);               // wait for a second
  17.   digitalWrite(BLUE_LED, LOW);    // turn the LED off by making the voltage LOW
  18.   delay(1000);               // wait for a second
  19.
  20.   digitalWrite(GREEN_LED, HIGH);   // turn the LED on (HIGH is the voltage level)
  21.   delay(1000);               // wait for a second
  22.   digitalWrite(GREEN_LED, LOW);    // turn the LED off by making the voltage LOW
  23.   delay(1000);               // wait for a second
  24. }
复制代码
收集了一些资料,估计大家也都能找到
Stellaris LaunchPad入门讲座.rar (6.64 MB, 下载次数: 75)
[ 本帖最后由 nwcheroes 于 2013-10-25 22:08 编辑 ]
