8605|3
SDHC卡初始化流程,读不到数据。。 [复制链接]
我的51开发板,SPI读写SD卡,在读SD卡扇区数据的时候出现了问题,完全读不到数据,即数据全是0,我的初始化流程是CMD0-->CMD8-->CMD55-->ACMD41;不知道是不是初始化缺少点什么。。网上看到些文章说是还要写CMD2,CMD3,CMD7之类的命令。。求解???
此帖出自单片机论坛
你找找网上有没有现成的,没有的话找这个描 /**   ******************************************************************************   * @file    stm32_eval_sdio_sd.c   * @author  MCD Application Team   * @version V4.5.0   * @date    07-March-2011   * @brief   This file provides a set of functions needed to manage the SDIO SD   *          Card memory mounted on STM32xx-EVAL board (refer to stm32_eval.h   *          to know about the boards supporting this memory).   *            *               *  @verbatim   *   *          ===================================================================   *                                   How to use this driver   *          ===================================================================   *          It implements a high level communication layer for read and write   *          from/to this memory. The needed STM32 hardware resources (SDIO and   *          GPIO) are defined in stm32xx_eval.h file, and the initialization is   *          performed in SD_LowLevel_Init() function declared in stm32xx_eval.c   *          file.   *          You can easily tailor this driver to any other development board,   *          by just adapting the defines for hardware resources and   *          SD_LowLevel_Init() function.   *               *          A - SD Card Initialization and configuration   *          ============================================      *            - To initialize the SD Card, use the SD_Init() function.  It   *              Initializes the SD Card and put it into StandBy State (Ready   *              for data transfer). This function provide the following operations:   *              *              1 - Apply the SD Card initialization process at 400KHz and check   *                  the SD Card type (Standard Capacity or High Capacity). You   *                  can change or adapt this frequency by adjusting the   *                  "SDIO_INIT_CLK_DIV" define inside the stm32xx_eval.h file.   *                  The SD Card frequency (SDIO_CK) is computed as follows:   *                       *                     +---------------------------------------------+      *                     | SDIO_CK = SDIOCLK / (SDIO_INIT_CLK_DIV + 2) |   *                     +---------------------------------------------+     *                             *                  In initialization mode and according to the SD Card standard,   *                  make sure that the SDIO_CK frequency don't exceed 400KHz.           *            *              2 - Get the SD CID and CSD data. All these information are   *                  managed by the SDCardInfo structure. This structure provide   *                  also ready computed SD Card capacity and Block size.      *   *              3 - Configure the SD Card Data transfer frequency. By Default,   *                  the card transfer frequency is set to 24MHz. You can change   *                  or adapt this frequency by adjusting the "SDIO_TRANSFER_CLK_DIV"   *                  define inside the stm32xx_eval.h file.   *                  The SD Card frequency (SDIO_CK) is computed as follows:   *                       *                     +---------------------------------------------+      *                     | SDIO_CK = SDIOCLK / (SDIO_INIT_CLK_DIV + 2) |   *                     +---------------------------------------------+        *                                       *                  In transfer mode and according to the SD Card standard,   *                  make sure that the SDIO_CK frequency don't exceed 25MHz   *                  and 50MHz in High-speed mode switch.   *                  To be able to use a frequency higher than 24MHz, you should   *                  use the SDIO peripheral in bypass mode. Refer to the   *                  corresponding reference manual for more details.   *                       *              4 -  Select the corresponding SD Card according to the address   *                   read with the step 2.   *                                      *              5 -  Configure the SD Card in wide bus mode: 4-bits data.                  *   *          B - SD Card Read operation   *          ==========================   *           - You can read SD card by using two function: SD_ReadBlock() and   *             SD_ReadMultiBlocks() functions. These functions support only   *             512-byte block length.   *           - The SD_ReadBlock() function read only one block (512-byte). This   *             function can transfer the data using DMA controller or using   *             polling mode. To select between DMA or polling mode refer to   *             "SD_DMA_MODE" or "SD_POLLING_MODE" inside the stm32_eval_sdio_sd.h   *             file and uncomment the corresponding line. By default the SD DMA   *             mode is selected            *           - The SD_ReadMultiBlocks() function read only mutli blocks (multiple   *             of 512-byte).   *           - Any read operation should be followed by two functions to check   *             if the DMA Controller and SD Card status.   *              - SD_ReadWaitOperation(): this function insure that the DMA   *                controller has finished all data transfer.   *              - SD_GetStatus(): to check that the SD Card has finished the   *                data transfer and it is ready for data.   *                     *           - The DMA transfer is finished by the SDIO Data End interrupt. User   *             has to call the SD_ProcessIRQ() function inside the SDIO_IRQHandler().   *             Don't forget to enable the SDIO_IRQn interrupt using the NVIC controller.         *                  *          C - SD Card Write operation   *          ===========================   *           - You can write SD card by using two function: SD_WriteBlock() and   *             SD_WriteMultiBlocks() functions. These functions support only   *             512-byte block length.      *           - The SD_WriteBlock() function write only one block (512-byte). This   *             function can transfer the data using DMA controller or using   *             polling mode. To select between DMA or polling mode refer to   *             "SD_DMA_MODE" or "SD_POLLING_MODE" inside the stm32_eval_sdio_sd.h   *             file and uncomment the corresponding line. By default the SD DMA   *             mode is selected            *           - The SD_WriteMultiBlocks() function write only mutli blocks (multiple   *             of 512-byte).   *           - Any write operation should be followed by two functions to check   *             if the DMA Controller and SD Card status.   *              - SD_ReadWaitOperation(): this function insure that the DMA   *                controller has finished all data transfer.   *              - SD_GetStatus(): to check that the SD Card has finished the   *                data transfer and it is ready for data.            *                  *           - The DMA transfer is finished by the SDIO Data End interrupt. User   *             has to call the SD_ProcessIRQ() function inside the SDIO_IRQHandler().   *             Don't forget to enable the SDIO_IRQn interrupt using the NVIC controller.                         *               *          D - SD card status   *          ==================   *           - At any time, you can check the SD Card status and get the SD card   *             state by using the SD_GetStatus() function. This function checks   *             first if the SD card is still connected and then get the internal   *             SD Card transfer state.        *           - You can also get the SD card SD Status register by using the   *             SD_SendSDStatus() function.         *                  *          E - Programming Model   *          =====================   *             Status = SD_Init(); // Initialization Step as described in section A   *                  *             // SDIO Interrupt ENABLE   *             NVIC_InitStructure.NVIC_IRQChannel = SDIO_IRQn;   *             NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;   *             NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;   *             NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;   *             NVIC_Init(&NVIC_InitStructure);   *               *             // Write operation as described in Section C   *             Status = SD_WriteBlock(buffer, address, 512);   *             Status = SD_WaitWriteOperation();   *             while(SD_GetStatus() != SD_TRANSFER_OK);   *               *             Status = SD_WriteMultiBlocks(buffer, address, 512, NUMBEROFBLOCKS);   *             Status = SD_WaitWriteOperation();   *             while(SD_GetStatus() != SD_TRANSFER_OK);        *               *             // Read operation as described in Section B   *             Status = SD_ReadBlock(buffer, address, 512);   *             Status = SD_WaitReadOperation();   *             while(SD_GetStatus() != SD_TRANSFER_OK);   *               *             Status = SD_ReadMultiBlocks(buffer, address, 512, NUMBEROFBLOCKS);   *             Status = SD_WaitReadOperation();   *             while(SD_GetStatus() != SD_TRANSFER_OK);               *                  *                                       *          STM32 SDIO Pin assignment   *          =========================      *          +-----------------------------------------------------------+   *          |                     Pin assignment                        |   *          +-----------------------------+---------------+-------------+   *          |  STM32 SDIO Pins            |     SD        |    Pin      |   *          +-----------------------------+---------------+-------------+   *          |      SDIO D2                |   D2          |    1        |   *          |      SDIO D3                |   D3          |    2        |   *          |      SDIO CMD               |   CMD         |    3        |   *          |                             |   VCC         |    4 (3.3 V)|   *          |      SDIO CLK               |   CLK         |    5        |   *          |                             |   GND         |    6 (0 V)  |   *          |      SDIO D0                |   D0          |    7        |   *          |      SDIO D1                |   D1          |    8        |     *          +-----------------------------+---------------+-------------+     *                 *  @endverbatim                  *               ******************************************************************************   * @attention   *   * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS   * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE   * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY   * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING   * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE   * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.   *   * © COPYRIGHT 2011 STMicroelectronics   ******************************************************************************     */ /* Includes ------------------------------------------------------------------*/ #include "stm32_eval_sdio_sd.h" /** @addtogroup Utilities   * @{   */    /** @addtogroup STM32_EVAL   * @{   */ /** @addtogroup Common   * @{   */    /** @addtogroup STM32_EVAL_SDIO_SD   * @brief      This file provides all the SD Card driver firmware functions.   * @{   */ /** @defgroup STM32_EVAL_SDIO_SD_Private_Types   * @{   */ /**   * @}   */ /** @defgroup STM32_EVAL_SDIO_SD_Private_Defines   * @{   */ /**   * @brief  SDIO Static flags, TimeOut, FIFO Address     */ #define NULL 0 #define SDIO_STATIC_FLAGS               ((uint32_t)0x000005FF) #define SDIO_CMD0TIMEOUT                ((uint32_t)0x00010000) /**   * @brief  Mask for errors Card Status R1 (OCR Register)   */ #define SD_OCR_ADDR_OUT_OF_RANGE        ((uint32_t)0x80000000) #define SD_OCR_ADDR_MISALIGNED          ((uint32_t)0x40000000) #define SD_OCR_BLOCK_LEN_ERR            ((uint32_t)0x20000000) #define SD_OCR_ERASE_SEQ_ERR            ((uint32_t)0x10000000) #define SD_OCR_BAD_ERASE_PARAM          ((uint32_t)0x08000000) #define SD_OCR_WRITE_PROT_VIOLATION     ((uint32_t)0x04000000) #define SD_OCR_LOCK_UNLOCK_FAILED       ((uint32_t)0x01000000) #define SD_OCR_COM_CRC_FAILED           ((uint32_t)0x00800000) #define SD_OCR_ILLEGAL_CMD              ((uint32_t)0x00400000) #define SD_OCR_CARD_ECC_FAILED          ((uint32_t)0x00200000) #define SD_OCR_CC_ERROR                 ((uint32_t)0x00100000) #define SD_OCR_GENERAL_UNKNOWN_ERROR    ((uint32_t)0x00080000) #define SD_OCR_STREAM_READ_UNDERRUN     ((uint32_t)0x00040000) #define SD_OCR_STREAM_WRITE_OVERRUN     ((uint32_t)0x00020000) #define SD_OCR_CID_CSD_OVERWRIETE       ((uint32_t)0x00010000) #define SD_OCR_WP_ERASE_SKIP            ((uint32_t)0x00008000) #define SD_OCR_CARD_ECC_DISABLED        ((uint32_t)0x00004000) #define SD_OCR_ERASE_RESET              ((uint32_t)0x00002000) #define SD_OCR_AKE_SEQ_ERROR            ((uint32_t)0x00000008) #define SD_OCR_ERRORBITS                ((uint32_t)0xFDFFE008) /**   * @brief  Masks for R6 Response   */ #define SD_R6_GENERAL_UNKNOWN_ERROR     ((uint32_t)0x00002000) #define SD_R6_ILLEGAL_CMD               ((uint32_t)0x00004000) #define SD_R6_COM_CRC_FAILED            ((uint32_t)0x00008000) #define SD_VOLTAGE_WINDOW_SD            ((uint32_t)0x80100000) #define SD_HIGH_CAPACITY                ((uint32_t)0x40000000) #define SD_STD_CAPACITY                 ((uint32_t)0x00000000) #define SD_CHECK_PATTERN                ((uint32_t)0x000001AA) #define SD_MAX_VOLT_TRIAL               ((uint32_t)0x0000FFFF) #define SD_ALLZERO                      ((uint32_t)0x00000000) #define SD_WIDE_BUS_SUPPORT             ((uint32_t)0x00040000) #define SD_SINGLE_BUS_SUPPORT           ((uint32_t)0x00010000) #define SD_CARD_LOCKED                  ((uint32_t)0x02000000) #define SD_DATATIMEOUT                  ((uint32_t)0xFFFFFFFF) #define SD_0TO7BITS                     ((uint32_t)0x000000FF) #define SD_8TO15BITS                    ((uint32_t)0x0000FF00) #define SD_16TO23BITS                   ((uint32_t)0x00FF0000) #define SD_24TO31BITS                   ((uint32_t)0xFF000000) #define SD_MAX_DATA_LENGTH              ((uint32_t)0x01FFFFFF) #define SD_HALFFIFO                     ((uint32_t)0x00000008) #define SD_HALFFIFOBYTES                ((uint32_t)0x00000020) /**   * @brief  Command Class Supported   */ #define SD_CCCC_LOCK_UNLOCK             ((uint32_t)0x00000080) #define SD_CCCC_WRITE_PROT              ((uint32_t)0x00000040) #define SD_CCCC_ERASE                   ((uint32_t)0x00000020) /**   * @brief  Following commands are SD Card Specific commands.   *         SDIO_APP_CMD should be sent before sending these commands.   */ #define SDIO_SEND_IF_COND               ((uint32_t)0x00000008) /**   * @}   */ /** @defgroup STM32_EVAL_SDIO_SD_Private_Macros   * @{   */ /**   * @}   */    /** @defgroup STM32_EVAL_SDIO_SD_Private_Variables   * @{   */ static uint32_t CardType =  SDIO_STD_CAPACITY_SD_CARD_V1_1; static uint32_t CSD_Tab[4], CID_Tab[4], RCA = 0; static uint8_t SDSTATUS_Tab[16]; __IO uint32_t StopCondition = 0; __IO SD_Error TransferError = SD_OK; __IO uint32_t TransferEnd = 0; SD_CardInfo SDCardInfo; SDIO_InitTypeDef SDIO_InitStructure; SDIO_CmdInitTypeDef SDIO_CmdInitStructure; SDIO_DataInitTypeDef SDIO_DataInitStructure;    /**   * @}                                */ /** @defgroup STM32_EVAL_SDIO_SD_Private_Function_Prototypes   * @{   */ static SD_Error CmdError(void); static SD_Error CmdResp1Error(uint8_t cmd); static SD_Error CmdResp7Error(void); static SD_Error CmdResp3Error(void); static SD_Error CmdResp2Error(void); static SD_Error CmdResp6Error(uint8_t cmd, uint16_t *prca); static SD_Error SDEnWideBus(FunctionalState NewState); static SD_Error IsCardProgramming(uint8_t *pstatus); static SD_Error FindSCR(uint16_t rca, uint32_t *pscr); uint8_t convert_from_bytes_to_power_of_two(uint16_t NumberOfBytes);    /**   * @}   */ /** @defgroup STM32_EVAL_SDIO_SD_Private_Functions   * @{   */   /**   * @brief  DeInitializes the SDIO interface.   * @param  None   * @retval None   */ void SD_DeInit(void) {   SD_LowLevel_DeInit(); } /**   * @brief  Initializes the SD Card and put it into StandBy State (Ready for data   *         transfer).   * @param  None   * @retval SD_Error: SD Card Error code.   */ SD_Error SD_Init(void) {   SD_Error errorstatus = SD_OK;      /* SDIO Peripheral Low Level Init */   SD_LowLevel_Init();   SDIO_DeInit();   errorstatus = SD_PowerON();   if (errorstatus != SD_OK)   {     /*!< CMD Response TimeOut (wait for CMDSENT flag) */     return(errorstatus);   }   errorstatus = SD_InitializeCards();   if (errorstatus != SD_OK)   {     /*!< CMD Response TimeOut (wait for CMDSENT flag) */     return(errorstatus);   }   /*!< Configure the SDIO peripheral */   /*!< SDIOCLK = HCLK, SDIO_CK = HCLK/(2 + SDIO_TRANSFER_CLK_DIV) */   /*!< on STM32F2xx devices, SDIOCLK is fixed to 48MHz */     SDIO_InitStructure.SDIO_ClockDiv = SDIO_TRANSFER_CLK_DIV;   SDIO_InitStructure.SDIO_ClockEdge = SDIO_ClockEdge_Rising;   SDIO_InitStructure.SDIO_ClockBypass = SDIO_ClockBypass_Disable;   SDIO_InitStructure.SDIO_ClockPowerSave = SDIO_ClockPowerSave_Disable;   SDIO_InitStructure.SDIO_BusWide = SDIO_BusWide_1b;   SDIO_InitStructure.SDIO_HardwareFlowControl = SDIO_HardwareFlowControl_Disable;   SDIO_Init(&SDIO_InitStructure);      if (errorstatus == SD_OK)   {     /*----------------- Read CSD/CID MSD registers ------------------*/     errorstatus = SD_GetCardInfo(&SDCardInfo);   }   if (errorstatus == SD_OK)   {     /*----------------- Select Card --------------------------------*/     errorstatus = SD_SelectDeselect((uint32_t) (SDCardInfo.RCA RCA = (uint16_t)RCA;   /*!< Byte 0 */   tmp = (uint8_t)((CSD_Tab[0] & 0xFF000000) >> 24);   cardinfo->SD_csd.CSDStruct = (tmp & 0xC0) >> 6;   cardinfo->SD_csd.SysSpecVersion = (tmp & 0x3C) >> 2;   cardinfo->SD_csd.Reserved1 = tmp & 0x03;   /*!< Byte 1 */   tmp = (uint8_t)((CSD_Tab[0] & 0x00FF0000) >> 16);   cardinfo->SD_csd.TAAC = tmp;   /*!< Byte 2 */   tmp = (uint8_t)((CSD_Tab[0] & 0x0000FF00) >> 8);   cardinfo->SD_csd.NSAC = tmp;   /*!< Byte 3 */   tmp = (uint8_t)(CSD_Tab[0] & 0x000000FF);   cardinfo->SD_csd.MaxBusClkFrec = tmp;   /*!< Byte 4 */   tmp = (uint8_t)((CSD_Tab[1] & 0xFF000000) >> 24);   cardinfo->SD_csd.CardComdClasses = tmp > 16);   cardinfo->SD_csd.CardComdClasses |= (tmp & 0xF0) >> 4;   cardinfo->SD_csd.RdBlockLen = tmp & 0x0F;   /*!< Byte 6 */   tmp = (uint8_t)((CSD_Tab[1] & 0x0000FF00) >> 8);   cardinfo->SD_csd.PartBlockRead = (tmp & 0x80) >> 7;   cardinfo->SD_csd.WrBlockMisalign = (tmp & 0x40) >> 6;   cardinfo->SD_csd.RdBlockMisalign = (tmp & 0x20) >> 5;   cardinfo->SD_csd.DSRImpl = (tmp & 0x10) >> 4;   cardinfo->SD_csd.Reserved2 = 0; /*!< Reserved */   if ((CardType == SDIO_STD_CAPACITY_SD_CARD_V1_1) || (CardType == SDIO_STD_CAPACITY_SD_CARD_V2_0))   {     cardinfo->SD_csd.DeviceSize = (tmp & 0x03) SD_csd.DeviceSize |= (tmp) > 24);     cardinfo->SD_csd.DeviceSize |= (tmp & 0xC0) >> 6;     cardinfo->SD_csd.MaxRdCurrentVDDMin = (tmp & 0x38) >> 3;     cardinfo->SD_csd.MaxRdCurrentVDDMax = (tmp & 0x07);     /*!< Byte 9 */     tmp = (uint8_t)((CSD_Tab[2] & 0x00FF0000) >> 16);     cardinfo->SD_csd.MaxWrCurrentVDDMin = (tmp & 0xE0) >> 5;     cardinfo->SD_csd.MaxWrCurrentVDDMax = (tmp & 0x1C) >> 2;     cardinfo->SD_csd.DeviceSizeMul = (tmp & 0x03) > 8);     cardinfo->SD_csd.DeviceSizeMul |= (tmp & 0x80) >> 7;         cardinfo->CardCapacity = (cardinfo->SD_csd.DeviceSize + 1) ;     cardinfo->CardCapacity *= (1 SD_csd.DeviceSizeMul + 2));     cardinfo->CardBlockSize = 1 SD_csd.RdBlockLen);     cardinfo->CardCapacity *= cardinfo->CardBlockSize;   }   else if (CardType == SDIO_HIGH_CAPACITY_SD_CARD)   {     /*!< Byte 7 */     tmp = (uint8_t)(CSD_Tab[1] & 0x000000FF);     cardinfo->SD_csd.DeviceSize = (tmp & 0x3F) > 24);     cardinfo->SD_csd.DeviceSize |= (tmp > 16);     cardinfo->SD_csd.DeviceSize |= (tmp);     /*!< Byte 10 */     tmp = (uint8_t)((CSD_Tab[2] & 0x0000FF00) >> 8);         cardinfo->CardCapacity = (cardinfo->SD_csd.DeviceSize + 1) * 512 * 1024;     cardinfo->CardBlockSize = 512;      }   cardinfo->SD_csd.EraseGrSize = (tmp & 0x40) >> 6;   cardinfo->SD_csd.EraseGrMul = (tmp & 0x3F) SD_csd.EraseGrMul |= (tmp & 0x80) >> 7;   cardinfo->SD_csd.WrProtectGrSize = (tmp & 0x7F);   /*!< Byte 12 */   tmp = (uint8_t)((CSD_Tab[3] & 0xFF000000) >> 24);   cardinfo->SD_csd.WrProtectGrEnable = (tmp & 0x80) >> 7;   cardinfo->SD_csd.ManDeflECC = (tmp & 0x60) >> 5;   cardinfo->SD_csd.WrSpeedFact = (tmp & 0x1C) >> 2;   cardinfo->SD_csd.MaxWrBlockLen = (tmp & 0x03) > 16);   cardinfo->SD_csd.MaxWrBlockLen |= (tmp & 0xC0) >> 6;   cardinfo->SD_csd.WriteBlockPaPartial = (tmp & 0x20) >> 5;   cardinfo->SD_csd.Reserved3 = 0;   cardinfo->SD_csd.ContentProtectAppli = (tmp & 0x01);   /*!< Byte 14 */   tmp = (uint8_t)((CSD_Tab[3] & 0x0000FF00) >> 8);   cardinfo->SD_csd.FileFormatGrouop = (tmp & 0x80) >> 7;   cardinfo->SD_csd.CopyFlag = (tmp & 0x40) >> 6;   cardinfo->SD_csd.PermWrProtect = (tmp & 0x20) >> 5;   cardinfo->SD_csd.TempWrProtect = (tmp & 0x10) >> 4;   cardinfo->SD_csd.FileFormat = (tmp & 0x0C) >> 2;   cardinfo->SD_csd.ECC = (tmp & 0x03);   /*!< Byte 15 */   tmp = (uint8_t)(CSD_Tab[3] & 0x000000FF);   cardinfo->SD_csd.CSD_CRC = (tmp & 0xFE) >> 1;   cardinfo->SD_csd.Reserved4 = 1;   /*!< Byte 0 */   tmp = (uint8_t)((CID_Tab[0] & 0xFF000000) >> 24);   cardinfo->SD_cid.ManufacturerID = tmp;   /*!< Byte 1 */   tmp = (uint8_t)((CID_Tab[0] & 0x00FF0000) >> 16);   cardinfo->SD_cid.OEM_AppliID = tmp > 8);   cardinfo->SD_cid.OEM_AppliID |= tmp;   /*!< Byte 3 */   tmp = (uint8_t)(CID_Tab[0] & 0x000000FF);   cardinfo->SD_cid.ProdName1 = tmp > 24);   cardinfo->SD_cid.ProdName1 |= tmp > 16);   cardinfo->SD_cid.ProdName1 |= tmp > 8);   cardinfo->SD_cid.ProdName1 |= tmp;   /*!< Byte 7 */   tmp = (uint8_t)(CID_Tab[1] & 0x000000FF);   cardinfo->SD_cid.ProdName2 = tmp;   /*!< Byte 8 */   tmp = (uint8_t)((CID_Tab[2] & 0xFF000000) >> 24);   cardinfo->SD_cid.ProdRev = tmp;   /*!< Byte 9 */   tmp = (uint8_t)((CID_Tab[2] & 0x00FF0000) >> 16);   cardinfo->SD_cid.ProdSN = tmp > 8);   cardinfo->SD_cid.ProdSN |= tmp SD_cid.ProdSN |= tmp > 24);   cardinfo->SD_cid.ProdSN |= tmp;   /*!< Byte 13 */   tmp = (uint8_t)((CID_Tab[3] & 0x00FF0000) >> 16);   cardinfo->SD_cid.Reserved1 |= (tmp & 0xF0) >> 4;   cardinfo->SD_cid.ManufactDate = (tmp & 0x0F) > 8);   cardinfo->SD_cid.ManufactDate |= tmp;   /*!< Byte 15 */   tmp = (uint8_t)(CID_Tab[3] & 0x000000FF);   cardinfo->SD_cid.CID_CRC = (tmp & 0xFE) >> 1;   cardinfo->SD_cid.Reserved2 = 1;      return(errorstatus); } /**   * @brief  Enables wide bus opeartion for the requeseted card if supported by   *         card.   * @param  WideMode: Specifies the SD card wide bus mode.   *   This parameter can be one of the following values:   *     @arg SDIO_BusWide_8b: 8-bit data transfer (Only for MMC)   *     @arg SDIO_BusWide_4b: 4-bit data transfer   *     @arg SDIO_BusWide_1b: 1-bit data transfer   * @retval SD_Error: SD Card Error code.   */ SD_Error SD_GetCardStatus(SD_CardStatus *cardstatus) {   SD_Error errorstatus = SD_OK;   uint8_t tmp = 0;   errorstatus = SD_SendSDStatus((uint32_t *)SDSTATUS_Tab);   if (errorstatus  != SD_OK)   {     return(errorstatus);   }   /*!< Byte 0 */   tmp = (uint8_t)((SDSTATUS_Tab[0] & 0xC0) >> 6);   cardstatus->DAT_BUS_WIDTH = tmp;   /*!< Byte 0 */   tmp = (uint8_t)((SDSTATUS_Tab[0] & 0x20) >> 5);   cardstatus->SECURED_MODE = tmp;   /*!< Byte 2 */   tmp = (uint8_t)((SDSTATUS_Tab[2] & 0xFF));   cardstatus->SD_CARD_TYPE = tmp SD_CARD_TYPE |= tmp;   /*!< Byte 4 */   tmp = (uint8_t)(SDSTATUS_Tab[4] & 0xFF);   cardstatus->SIZE_OF_PROTECTED_AREA = tmp SIZE_OF_PROTECTED_AREA |= tmp SIZE_OF_PROTECTED_AREA |= tmp SIZE_OF_PROTECTED_AREA |= tmp;   /*!< Byte 8 */   tmp = (uint8_t)((SDSTATUS_Tab[8] & 0xFF));   cardstatus->SPEED_CLASS = tmp;   /*!< Byte 9 */   tmp = (uint8_t)((SDSTATUS_Tab[9] & 0xFF));   cardstatus->PERFORMANCE_MOVE = tmp;   /*!< Byte 10 */   tmp = (uint8_t)((SDSTATUS_Tab[10] & 0xF0) >> 4);   cardstatus->AU_SIZE = tmp;   /*!< Byte 11 */   tmp = (uint8_t)(SDSTATUS_Tab[11] & 0xFF);   cardstatus->ERASE_SIZE = tmp ERASE_SIZE |= tmp;   /*!< Byte 13 */   tmp = (uint8_t)((SDSTATUS_Tab[13] & 0xFC) >> 2);   cardstatus->ERASE_TIMEOUT = tmp;   /*!< Byte 13 */   tmp = (uint8_t)((SDSTATUS_Tab[13] & 0x3));   cardstatus->ERASE_OFFSET = tmp;   return(errorstatus); } /**   * @brief  Enables wide bus opeartion for the requeseted card if supported by   *         card.   * @param  WideMode: Specifies the SD card wide bus mode.   *   This parameter can be one of the following values:   *     @arg SDIO_BusWide_8b: 8-bit data transfer (Only for MMC)   *     @arg SDIO_BusWide_4b: 4-bit data transfer   *     @arg SDIO_BusWide_1b: 1-bit data transfer   * @retval SD_Error: SD Card Error code.   */ SD_Error SD_EnableWideBusOperation(uint32_t WideMode) {   SD_Error errorstatus = SD_OK;   /*!< MMC Card doesn't support this feature */   if (SDIO_MULTIMEDIA_CARD == CardType)   {     errorstatus = SD_UNSUPPORTED_FEATURE;     return(errorstatus);   }   else if ((SDIO_STD_CAPACITY_SD_CARD_V1_1 == CardType) || (SDIO_STD_CAPACITY_SD_CARD_V2_0 == CardType) || (SDIO_HIGH_CAPACITY_SD_CARD == CardType))   {     if (SDIO_BusWide_8b == WideMode)     {       errorstatus = SD_UNSUPPORTED_FEATURE;       return(errorstatus);     }     else if (SDIO_BusWide_4b == WideMode)     {       errorstatus = SDEnWideBus(ENABLE);       if (SD_OK == errorstatus)       {         /*!< Configure the SDIO peripheral */         SDIO_InitStructure.SDIO_ClockDiv = SDIO_TRANSFER_CLK_DIV;         SDIO_InitStructure.SDIO_ClockEdge = SDIO_ClockEdge_Rising;         SDIO_InitStructure.SDIO_ClockBypass = SDIO_ClockBypass_Disable;         SDIO_InitStructure.SDIO_ClockPowerSave = SDIO_ClockPowerSave_Disable;         SDIO_InitStructure.SDIO_BusWide = SDIO_BusWide_4b;         SDIO_InitStructure.SDIO_HardwareFlowControl = SDIO_HardwareFlowControl_Disable;         SDIO_Init(&SDIO_InitStructure);       }     }     else     {       errorstatus = SDEnWideBus(DISABLE);       if (SD_OK == errorstatus)       {         /*!< Configure the SDIO peripheral */         SDIO_InitStructure.SDIO_ClockDiv = SDIO_TRANSFER_CLK_DIV;         SDIO_InitStructure.SDIO_ClockEdge = SDIO_ClockEdge_Rising;         SDIO_InitStructure.SDIO_ClockBypass = SDIO_ClockBypass_Disable;         SDIO_InitStructure.SDIO_ClockPowerSave = SDIO_ClockPowerSave_Disable;         SDIO_InitStructure.SDIO_BusWide = SDIO_BusWide_1b;         SDIO_InitStructure.SDIO_HardwareFlowControl = SDIO_HardwareFlowControl_Disable;         SDIO_Init(&SDIO_InitStructure);       }     }   }   return(errorstatus); } /**   * @brief  Selects od Deselects the corresponding card.   * @param  addr: Address of the Card to be selected.   * @retval SD_Error: SD Card Error code.   */ SD_Error SD_SelectDeselect(uint32_t addr) {   SD_Error errorstatus = SD_OK;   /*!< Send CMD7 SDIO_SEL_DESEL_CARD */   SDIO_CmdInitStructure.SDIO_Argument =  addr;   SDIO_CmdInitStructure.SDIO_CmdIndex = SD_CMD_SEL_DESEL_CARD;   SDIO_CmdInitStructure.SDIO_Response = SDIO_Response_Short;   SDIO_CmdInitStructure.SDIO_Wait = SDIO_Wait_No;   SDIO_CmdInitStructure.SDIO_CPSM = SDIO_CPSM_Enable;   SDIO_SendCommand(&SDIO_CmdInitStructure);   errorstatus = CmdResp1Error(SD_CMD_SEL_DESEL_CARD);   return(errorstatus); } /**   * @brief  Allows to read one block from a specified address in a card. The Data   *         transfer can be managed by DMA mode or Polling mode.   * @note   This operation should be followed by two functions to check if the   *         DMA Controller and SD Card status.   *          - SD_ReadWaitOperation(): this function insure that the DMA   *            controller has finished all data transfer.   *          - SD_GetStatus(): to check that the SD Card has finished the   *            data transfer and it is ready for data.               * @param  readbuff: pointer to the buffer that will contain the received data   * @param  ReadAddr: Address from where data are to be read.     * @param  BlockSize: the SD card Data block size. The Block size should be 512.   * @retval SD_Error: SD Card Error code.   */ SD_Error SD_ReadBlock(uint8_t *readbuff, uint32_t ReadAddr, uint16_t BlockSize) {   SD_Error errorstatus = SD_OK; #if defined (SD_POLLING_MODE)   uint32_t count = 0, *tempbuff = (uint32_t *)readbuff; #endif   TransferError = SD_OK;   TransferEnd = 0;   StopCondition = 0;      SDIO->DCTRL = 0x0;      if (CardType == SDIO_HIGH_CAPACITY_SD_CARD)   {     BlockSize = 512;     ReadAddr /= 512;   }   SDIO_DataInitStructure.SDIO_DataTimeOut = SD_DATATIMEOUT;   SDIO_DataInitStructure.SDIO_DataLength = BlockSize;   SDIO_DataInitStructure.SDIO_DataBlockSize = (uint32_t) 9 STA &(SDIO_FLAG_RXOVERR | SDIO_FLAG_DCRCFAIL | SDIO_FLAG_DTIMEOUT | SDIO_FLAG_DBCKEND | SDIO_FLAG_STBITERR)))   {     if (SDIO_GetFlagStatus(SDIO_FLAG_RXFIFOHF) != RESET)     {       for (count = 0; count < 8; count++)       {         *(tempbuff + count) = SDIO_ReadData();       }       tempbuff += 8;     }   }   if (SDIO_GetFlagStatus(SDIO_FLAG_DTIMEOUT) != RESET)   {     SDIO_ClearFlag(SDIO_FLAG_DTIMEOUT);     errorstatus = SD_DATA_TIMEOUT;     return(errorstatus);   }   else if (SDIO_GetFlagStatus(SDIO_FLAG_DCRCFAIL) != RESET)   {     SDIO_ClearFlag(SDIO_FLAG_DCRCFAIL);     errorstatus = SD_DATA_CRC_FAIL;     return(errorstatus);   }   else if (SDIO_GetFlagStatus(SDIO_FLAG_RXOVERR) != RESET)   {     SDIO_ClearFlag(SDIO_FLAG_RXOVERR);     errorstatus = SD_RX_OVERRUN;     return(errorstatus);   }   else if (SDIO_GetFlagStatus(SDIO_FLAG_STBITERR) != RESET)   {     SDIO_ClearFlag(SDIO_FLAG_STBITERR);     errorstatus = SD_START_BIT_ERR;     return(errorstatus);   }   while (SDIO_GetFlagStatus(SDIO_FLAG_RXDAVL) != RESET)   {     *tempbuff = SDIO_ReadData();     tempbuff++;   }      /*!< Clear all the static flags */   SDIO_ClearFlag(SDIO_STATIC_FLAGS); #elif defined (SD_DMA_MODE)     SDIO_ITConfig(SDIO_IT_DATAEND, ENABLE);     SDIO_DMACmd(ENABLE);     SD_LowLevel_DMA_RxConfig((uint32_t *)readbuff, BlockSize); #endif   return(errorstatus); } /**   * @brief  Allows to read blocks from a specified address  in a card.  The Data   *         transfer can be managed by DMA mode or Polling mode.   * @note   This operation should be followed by two functions to check if the   *         DMA Controller and SD Card status.   *          - SD_ReadWaitOperation(): this function insure that the DMA   *            controller has finished all data transfer.   *          - SD_GetStatus(): to check that the SD Card has finished the   *            data transfer and it is ready for data.      * @param  readbuff: pointer to the buffer that will contain the received data.   * @param  ReadAddr: Address from where data are to be read.   * @param  BlockSize: the SD card Data block size. The Block size should be 512.   * @param  NumberOfBlocks: number of blocks to be read.   * @retval SD_Error: SD Card Error code.   */ SD_Error SD_ReadMultiBlocks(uint8_t *readbuff, uint32_t ReadAddr, uint16_t BlockSize, uint32_t NumberOfBlocks) {   SD_Error errorstatus = SD_OK;   TransferError = SD_OK;   TransferEnd = 0;   StopCondition = 1;           SDIO->DCTRL = 0x0;   if (CardType == SDIO_HIGH_CAPACITY_SD_CARD)   {     BlockSize = 512;     ReadAddr /= 512;   }   /*!< Set Block Size for Card */   SDIO_CmdInitStructure.SDIO_Argument = (uint32_t) BlockSize;   SDIO_CmdInitStructure.SDIO_CmdIndex = SD_CMD_SET_BLOCKLEN;   SDIO_CmdInitStructure.SDIO_Response = SDIO_Response_Short;   SDIO_CmdInitStructure.SDIO_Wait = SDIO_Wait_No;   SDIO_CmdInitStructure.SDIO_CPSM = SDIO_CPSM_Enable;   SDIO_SendCommand(&SDIO_CmdInitStructure);   errorstatus = CmdResp1Error(SD_CMD_SET_BLOCKLEN);   if (SD_OK != errorstatus)   {     return(errorstatus);   }       SDIO_DataInitStructure.SDIO_DataTimeOut = SD_DATATIMEOUT;   SDIO_DataInitStructure.SDIO_DataLength = NumberOfBlocks * BlockSize;   SDIO_DataInitStructure.SDIO_DataBlockSize = (uint32_t) 9 DCTRL = 0x0;   if (CardType == SDIO_HIGH_CAPACITY_SD_CARD)   {     BlockSize = 512;     WriteAddr /= 512;   }      /*!< Send CMD24 WRITE_SINGLE_BLOCK */   SDIO_CmdInitStructure.SDIO_Argument = WriteAddr;   SDIO_CmdInitStructure.SDIO_CmdIndex = SD_CMD_WRITE_SINGLE_BLOCK;   SDIO_CmdInitStructure.SDIO_Response = SDIO_Response_Short;   SDIO_CmdInitStructure.SDIO_Wait = SDIO_Wait_No;   SDIO_CmdInitStructure.SDIO_CPSM = SDIO_CPSM_Enable;   SDIO_SendCommand(&SDIO_CmdInitStructure);   errorstatus = CmdResp1Error(SD_CMD_WRITE_SINGLE_BLOCK);   if (errorstatus != SD_OK)   {     return(errorstatus);   }   SDIO_DataInitStructure.SDIO_DataTimeOut = SD_DATATIMEOUT;   SDIO_DataInitStructure.SDIO_DataLength = BlockSize;   SDIO_DataInitStructure.SDIO_DataBlockSize = (uint32_t) 9 STA & (SDIO_FLAG_DBCKEND | SDIO_FLAG_TXUNDERR | SDIO_FLAG_DCRCFAIL | SDIO_FLAG_DTIMEOUT | SDIO_FLAG_STBITERR)))   {     if (SDIO_GetFlagStatus(SDIO_FLAG_TXFIFOHE) != RESET)     {       if ((512 - bytestransferred) < 32)       {         restwords = ((512 - bytestransferred) % 4 == 0) ? ((512 - bytestransferred) / 4) : (( 512 -  bytestransferred) / 4 + 1);         for (count = 0; count < restwords; count++, tempbuff++, bytestransferred += 4)         {           SDIO_WriteData(*tempbuff);         }       }       else       {         for (count = 0; count < 8; count++)         {           SDIO_WriteData(*(tempbuff + count));         }         tempbuff += 8;         bytestransferred += 32;       }     }   }   if (SDIO_GetFlagStatus(SDIO_FLAG_DTIMEOUT) != RESET)   {     SDIO_ClearFlag(SDIO_FLAG_DTIMEOUT);     errorstatus = SD_DATA_TIMEOUT;     return(errorstatus);   }   else if (SDIO_GetFlagStatus(SDIO_FLAG_DCRCFAIL) != RESET)   {     SDIO_ClearFlag(SDIO_FLAG_DCRCFAIL);     errorstatus = SD_DATA_CRC_FAIL;     return(errorstatus);   }   else if (SDIO_GetFlagStatus(SDIO_FLAG_TXUNDERR) != RESET)   {     SDIO_ClearFlag(SDIO_FLAG_TXUNDERR);     errorstatus = SD_TX_UNDERRUN;     return(errorstatus);   }   else if (SDIO_GetFlagStatus(SDIO_FLAG_STBITERR) != RESET)   {     SDIO_ClearFlag(SDIO_FLAG_STBITERR);     errorstatus = SD_START_BIT_ERR;     return(errorstatus);   } #elif defined (SD_DMA_MODE)   SDIO_ITConfig(SDIO_IT_DATAEND, ENABLE);   SD_LowLevel_DMA_TxConfig((uint32_t *)writebuff, BlockSize);   SDIO_DMACmd(ENABLE); #endif   return(errorstatus); } /**   * @brief  Allows to write blocks starting from a specified address in a card.   *         The Data transfer can be managed by DMA mode only.   * @note   This operation should be followed by two functions to check if the   *         DMA Controller and SD Card status.   *          - SD_ReadWaitOperation(): this function insure that the DMA   *            controller has finished all data transfer.   *          - SD_GetStatus(): to check that the SD Card has finished the   *            data transfer and it is ready for data.        * @param  WriteAddr: Address from where data are to be read.   * @param  writebuff: pointer to the buffer that contain the data to be transferred.   * @param  BlockSize: the SD card Data block size. The Block size should be 512.   * @param  NumberOfBlocks: number of blocks to be written.   * @retval SD_Error: SD Card Error code.   */ SD_Error SD_WriteMultiBlocks(uint8_t *writebuff, uint32_t WriteAddr, uint16_t BlockSize, uint32_t NumberOfBlocks) {   SD_Error errorstatus = SD_OK;   __IO uint32_t count = 0;   TransferError = SD_OK;   TransferEnd = 0;   StopCondition = 1;      SDIO->DCTRL = 0x0;   if (CardType == SDIO_HIGH_CAPACITY_SD_CARD)   {     BlockSize = 512;     WriteAddr /= 512;   }   /*!< To improve performance */   SDIO_CmdInitStructure.SDIO_Argument = (uint32_t) (RCA ARG = 0x0;   SDIO->CMD = 0x44C;   errorstatus = CmdResp1Error(SD_CMD_STOP_TRANSMISSION);   return(errorstatus); } /**   * @brief  Allows to erase memory area specified for the given card.   * @param  startaddr: the start address.   * @param  endaddr: the end address.   * @retval SD_Error: SD Card Error code.   */ SD_Error SD_Erase(uint32_t startaddr, uint32_t endaddr) {   SD_Error errorstatus = SD_OK;   uint32_t delay = 0;   __IO uint32_t maxdelay = 0;   uint8_t cardstate = 0;   /*!< Check if the card coomnd class supports erase command */   if (((CSD_Tab[1] >> 20) & SD_CCCC_ERASE) == 0)   {     errorstatus = SD_REQUEST_NOT_APPLICABLE;     return(errorstatus);   }   maxdelay = 120000 / ((SDIO->CLKCR & 0xFF) + 2);   if (SDIO_GetResponse(SDIO_RESP1) & SD_CARD_LOCKED)   {     errorstatus = SD_LOCK_UNLOCK_FAILED;     return(errorstatus);   }   if (CardType == SDIO_HIGH_CAPACITY_SD_CARD)   {     startaddr /= 512;     endaddr /= 512;   }      /*!< According to sd-card spec 1.0 ERASE_GROUP_START (CMD32) and erase_group_end(CMD33) */   if ((SDIO_STD_CAPACITY_SD_CARD_V1_1 == CardType) || (SDIO_STD_CAPACITY_SD_CARD_V2_0 == CardType) || (SDIO_HIGH_CAPACITY_SD_CARD == CardType))   {     /*!< Send CMD32 SD_ERASE_GRP_START with argument as addr  */     SDIO_CmdInitStructure.SDIO_Argument = startaddr;     SDIO_CmdInitStructure.SDIO_CmdIndex = SD_CMD_SD_ERASE_GRP_START;     SDIO_CmdInitStructure.SDIO_Response = SDIO_Response_Short;     SDIO_CmdInitStructure.SDIO_Wait = SDIO_Wait_No;     SDIO_CmdInitStructure.SDIO_CPSM = SDIO_CPSM_Enable;     SDIO_SendCommand(&SDIO_CmdInitStructure);     errorstatus = CmdResp1Error(SD_CMD_SD_ERASE_GRP_START);     if (errorstatus != SD_OK)     {       return(errorstatus);     }     /*!< Send CMD33 SD_ERASE_GRP_END with argument as addr  */     SDIO_CmdInitStructure.SDIO_Argument = endaddr;     SDIO_CmdInitStructure.SDIO_CmdIndex = SD_CMD_SD_ERASE_GRP_END;     SDIO_CmdInitStructure.SDIO_Response = SDIO_Response_Short;     SDIO_CmdInitStructure.SDIO_Wait = SDIO_Wait_No;     SDIO_CmdInitStructure.SDIO_CPSM = SDIO_CPSM_Enable;     SDIO_SendCommand(&SDIO_CmdInitStructure);     errorstatus = CmdResp1Error(SD_CMD_SD_ERASE_GRP_END);     if (errorstatus != SD_OK)     {       return(errorstatus);     }   }   /*!< Send CMD38 ERASE */   SDIO_CmdInitStructure.SDIO_Argument = 0;   SDIO_CmdInitStructure.SDIO_CmdIndex = SD_CMD_ERASE;   SDIO_CmdInitStructure.SDIO_Response = SDIO_Response_Short;   SDIO_CmdInitStructure.SDIO_Wait = SDIO_Wait_No;   SDIO_CmdInitStructure.SDIO_CPSM = SDIO_CPSM_Enable;   SDIO_SendCommand(&SDIO_CmdInitStructure);   errorstatus = CmdResp1Error(SD_CMD_ERASE);   if (errorstatus != SD_OK)   {     return(errorstatus);   }   for (delay = 0; delay < maxdelay; delay++)   {}   /*!< Wait till the card is in programming state */   errorstatus = IsCardProgramming(&cardstate);   while ((errorstatus == SD_OK) && ((SD_CARD_PROGRAMMING == cardstate) || (SD_CARD_RECEIVING == cardstate)))   {     errorstatus = IsCardProgramming(&cardstate);   }   return(errorstatus); } /**   * @brief  Returns the current card's status.   * @param  pcardstatus: pointer to the buffer that will contain the SD card   *         status (Card Status register).   * @retval SD_Error: SD Card Error code.   */ SD_Error SD_SendStatus(uint32_t *pcardstatus) {   SD_Error errorstatus = SD_OK;   SDIO->ARG = (uint32_t) RCA CMD = 0x44D;      errorstatus = CmdResp1Error(SD_CMD_SEND_STATUS);   if (errorstatus != SD_OK)   {     return(errorstatus);   }   *pcardstatus = SDIO->RESP1;   return(errorstatus); } /**   * @brief  Returns the current SD card's status.   * @param  psdstatus: pointer to the buffer that will contain the SD card status   *         (SD Status register).   * @retval SD_Error: SD Card Error code.   */ SD_Error SD_SendSDStatus(uint32_t *psdstatus) {   SD_Error errorstatus = SD_OK;   uint32_t count = 0;   if (SDIO_GetResponse(SDIO_RESP1) & SD_CARD_LOCKED)   {     errorstatus = SD_LOCK_UNLOCK_FAILED;     return(errorstatus);   }   /*!< Set block size for card if it is not equal to current block size for card. */   SDIO_CmdInitStructure.SDIO_Argument = 64;   SDIO_CmdInitStructure.SDIO_CmdIndex = SD_CMD_SET_BLOCKLEN;   SDIO_CmdInitStructure.SDIO_Response = SDIO_Response_Short;   SDIO_CmdInitStructure.SDIO_Wait = SDIO_Wait_No;   SDIO_CmdInitStructure.SDIO_CPSM = SDIO_CPSM_Enable;   SDIO_SendCommand(&SDIO_CmdInitStructure);   errorstatus = CmdResp1Error(SD_CMD_SET_BLOCKLEN);   if (errorstatus != SD_OK)   {     return(errorstatus);   }   /*!< CMD55 */   SDIO_CmdInitStructure.SDIO_Argument = (uint32_t) RCA   详情 回复 发表于 2013-9-28 14:26
4008
SDHC卡属2.0卡,cmd8指令的回应区分是1.0或2.0卡.
2.0卡不需要cmd55,cmd2,cmd3指令用于读取卡参数,是为了提高卡程序的兼容性.
数据全0是不对的.
此帖出自单片机论坛
根据cmd8,回应看出是2.0,那接下来需要什么命令?  详情 回复 发表于 2013-9-28 14:04
回复 沙发huo_hu 的帖子
此帖出自单片机论坛
4008
  * @version V4.5.0
  *  @verbatim
  *          file.
  *             mode is selected
  *             of 512-byte).
  *             mode is selected
  *             of 512-byte).
  *  @endverbatim
  * @attention
#define NULL 0
  * @param  None
  * @retval None
  *         transfer).
  * @param  None
  SD_LowLevel_Init();
  SDIO_DeInit();
    errorstatus = SD_SelectDeselect((uint32_t) (SDCardInfo.RCA << 16));
    errorstatus = SD_EnableWideBusOperation(SDIO_BusWide_4b);
  * @brief  Gets the cuurent sd card data transfer status.
  * @param  None
  * @retval SDTransferState: Data Transfer state.
  *   This value can be:
  *        - SD_TRANSFER_OK: No data transfer is acting
  *        - SD_TRANSFER_BUSY: Data transfer is acting
SDTransferState SD_GetStatus(void)
  SDCardState cardstate =  SD_CARD_TRANSFER;
  cardstate = SD_GetState();
  if (cardstate == SD_CARD_TRANSFER)
    return(SD_TRANSFER_OK);
  else if(cardstate == SD_CARD_ERROR)
    return (SD_TRANSFER_ERROR);
  else
    return(SD_TRANSFER_BUSY);
  * @brief  Returns the current card's state.
  * @param  None
  * @retval SDCardState: SD Card Error or SD Card Current State.
SDCardState SD_GetState(void)
  uint32_t resp1 = 0;
  if(SD_Detect()== SD_PRESENT)
    if (SD_SendStatus(&resp1) != SD_OK)
      return SD_CARD_ERROR;
    else
      return (SDCardState)((resp1 >> 9) & 0x0F);
  else
* @brief  Detect if SD card is correctly plugged in the memory slot.
* @param  None
* @retval Return if SD is detected or not
uint8_t SD_Detect(void)
  __IO uint8_t status = SD_PRESENT;
  /*!< Check GPIO to detect SD */
  if (GPIO_ReadInputDataBit(SD_DETECT_GPIO_PORT, SD_DETECT_PIN) != Bit_RESET)
    status = SD_NOT_PRESENT;
  return status;
  * @brief  Enquires cards about their operating voltage and configures
  *   clock controls.
  * @param  None
SD_Error SD_PowerON(void)
  uint32_t response = 0, count = 0, validvoltage = 0;
  uint32_t SDType = SD_STD_CAPACITY;
  /*!< Power ON Sequence -----------------------------------------------------*/
  /*!< SDIOCLK = HCLK, SDIO_CK = HCLK/(2 + SDIO_INIT_CLK_DIV) */
  /*!< SDIO_CK for initialization should not exceed 400 KHz */
  SDIO_InitStructure.SDIO_ClockDiv = SDIO_INIT_CLK_DIV;
  /*!< Set Power State to ON */
  SDIO_SetPowerState(SDIO_PowerState_ON);
  /*!< Enable SDIO Clock */
  SDIO_ClockCmd(ENABLE);
  /*!< CMD0: GO_IDLE_STATE ---------------------------------------------------*/
  /*!< No CMD response required */
  SDIO_CmdInitStructure.SDIO_Argument = 0x0;
  SDIO_CmdInitStructure.SDIO_CmdIndex = SD_CMD_GO_IDLE_STATE;
  SDIO_CmdInitStructure.SDIO_Response = SDIO_Response_No;
  errorstatus = CmdError();
  /*!< CMD8: SEND_IF_COND ----------------------------------------------------*/
  /*!< Send CMD8 to verify SD card interface operating condition */
  /*!< Argument: - [31:12]: Reserved (shall be set to '0')
               - [11:8]: Supply Voltage (VHS) 0x1 (Range: 2.7-3.6 V)
               - [7:0]: Check Pattern (recommended 0xAA) */
  /*!< CMD Response: R7 */
  SDIO_CmdInitStructure.SDIO_Argument = SD_CHECK_PATTERN;
  SDIO_CmdInitStructure.SDIO_CmdIndex = SDIO_SEND_IF_COND;
  errorstatus = CmdResp7Error();
    CardType = SDIO_STD_CAPACITY_SD_CARD_V2_0; /*!< SD Card 2.0 */
    SDType = SD_HIGH_CAPACITY;
  else
    /*!< CMD55 */
    SDIO_CmdInitStructure.SDIO_Argument = 0x00;
    SDIO_CmdInitStructure.SDIO_CmdIndex = SD_CMD_APP_CMD;
    errorstatus = CmdResp1Error(SD_CMD_APP_CMD);
  /*!< CMD55 */
  /*!< If errorstatus is Command TimeOut, it is a MMC card */
  /*!< If errorstatus is SD_OK it is a SD card: SD card 2.0 (voltage range mismatch)
     or SD card 1.x */
    /*!< SD CARD */
    /*!< Send ACMD41 SD_APP_OP_COND with Argument 0x80100000 */
    while ((!validvoltage) && (count < SD_MAX_VOLT_TRIAL))
      /*!< SEND CMD55 APP_CMD with RCA as 0 */
      SDIO_CmdInitStructure.SDIO_Argument = SD_VOLTAGE_WINDOW_SD | SDType;
      SDIO_CmdInitStructure.SDIO_CmdIndex = SD_CMD_SD_APP_OP_COND;
      errorstatus = CmdResp3Error();
      response = SDIO_GetResponse(SDIO_RESP1);
      validvoltage = (((response >> 31) == 1) ? 1 : 0);
      count++;
    if (count >= SD_MAX_VOLT_TRIAL)
      errorstatus = SD_INVALID_VOLTRANGE;
    if (response &= SD_HIGH_CAPACITY)
      CardType = SDIO_HIGH_CAPACITY_SD_CARD;
  }/*!< else MMC Card */
  * @brief  Turns the SDIO output signals off.
  * @param  None
SD_Error SD_PowerOFF(void)
  /*!< Set Power State to OFF */
  SDIO_SetPowerState(SDIO_PowerState_OFF);
  * @brief  Intialises all cards or single card as the case may be Card(s) come
  *         into standby state.
  * @param  None
SD_Error SD_InitializeCards(void)
  uint16_t rca = 0x01;
  if (SDIO_GetPowerState() == SDIO_PowerState_OFF)
  if (SDIO_SECURE_DIGITAL_IO_CARD != CardType)
    /*!< Send CMD2 ALL_SEND_CID */
    SDIO_CmdInitStructure.SDIO_CmdIndex = SD_CMD_ALL_SEND_CID;
    SDIO_CmdInitStructure.SDIO_Response = SDIO_Response_Long;
    errorstatus = CmdResp2Error();
    CID_Tab[0] = SDIO_GetResponse(SDIO_RESP1);
    CID_Tab[1] = SDIO_GetResponse(SDIO_RESP2);
    CID_Tab[2] = SDIO_GetResponse(SDIO_RESP3);
    CID_Tab[3] = SDIO_GetResponse(SDIO_RESP4);
  if ((SDIO_STD_CAPACITY_SD_CARD_V1_1 == CardType) ||  (SDIO_STD_CAPACITY_SD_CARD_V2_0 == CardType) ||  (SDIO_SECURE_DIGITAL_IO_COMBO_CARD == CardType)
    /*!< Send CMD3 SET_REL_ADDR with argument 0 */
    /*!< SD Card publishes its RCA. */
    SDIO_CmdInitStructure.SDIO_CmdIndex = SD_CMD_SET_REL_ADDR;
    errorstatus = CmdResp6Error(SD_CMD_SET_REL_ADDR, &rca);
    RCA = rca;
    /*!< Send CMD9 SEND_CSD with argument as card's RCA */
    SDIO_CmdInitStructure.SDIO_Argument = (uint32_t)(rca << 16);
    SDIO_CmdInitStructure.SDIO_CmdIndex = SD_CMD_SEND_CSD;
    CSD_Tab[0] = SDIO_GetResponse(SDIO_RESP1);
    CSD_Tab[1] = SDIO_GetResponse(SDIO_RESP2);
    CSD_Tab[2] = SDIO_GetResponse(SDIO_RESP3);
    CSD_Tab[3] = SDIO_GetResponse(SDIO_RESP4);
  errorstatus = SD_OK; /*!< All cards get intialized */
  * @brief  Returns information about specific card.
  * @param  cardinfo: pointer to a SD_CardInfo structure that contains all SD card
  *         information.
SD_Error SD_GetCardInfo(SD_CardInfo *cardinfo)
  uint8_t tmp = 0;
  cardinfo->CardType = (uint8_t)CardType;
  cardinfo->RCA = (uint16_t)RCA;
  /*!< Byte 0 */
  /*!< Byte 1 */
  /*!< Byte 2 */
  /*!< Byte 3 */
  /*!< Byte 4 */
  cardinfo->SD_csd.CardComdClasses = tmp << 4;
  /*!< Byte 5 */
  tmp = (uint8_t)((CSD_Tab[1] & 0x00FF0000) >> 16);
  /*!< Byte 6 */
    cardinfo->SD_csd.DeviceSize = (tmp & 0x03) << 10;
    /*!< Byte 7 */
    cardinfo->SD_csd.DeviceSize |= (tmp) << 2;
    /*!< Byte 8 */
    tmp = (uint8_t)((CSD_Tab[2] & 0xFF000000) >> 24);
    /*!< Byte 9 */
    cardinfo->SD_csd.DeviceSizeMul = (tmp & 0x03) << 1;
    /*!< Byte 10 */
    cardinfo->CardCapacity *= (1 << (cardinfo->SD_csd.DeviceSizeMul + 2));
    cardinfo->CardBlockSize = 1 << (cardinfo->SD_csd.RdBlockLen);
    /*!< Byte 7 */
    cardinfo->SD_csd.DeviceSize = (tmp & 0x3F) << 16;
    /*!< Byte 8 */
    cardinfo->SD_csd.DeviceSize |= (tmp << 8);
    /*!< Byte 9 */
    /*!< Byte 10 */
  cardinfo->SD_csd.EraseGrMul = (tmp & 0x3F) << 1;
  /*!< Byte 11 */
  tmp = (uint8_t)(CSD_Tab[2] & 0x000000FF);
  cardinfo->SD_csd.EraseGrMul |= (tmp & 0x80) >> 7;
  /*!< Byte 12 */
  cardinfo->SD_csd.MaxWrBlockLen = (tmp & 0x03) << 2;
  /*!< Byte 13 */
  tmp = (uint8_t)((CSD_Tab[3] & 0x00FF0000) >> 16);
  /*!< Byte 14 */
  /*!< Byte 15 */
  /*!< Byte 0 */
  /*!< Byte 1 */
  cardinfo->SD_cid.OEM_AppliID = tmp << 8;
  /*!< Byte 2 */
  tmp = (uint8_t)((CID_Tab[0] & 0x000000FF00) >> 8);
  /*!< Byte 3 */
  cardinfo->SD_cid.ProdName1 = tmp << 24;
  /*!< Byte 4 */
  tmp = (uint8_t)((CID_Tab[1] & 0xFF000000) >> 24);
  cardinfo->SD_cid.ProdName1 |= tmp << 16;
  /*!< Byte 5 */
  tmp = (uint8_t)((CID_Tab[1] & 0x00FF0000) >> 16);
  cardinfo->SD_cid.ProdName1 |= tmp << 8;
  /*!< Byte 6 */
  tmp = (uint8_t)((CID_Tab[1] & 0x0000FF00) >> 8);
  /*!< Byte 7 */
  /*!< Byte 8 */
  /*!< Byte 9 */
  cardinfo->SD_cid.ProdSN = tmp << 24;
  /*!< Byte 10 */
  tmp = (uint8_t)((CID_Tab[2] & 0x0000FF00) >> 8);
  cardinfo->SD_cid.ProdSN |= tmp << 16;
  /*!< Byte 11 */
  tmp = (uint8_t)(CID_Tab[2] & 0x000000FF);
  cardinfo->SD_cid.ProdSN |= tmp << 8;
  /*!< Byte 12 */
  tmp = (uint8_t)((CID_Tab[3] & 0xFF000000) >> 24);
  /*!< Byte 13 */
  cardinfo->SD_cid.ManufactDate = (tmp & 0x0F) << 8;
  /*!< Byte 14 */
  tmp = (uint8_t)((CID_Tab[3] & 0x0000FF00) >> 8);
  /*!< Byte 15 */
  *         card.
  uint8_t tmp = 0;
  /*!< Byte 0 */
  /*!< Byte 0 */
  /*!< Byte 2 */
  cardstatus->SD_CARD_TYPE = tmp << 8;
  /*!< Byte 3 */
  tmp = (uint8_t)((SDSTATUS_Tab[3] & 0xFF));
  cardstatus->SD_CARD_TYPE |= tmp;
  /*!< Byte 4 */
  cardstatus->SIZE_OF_PROTECTED_AREA = tmp << 24;
  /*!< Byte 5 */
  tmp = (uint8_t)(SDSTATUS_Tab[5] & 0xFF);
  cardstatus->SIZE_OF_PROTECTED_AREA |= tmp << 16;
  /*!< Byte 6 */
  tmp = (uint8_t)(SDSTATUS_Tab[6] & 0xFF);
  cardstatus->SIZE_OF_PROTECTED_AREA |= tmp << 8;
  /*!< Byte 7 */
  tmp = (uint8_t)(SDSTATUS_Tab[7] & 0xFF);
  cardstatus->SIZE_OF_PROTECTED_AREA |= tmp;
  /*!< Byte 8 */
  /*!< Byte 9 */
  /*!< Byte 10 */
  /*!< Byte 11 */
  cardstatus->ERASE_SIZE = tmp << 8;
  /*!< Byte 12 */
  tmp = (uint8_t)(SDSTATUS_Tab[12] & 0xFF);
  cardstatus->ERASE_SIZE |= tmp;
  /*!< Byte 13 */
  /*!< Byte 13 */
  *         card.
    else
#endif
  TransferEnd = 0;
  StopCondition = 0;
  SDIO->DCTRL = 0x0;
    BlockSize = 512;
    ReadAddr /= 512;
  SDIO_DataInitStructure.SDIO_DataBlockSize = (uint32_t) 9 << 4;
  SDIO_DataInitStructure.SDIO_TransferDir = SDIO_TransferDir_ToSDIO;
  SDIO_DataInitStructure.SDIO_TransferMode = SDIO_TransferMode_Block;
  SDIO_DataInitStructure.SDIO_DPSM = SDIO_DPSM_Enable;
  SDIO_DataConfig(&SDIO_DataInitStructure);
  /*!< Send CMD17 READ_SINGLE_BLOCK */
  SDIO_CmdInitStructure.SDIO_Argument = (uint32_t)ReadAddr;
  SDIO_CmdInitStructure.SDIO_CmdIndex = SD_CMD_READ_SINGLE_BLOCK;
  errorstatus = CmdResp1Error(SD_CMD_READ_SINGLE_BLOCK);
  /*!< In case of single block transfer, no need of stop transfer at all.*/
  /*!< Polling mode */
  while (!(SDIO->STA &(SDIO_FLAG_RXOVERR | SDIO_FLAG_DCRCFAIL | SDIO_FLAG_DTIMEOUT | SDIO_FLAG_DBCKEND | SDIO_FLAG_STBITERR)))
      tempbuff += 8;
    tempbuff++;
#endif
  TransferEnd = 0;
  StopCondition = 1;
  SDIO->DCTRL = 0x0;
    BlockSize = 512;
    ReadAddr /= 512;
  /*!< Send CMD18 READ_MULT_BLOCK with argument data address */
  SDIO_CmdInitStructure.SDIO_CmdIndex = SD_CMD_READ_MULT_BLOCK;
  errorstatus = CmdResp1Error(SD_CMD_READ_MULT_BLOCK);
  SD_LowLevel_DMA_RxConfig((uint32_t *)readbuff, (NumberOfBlocks * BlockSize));
  * @brief  This function waits until the SDIO DMA data transfer is finished.
  *         This function should be called after SDIO_ReadMultiBlocks() function
  *         to insure that all data sent by the card are already transferred by
  *         the DMA controller.
  * @param  None.
SD_Error SD_WaitReadOperation(void)
  while ((SD_DMAEndOfTransferStatus() == RESET) && (TransferEnd == 0) && (TransferError == SD_OK))
  if (TransferError != SD_OK)
    return(TransferError);
  * @brief  Allows to write one block starting from a specified address in a card.
  *         The Data transfer can be managed by DMA mode or Polling mode.
SD_Error SD_WriteBlock(uint8_t *writebuff, uint32_t WriteAddr, uint16_t BlockSize)
  uint32_t bytestransferred = 0, count = 0, restwords = 0;
  uint32_t *tempbuff = (uint32_t *)writebuff;
#endif
  TransferEnd = 0;
  StopCondition = 0;
  SDIO->DCTRL = 0x0;
    BlockSize = 512;
    WriteAddr /= 512;
  SDIO_DataInitStructure.SDIO_TransferDir = SDIO_TransferDir_ToCard;
  /*!< In case of single data block transfer no need of stop command at all */
  while (!(SDIO->STA & (SDIO_FLAG_DBCKEND | SDIO_FLAG_TXUNDERR | SDIO_FLAG_DCRCFAIL | SDIO_FLAG_DTIMEOUT | SDIO_FLAG_STBITERR)))
      else
        tempbuff += 8;
#endif
  TransferEnd = 0;
  StopCondition = 1;
  SDIO->DCTRL = 0x0;
    BlockSize = 512;
    WriteAddr /= 512;
  SDIO_CmdInitStructure.SDIO_Argument = (uint32_t) (RCA << 16);
  SDIO_CmdInitStructure.SDIO_Argument = (uint32_t)NumberOfBlocks;
  SDIO_CmdInitStructure.SDIO_CmdIndex = SD_CMD_SET_BLOCK_COUNT;
  errorstatus = CmdResp1Error(SD_CMD_SET_BLOCK_COUNT);
  /*!< Send CMD25 WRITE_MULT_BLOCK with argument data address */
  SDIO_CmdInitStructure.SDIO_Argument = (uint32_t)WriteAddr;
  SDIO_CmdInitStructure.SDIO_CmdIndex = SD_CMD_WRITE_MULT_BLOCK;
  errorstatus = CmdResp1Error(SD_CMD_WRITE_MULT_BLOCK);
  SD_LowLevel_DMA_TxConfig((uint32_t *)writebuff, (NumberOfBlocks * BlockSize));
  *         This function should be called after SDIO_WriteBlock() and
  *         SDIO_WriteMultiBlocks() function to insure that all data sent by the
  *         card are already transferred by the DMA controller.
  * @param  None.
SD_Error SD_WaitWriteOperation(void)
  * @brief  Gets the cuurent data transfer state.
  * @param  None
SDTransferState SD_GetTransferState(void)
  if (SDIO->STA & (SDIO_FLAG_TXACT | SDIO_FLAG_RXACT))
  else
  * @brief  Aborts an ongoing data transfer.
  * @param  None
SD_Error SD_StopTransfer(void)
  /*!< Send CMD12 STOP_TRANSMISSION  */
  SDIO->ARG = 0x0;
  SDIO->CMD = 0x44C;
  uint32_t delay = 0;
    startaddr /= 512;
    endaddr /= 512;
  SDIO->ARG = (uint32_t) RCA << 16;
  SDIO->CMD = 0x44D;
  uint32_t count = 0;
  /*!< CMD55 */
  SDIO_CmdInitStructure.SDIO_Argument = (uint32_t) RCA << 16;
  SDIO_DataInitStructure.SDIO_DataLength = 64;
  SDIO_DataInitStructure.SDIO_DataBlockSize = SDIO_DataBlockSize_64b;
  /*!< Send ACMD13 SD_APP_STAUS  with argument as card's RCA.*/
  SDIO_CmdInitStructure.SDIO_CmdIndex = SD_CMD_SD_APP_STAUS;
  errorstatus = CmdResp1Error(SD_CMD_SD_APP_STAUS);
        *(psdstatus + count) = SDIO_ReadData();
      psdstatus += 8;
    *psdstatus = SDIO_ReadData();
    psdstatus++;
  /*!< Clear all the static status flags*/
  * @brief  Allows to process all the interrupts that are high.
  * @param  None
SD_Error SD_ProcessIRQSrc(void)
  if (StopCondition == 1)
    SDIO->ARG = 0x0;
    SDIO->CMD = 0x44C;
    TransferError = CmdResp1Error(SD_CMD_STOP_TRANSMISSION);
  else
  SDIO_ClearITPendingBit(SDIO_IT_DATAEND);
  SDIO_ITConfig(SDIO_IT_DATAEND, DISABLE);
  TransferEnd = 1;
  * @brief  Checks for error conditions for CMD0.
  * @param  None
  uint32_t timeout;
  timeout = SDIO_CMD0TIMEOUT; /*!< 10000 */
  while ((timeout > 0) && (SDIO_GetFlagStatus(SDIO_FLAG_CMDSENT) == RESET))
    timeout--;
  if (timeout == 0)
    errorstatus = SD_CMD_RSP_TIMEOUT;
  * @brief  Checks for error conditions for R7 response.
  * @param  None
  uint32_t status;
  uint32_t timeout = SDIO_CMD0TIMEOUT;
  status = SDIO->STA;
  while (!(status & (SDIO_FLAG_CCRCFAIL | SDIO_FLAG_CMDREND | SDIO_FLAG_CTIMEOUT)) && (timeout > 0))
    timeout--;
    status = SDIO->STA;
  if ((timeout == 0) || (status & SDIO_FLAG_CTIMEOUT))
    /*!< Card is not V2.0 complient or card does not support the set voltage range */
    SDIO_ClearFlag(SDIO_FLAG_CTIMEOUT);
  if (status & SDIO_FLAG_CMDREND)
    /*!< Card is SD V2.0 compliant */
    SDIO_ClearFlag(SDIO_FLAG_CMDREND);
  * @brief  Checks for error conditions for R1 response.
  * @param  cmd: The sent command index.
  while (!(SDIO->STA & (SDIO_FLAG_CCRCFAIL | SDIO_FLAG_CMDREND | SDIO_FLAG_CTIMEOUT)))
  SDIO->ICR = SDIO_STATIC_FLAGS;
  return (SD_Error)(SDIO->RESP1 &  SD_OCR_ERRORBITS);
  * @brief  Checks for error conditions for R3 (OCR) response.
  * @param  None
  uint32_t status;
  status = SDIO->STA;
  while (!(status & (SDIO_FLAG_CCRCFAIL | SDIO_FLAG_CMDREND | SDIO_FLAG_CTIMEOUT)))
    status = SDIO->STA;
  if (status & SDIO_FLAG_CTIMEOUT)
  * @brief  Checks for error conditions for R2 (CID or CSD) response.
  * @param  None
  uint32_t status;
  status = SDIO->STA;
  while (!(status & (SDIO_FLAG_CCRCFAIL | SDIO_FLAG_CTIMEOUT | SDIO_FLAG_CMDREND)))
    status = SDIO->STA;
  else if (status & SDIO_FLAG_CCRCFAIL)
    errorstatus = SD_CMD_CRC_FAIL;
    SDIO_ClearFlag(SDIO_FLAG_CCRCFAIL);
  * @brief  Checks for error conditions for R6 (RCA) response.
  * @param  prca: pointer to the variable that will contain the SD card relative
  *         address RCA.
  uint32_t status;
  uint32_t response_r1;
  status = SDIO->STA;
    status = SDIO->STA;
  /*!< Check response received is of desired command */
  if (SDIO_GetCommandResponse() != cmd)
    errorstatus = SD_ILLEGAL_CMD;
  /*!< We have received response, retrieve it.  */
  response_r1 = SDIO_GetResponse(SDIO_RESP1);
  if (SD_ALLZERO == (response_r1 & (SD_R6_GENERAL_UNKNOWN_ERROR | SD_R6_ILLEGAL_CMD | SD_R6_COM_CRC_FAILED)))
    *prca = (uint16_t) (response_r1 >> 16);
  if (response_r1 & SD_R6_GENERAL_UNKNOWN_ERROR)
    return(SD_GENERAL_UNKNOWN_ERROR);
  if (response_r1 & SD_R6_ILLEGAL_CMD)
    return(SD_ILLEGAL_CMD);
  if (response_r1 & SD_R6_COM_CRC_FAILED)
    return(SD_COM_CRC_FAILED);
  * @brief  Enables or disables the SDIO wide bus mode.
  * @param  NewState: new state of the SDIO wide bus mode.
  *   This parameter can be: ENABLE or DISABLE.
  uint32_t scr[2] = {0, 0};
  /*!< Get SCR Register */
  errorstatus = FindSCR(RCA, scr);
  /*!< If wide bus operation to be enabled */
  if (NewState == ENABLE)
    /*!< If requested card supports wide bus operation */
    if ((scr[1] & SD_WIDE_BUS_SUPPORT) != SD_ALLZERO)
      /*!< Send CMD55 APP_CMD with argument as card's RCA.*/
      /*!< Send ACMD6 APP_CMD with argument as 2 for wide bus mode */
      SDIO_CmdInitStructure.SDIO_Argument = 0x2;
      SDIO_CmdInitStructure.SDIO_CmdIndex = SD_CMD_APP_SD_SET_BUSWIDTH;
      errorstatus = CmdResp1Error(SD_CMD_APP_SD_SET_BUSWIDTH);
    else
  }   /*!< If wide bus operation to be disabled */
  else
    /*!< If requested card supports 1 bit mode operation */
    if ((scr[1] & SD_SINGLE_BUS_SUPPORT) != SD_ALLZERO)
    else
  * @brief  Checks if the SD card is in programming state.
  * @param  pstatus: pointer to the variable that will contain the SD card state.
  __IO uint32_t respR1 = 0, status = 0;
  SDIO_CmdInitStructure.SDIO_CmdIndex = SD_CMD_SEND_STATUS;
  status = SDIO->STA;
    status = SDIO->STA;
  status = (uint32_t)SDIO_GetCommandResponse();
  if (status != SD_CMD_SEND_STATUS)
  /*!< We have received response, retrieve it for analysis  */
  respR1 = SDIO_GetResponse(SDIO_RESP1);
  /*!< Find out card status */
  *pstatus = (uint8_t) ((respR1 >> 9) & 0x0000000F);
  if ((respR1 & SD_OCR_ERRORBITS) == SD_ALLZERO)
  if (respR1 & SD_OCR_ADDR_OUT_OF_RANGE)
    return(SD_ADDR_OUT_OF_RANGE);
  if (respR1 & SD_OCR_ADDR_MISALIGNED)
    return(SD_ADDR_MISALIGNED);
  if (respR1 & SD_OCR_BLOCK_LEN_ERR)
    return(SD_BLOCK_LEN_ERR);
  if (respR1 & SD_OCR_ERASE_SEQ_ERR)
    return(SD_ERASE_SEQ_ERR);
  if (respR1 & SD_OCR_BAD_ERASE_PARAM)
    return(SD_BAD_ERASE_PARAM);
  if (respR1 & SD_OCR_WRITE_PROT_VIOLATION)
    return(SD_WRITE_PROT_VIOLATION);
  if (respR1 & SD_OCR_LOCK_UNLOCK_FAILED)
    return(SD_LOCK_UNLOCK_FAILED);
  if (respR1 & SD_OCR_COM_CRC_FAILED)
  if (respR1 & SD_OCR_ILLEGAL_CMD)
  if (respR1 & SD_OCR_CARD_ECC_FAILED)
    return(SD_CARD_ECC_FAILED);
  if (respR1 & SD_OCR_CC_ERROR)
    return(SD_CC_ERROR);
  if (respR1 & SD_OCR_GENERAL_UNKNOWN_ERROR)
  if (respR1 & SD_OCR_STREAM_READ_UNDERRUN)
    return(SD_STREAM_READ_UNDERRUN);
  if (respR1 & SD_OCR_STREAM_WRITE_OVERRUN)
    return(SD_STREAM_WRITE_OVERRUN);
  if (respR1 & SD_OCR_CID_CSD_OVERWRIETE)
    return(SD_CID_CSD_OVERWRITE);
  if (respR1 & SD_OCR_WP_ERASE_SKIP)
    return(SD_WP_ERASE_SKIP);
  if (respR1 & SD_OCR_CARD_ECC_DISABLED)
    return(SD_CARD_ECC_DISABLED);
  if (respR1 & SD_OCR_ERASE_RESET)
    return(SD_ERASE_RESET);
  if (respR1 & SD_OCR_AKE_SEQ_ERROR)
    return(SD_AKE_SEQ_ERROR);
  * @brief  Find the SD card SCR register value.
  * @param  rca: selected card address.
  * @param  pscr: pointer to the buffer that will contain the SCR value.
  uint32_t index = 0;
  uint32_t tempscr[2] = {0, 0};
  /*!< Set Block Size To 8 Bytes */
  /*!< Send CMD55 APP_CMD with argument as card's RCA */
  SDIO_CmdInitStructure.SDIO_Argument = (uint32_t)8;
  SDIO_DataInitStructure.SDIO_DataLength = 8;
  SDIO_DataInitStructure.SDIO_DataBlockSize = SDIO_DataBlockSize_8b;
  /*!< Send ACMD51 SD_APP_SEND_SCR with argument as 0 */
  SDIO_CmdInitStructure.SDIO_CmdIndex = SD_CMD_SD_APP_SEND_SCR;
  errorstatus = CmdResp1Error(SD_CMD_SD_APP_SEND_SCR);
  while (!(SDIO->STA & (SDIO_FLAG_RXOVERR | SDIO_FLAG_DCRCFAIL | SDIO_FLAG_DTIMEOUT | SDIO_FLAG_DBCKEND | SDIO_FLAG_STBITERR)))
    if (SDIO_GetFlagStatus(SDIO_FLAG_RXDAVL) != RESET)
      *(tempscr + index) = SDIO_ReadData();
      index++;
  *(pscr + 1) = ((tempscr[0] & SD_0TO7BITS) << 24) | ((tempscr[0] & SD_8TO15BITS) << 8) | ((tempscr[0] & SD_16TO23BITS) >> 8) | ((tempscr[0] & SD_24TO31BITS) >> 24);
  *(pscr) = ((tempscr[1] & SD_0TO7BITS) << 24) | ((tempscr[1] & SD_8TO15BITS) << 8) | ((tempscr[1] & SD_16TO23BITS) >> 8) | ((tempscr[1] & SD_24TO31BITS) >> 24);
  * @brief  Converts the number of bytes in power of two and returns the power.
  * @param  NumberOfBytes: number of bytes.
  * @retval None
  uint8_t count = 0;
  while (NumberOfBytes != 1)
    NumberOfBytes >>= 1;
    count++;
  return(count);
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
此帖出自单片机论坛
开源项目 更多>>
