2201|2
MSP430G2231 ACLK SMCLK输出问题 [复制链接]
我的源代码如下,问题是P1.0和P1.4输出脉冲频率都一样只有0.87Hz,而且相位相差180度,请问高手是怎么回事,谢谢了:
#include "io430.h"
#include "io430G2231.h"
int main( void )
  // Stop watchdog timer to prevent time out reset
  WDTCTL   =   WDTPW + WDTHOLD;
  DCOCTL   =   DCO0  + DCO1;  //+ DCO2;                //设置DCO=7
  BCSCTL1 &= ~(RSEL0 + RSEL1 + RSEL2 + RSEL3);         //设置RSEL=0,DCO设置为120KHz
  BCSCTL1 &= ~ XTS;                                    //设置LFXT1进入低频模式(VLO使用前提条件)
  BCSCTL1 |=   XT2OFF;                                 //关闭XT2
  BCSCTL2 &= ~(SELM0 + SELM1);                         //设置 MCLK来源于DCO
  BCSCTL2 &= ~ SELS;                                   //设置SMCLK来源于DCO
  BCSCTL2 |=   DIVS0 + DIVS1;                          //设置SMCLK 8分频
  BCSCTL3 |=   LFXT1S1;                                //使用 VLO
  BCSCTL3 &= ~ LFXT1S0;
  P1DIR   |=   P0 + P4;                                //设置P1.0 1.4为输出
  P1SEL   |=   P0 + P4;                                //设置P1.0输出ACLK,P1.4输出SMCLK
  while(1)                                             //无限次while循环
楼主你的是P0 + P4 不是P1.0+P1.4(其实应该使用BIT0+BIT4)  详情 回复 发表于 2013-9-5 01:33
1729
BIT0+BIT4已经试过了,io430G2231.h里面有定义
  P0              = 0x0001,
  P1              = 0x0002,
  P2              = 0x0004,
  P3              = 0x0008,
  P4              = 0x0010,
  P5              = 0x0020,
  P6              = 0x0040,
  P7              = 0x0080
