3697|3
27
UART的有時候收不到? [复制链接]
我使用TI提供的USCI UART ECHO範例程式,
使用超級終端機與MSP430做UART傳輸。
但,有時會遇到按下鍵盤卻沒有回傳,
手觸摸GND後,便能順利傳輸,
請問高手們,這是什麼問題?
接觸不良?還是另有其原因?
拜託幫忙解決...
感激!!!
手觸摸GND後,便能順利傳輸, 得是硬件问题,没有公地?  详情 回复 发表于 2012-12-27 09:47
2781
419
电平问题?
我po程式碼。 //****************************************************************************** // MSP430G2xx3 Demo - USCI_A0, Ultra-Low Pwr UART 9600 String, 32kHz ACLK // // Description: Th  详情 回复 发表于 2012-12-26 11:38
27
回复 沙发 qinkaiabc 的帖子
我po程式碼。
//   Description: This program demonstrates a full-duplex 9600-baud UART using
//   USCI_A0 and a 32kHz crystal.  The program will wait in LPM3, and will
//   respond to a received 'u' character using 8N1 protocol. The response will
//   be the string 'Hello World'.
//   ACLK = BRCLK = LFXT1 = 32768Hz, MCLK = SMCLK = DCO ~1.2MHz
//   Baud rate divider with 32768Hz XTAL @9600 = 32768Hz/9600 = 3.41
//* An external watch crystal is required on XIN XOUT for ACLK *//
//                MSP430G2xx3
//         /|\|              XIN|-
//          | |                 | 32kHz
//          --|RST          XOUT|-
//            |     P1.2/UCA0TXD|------------>
//            |                 | 9600 - 8N1
//            |     P1.1/UCA0RXD|<------------
//   D. Dang
//   Texas Instruments Inc.
//   February 2011
//   Built with CCS Version 4.2.0 and IAR Embedded Workbench Version: 5.10
#include  "msp430g2553.h"
const char string1[] = { "Hello World\r\n" };
unsigned int i;
void main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  P1DIR = 0xFF;                             // All P1.x outputs
  P1OUT = 0;                                // All P1.x reset
  P2DIR = 0xFF;                             // All P2.x outputs
  P2OUT = 0;                                // All P2.x reset
  P1SEL = BIT1 + BIT2 ;                     // P1.1 = RXD, P1.2=TXD
  P1SEL2 = BIT1 + BIT2 ;                     // P1.1 = RXD, P1.2=TXD
  P3DIR = 0xFF;                             // All P3.x outputs
  P3OUT = 0;                                // All P3.x reset
  UCA0CTL1 |= UCSSEL_1;                     // CLK = ACLK
  UCA0BR0 = 0x03;                           // 32kHz/9600 = 3.41
  UCA0BR1 = 0x00;                           //
  UCA0MCTL = UCBRS1 + UCBRS0;               // Modulation UCBRSx = 3
  UCA0CTL1 &= ~UCSWRST;                     // **Initialize USCI state machine**
  IE2 |= UCA0RXIE;                          // Enable USCI_A0 RX interrupt
  __bis_SR_register(LPM3_bits + GIE);       // Enter LPM3 w/ int until Byte RXed
#pragma vector=USCIAB0TX_VECTOR
__interrupt void USCI0TX_ISR(void)
  UCA0TXBUF = string1[i++];                 // TX next character
  if (i == sizeof string1 - 1)              // TX over?
    IE2 &= ~UCA0TXIE;                       // Disable USCI_A0 TX interrupt
#pragma vector=USCIAB0RX_VECTOR
__interrupt void USCI0RX_ISR(void)
  if (UCA0RXBUF == 'u')                     // 'u' received?
    i = 0;
    IE2 |= UCA0TXIE;                        // Enable USCI_A0 TX interrupt
436
手觸摸GND後,便能順利傳輸,
得是硬件问题,没有公地?
