2716|0
g2553 2线控制液晶128*64 怎么接线呢,包括每个引脚,谢谢 [复制链接]
#include "msp430g2553.h"
#define uchar unsigned char
#define SID P2.1;
#define CLCLK P2.0;
接线:LCD12864的5脚接P2.1
      LCD12864的6脚接P2.0
      LCD12864的4引脚直接接VCC
#define SID_1 P2OUT|=0x02;
#define SID_0 P2OUT&=~0x02;
#define CLK_1 P2OUT|=0x01;
#define CLK_0 P2OUT&=~0x01;
#define nop _NOP();
char tab[]={'0','1','2','3','4','5','6','7','8','9','a','b','c','d','e','f'};
//#define nop   __no_operation();//可以用这个代替的
void W_str(uchar x,uchar y,uchar *s);
void write_com(uchar x);
void write_data(uchar x);
void write_string(uchar x,uchar y,uchar *s);
void delay(uchar z)
        uchar x,y;
        for(x=z;x>0;x--)
                for(y=20;y>0;y--);
void W_8bits(uchar W_bits)
  uchar i,temp;
  for(i=0;i<8;i++)
    temp=W_bits;
    temp<<=i;
    if((temp&0x80)==0)
      SID_0;
      nop;
      CLK_1;
      nop;
      nop;
      CLK_0;
      nop;
      SID_0;
    else
      SID_1;
      nop;
      CLK_1;
      nop;
      nop;
      CLK_0;
      nop;
      SID_0;
  rw=1  则表示读出
  rw=0  则表示输入
  rs=1  则表示写数据
  rs=0  则表示写命令
  W_byte(0,0,x)写命令x;
  W_byte(0,1,y)写数据y;
void W_byte(uchar rw,uchar rs,uchar W_data)
  uchar H_data,L_data,s_id=0xf8;
  if(rw==0)
    s_id&=~0x04;
  else
    s_id|=0x04;
  if(rs==0)
    s_id&=~0x02;
  else
      s_id|=0x02;
  H_data=W_data;
  H_data&=0xf0;
  L_data=W_data;
  L_data&=0x0f;
  L_data<<=4;
  W_8bits(s_id);
  W_8bits(H_data);
  W_8bits(L_data);
void lcdinit()
  delay(10);
  W_byte(0,0,0x38);
  delay(5);
  W_byte(0,0,0x38);
  delay(5);
  W_byte(0,0,0x0c);
  delay(5);
  W_byte(0,0,0x01);
  delay(5);
  W_byte(0,0,0x02);
  delay(5);
  W_byte(0,0,0x80);
  delay(5);
void main( void )
  // Stop watchdog timer to prevent time out reset
  WDTCTL = WDTPW + WDTHOLD;
//  unsigned int j;
//  char i;
//  SP=0x60;//51中必须要的,为什么?
  P2DIR=0x03;//就是少了这条指令,导致研究好久!!!
//  CS_0;
//  P2OUT|=~BIT2;
  CLK_0;
  SID_0;
  lcdinit();
//  W_byte(0,1,0x30);说明,这个是说,LCD显示只认识ASCII码
  W_str(0,0,"MSP430G2553");
//  W_byte(0,0,0x88);//可以用这种方式写指令
//  W_str(1,2,"22:52");
  write_string(3,4,"Launch Pad");
  W_str(0,2,"长江大学");
  W_str(2,3,"创新基地");
  write_com(0x98);
  write_data(tab[2]);
  while(1);
/* while(1)
  for(i=0;i<16;i++);
      W_byte(0,0,0x98);
      for(j=0;j<60000;j++);
      W_byte(0,1,tab);
/*很神奇的一个函数,可以输入字符串,不管是汉字还是字母表*/
  x代表偏移量
  y代表第几行
  *S是字符串的指针
  switch(y)
  case 1:W_byte(0,0,0x80+x);break;//0x80是第一行起始位置
  case 2:W_byte(0,0,0x90+x);break;//0x90是第二行起始位置
  case 3:W_byte(0,0,0x88+x);break;//0x88是第三行起始位置
  case 4:W_byte(0,0,0x98+x);break;//0x98是第四行起始位置
  default:W_byte(0,0,0x80+x);//否则都当成第一行处理
  while(*s)
    W_byte(0,1,*s);
    s++;
  W_byte(0,0,x);
  W_byte(0,1,x);
  switch(y)
  while(*s)
    W_byte(0,1,*s);
    s++;
