2742|1
459
37
VGA转USB [复制链接]
还在发愁笔记本上的USB插头不足吗?现在有VGA转USB接口卖了。
当然,只是供电而已
VGA DDC2 connector pinout:
Pin Name Dir Description
1 RED --> Red Video (75 ohm, 0.7 V p-p)
2 GREEN --> Green Video (75 ohm, 0.7 V p-p)
3 BLUE --> Blue Video (75 ohm, 0.7 V p-p)
4 RES   RESERVED
5 GND --- Ground
6 RGND --- Red Ground
7 GGND --- Green Ground
8 BGND --- Blue Ground
9 KEY - Key (No pin) / Optional +5V output from graphics card
10 SGND --- Sync Ground
11 ID0 <-- Monitor ID Bit 0 (optional)
12 SDA <-- I2C bidirectional data line
13 HSYNC or CSYNC --> Horizontal Sync (or Composite Sync)
14 VSYNC --> Vertical Sync which works also as data clock
15 SCL <-- I2C data clock in DDC2, Monitor ID3 in DDC1
主要利用Pin9的5V电压
此帖出自创意市集论坛
 折腾一番只是为了取个5V电源?可怜的笔记本!  详情 回复 发表于 2012-4-19 15:23
3138
裸片初长成(初级)
插个U盘不怕误导吗?
此帖出自创意市集论坛
