启动文件中配置:
; If you need to use external SRAM mounted on STM3210E-EVAL board as data memory,
; change the following define value to '1' (or choose ENABLE in Configuration Wizard window)
;// <o> External SRAM Configuration <0=> DISABLE <1=> ENABLE
DATA_IN_ExtSRAM EQU 1
; Amount of memory (in bytes) allocated for Stack
; Tailor this value to your application needs
;// <h> Stack Configuration
;// <o> Stack Size (in Bytes) <0x0-0xFFFFFFFF:8>
;// </h>
Stack_Size EQU 0x00000400
AREA STACK, NOINIT, READWRITE, ALIGN=3
Stack_Mem SPACE Stack_Size
;__initial_sp
; and internal SRAM for Stack, uncomment the following line and comment the line above
__initial_sp EQU 0x20000000 + Stack_Size ; "Use MicroLIB" must be checked in
;// </h>
AREA STACK, NOINIT, READWRITE, ALIGN = 3
__initial_sp
;__initial_sp EQU 0x20000000 + Stack_Size ; "Use MicroLIB" must be checked in
; the Project->Options->Target window
; Amount of memory (in bytes) allocated for Heap
;// <h> Heap Configuration
;// <o> Heap Size (in Bytes) <0x0-0xFFFFFFFF:8>
;// </h>
