3176|4
84
(高分求救)我用T2作中断发生器,串口接收正常,发送不对 [复制链接]
我用T2作中断发生器,串口接收正常,发送不对,不知道哪个设定不比好心人帮帮忙.程序如下#include
#include
uint08 com1data[15];
uint08 point1=0;
uint08 com2data[6];
uint08 point2=0;
  uint08 sbuf[15];
void initUart(void)
{   IE=0x90;      //允许总中断和串口0的中断
     TMOD=0x20;      //定时器1工作在模式1
    //T1 用于com1波特率 9600
        switch (4)/*串口1波特率选择*/
        case 1:
         TH1=0xE8;        //1200
          TL1=0xE8;
          break;
        case 2:
          TH1=0xF4;       //2400
          TL1=0xF4;
          break;
        case 3:
          TH1=0xFA;        //4800
         TL1=0xFA;
         break;
        case 4:
         TH1=0xFD;        //9600
        TL1=0xFD;
         break;
        SCON1=0x58;   //工作在模式1,允许接收
     PCON=0x00; // SM0=0 SM1=1 在10位异步收发模式 SMOD=0 溢出速率/32
     ES1=1;    //串口1中断允许
     SCON0=0x58;      //工作在模式1,接收允许
     T2CON=0x30;  //用定时器2做串口0的波特率发生器
    //TCLK=1;
    //T2 用于com0波特率 9600
        switch (4)/*串口0波特率选择*/
        case 1:
         RCAP2H=0xFE;        //1200
          RCAP2L=0xE0;
          break;
        case 2:
          RCAP2H=0xFF;       //2400
          RCAP2L=0x70;
          break;
        case 3:
          RCAP2H=0xFF;        //4800
         RCAP2L=0xB8;
         break;
        case 4:
         RCAP2H=0xFF;        //9600
        RCAP2L=0xDC;
         break;
        case 5:
         RCAP2H=0xFF;        //19200
         RCAP2L=0xEE;
        break;
     TR2=1;
     TR1=1;
void Int_serial1() interrupt 7
    uint16 uctimes=5000;
    while((RI_1==0)&&(uctimes>0))
        uctimes--;
    if(uctimes!=0)
    {     com2data[point2]=SBUF1;
           point2++;
      RI_1=0;
void Intcom ()interrupt 4               //串口1接收
    while((RI==0)&&(uctimes>0))
        uctimes--;
    if(uctimes!=0)
    if(point1==0)
    if(SBUF==0x7e)
     com1data[point1]=SBUF;
     point1++;
    else
            point1++;
     RI=0;
void DelayMs(uint08 usTime)
    uint16  i;
    uint16  j;
    for(j=0;j     for(i=0;i<227;i++);
       void putchar(uint08 xdata *ucBuff)    //串口1发送
{     uint08 ucNum;
      for(ucNum = 0; ucNum <15; ucNum++)
        SBUF = ucBuff[ucNum];
        while (0 == TI);
        TI = 0;
void main()
{               sbuf[0] = 0x7e;
                sbuf[1] = 0x01;
                sbuf[2] = 0x00;
                sbuf[3] = 0x10;
                sbuf[4] = 0x01;
                sbuf[5] = 0x00;
                sbuf[6] = 0x12;
                sbuf[7] = 0x0d;
                sbuf[8] = 0x08;
                sbuf[9] = 0x09;
                sbuf[10] = 0x0a;
                sbuf[11] = 0x0b;
                sbuf[12] = 0x0c;
                sbuf[13] = 0x0d;
                sbuf[14] = 0x0e;// 获取实时信息
    initUart();
    while(1)
        SBUF1=1;
        if(point1==15)
                ES1=0;
               putchar(sbuf);
               ES1=1;
            point1=0;
        if(point2==6)
            point2=0;
{     uint08 ucNum;
        while (0 == TI);
        TI = 0;
数据不对
这一版块,太没人气了,是不是大家都成大侠了 如果成大侠了,也常回家看看嘛,家里太冷清了 据说努力顶帖也是一种美德,但我只想大家常回家看看 毕竟每天都有新手需要帮忙,而我能帮的只能是把帖子顶起来  详情 回复 发表于 2008-4-4 01:23
61
只发送一个数据,把Txd撬起来,用示波器量,
88
63
怎么不对?说说情况。你发给PC还是其他单片机?
