4028|5
高手入,WinCE 内存泄露, 求助!!! [复制链接]
贴代码如下. CProgressCtrlEx.cpp类的功能是做一个进度条,替代系统自带的进度条. 在使用的过程中,发现存在内存泄露. 经过测试发现,泄露发生在当OnTimer()定时器进入时, 调用SetPos()函数,重新确定进度条的位置的时候, 需要刷新进度条, 调用Invalidate()函数. 查看系统使用内存时,发现内存不断增加, 频率是5-6秒钟,增加4KB.
    求助答案,站内回信,或Email lovefornothing@live.cn
#include "stdafx.h"
#include "resource.h"
#include "ProgressCtrlEx.h"
#ifdef _DEBUG
#define new DEBUG_NEW
#undef THIS_FILE
static char THIS_FILE[] = __FILE__;
#endif
// CProgressCtrlEx
CProgressCtrlEx::CProgressCtrlEx()
        m_nProgressPos=0;
        m_penframe.CreatePen(PS_SOLID,1,RGB(0,0,0));
CProgressCtrlEx::~CProgressCtrlEx()
        m_penframe.DeleteObject();
BEGIN_MESSAGE_MAP(CProgressCtrlEx, CWnd)
        //{{AFX_MSG_MAP(CProgressCtrlEx)
        ON_WM_ERASEBKGND()
        //}}AFX_MSG_MAP
END_MESSAGE_MAP()
// CProgressCtrlEx message handlers
bool CProgressCtrlEx::RegisterWindowClass()
    WNDCLASS wndcls;
    HINSTANCE hInst = AfxGetInstanceHandle();
    if (!(::GetClassInfo(hInst, ProgressCtrlEx_CLASSNAME, &wndcls)))
        // otherwise we need to register a new class
        wndcls.style            = CS_DBLCLKS | CS_HREDRAW | CS_VREDRAW;
        wndcls.lpfnWndProc      = ::DefWindowProc;
        wndcls.cbClsExtra       = wndcls.cbWndExtra = 0;
        wndcls.hInstance        = hInst;
        wndcls.hIcon            = NULL;
        wndcls.hCursor          = NULL;
        wndcls.hbrBackground    = NULL;
        wndcls.lpszMenuName     = NULL;
        wndcls.lpszClassName    = ProgressCtrlEx_CLASSNAME;
        if (!AfxRegisterClass(&wndcls))
            AfxThrowResourceException();
            return FALSE;
        return TRUE;
bool CProgressCtrlEx::CreateCtrl(CWnd *pParent, CRect rcClient, UINT nID)
   if (!RegisterWindowClass())
                return FALSE;
        if (!Create(ProgressCtrlEx_CLASSNAME,NULL, WS_CHILD|WS_VISIBLE,CRect(rcClient.left,rcClient.top,rcClient.right,rcClient.bottom), pParent,nID,NULL))
                return FALSE;
        return TRUE;
BOOL CProgressCtrlEx::OnEraseBkgnd(CDC* pDC)
        // TODO: Add your message handler code here and/or call default
        CWnd::OnEraseBkgnd(pDC);
        CRect RectClient;
        GetClientRect(&RectClient);
    pDC->FillSolidRect(RectClient,RGB(255,255,255));
        CRect rectframe;
        rectframe.left=RectClient.left+1;
        rectframe.top=RectClient.top+1;
        rectframe.right=RectClient.right-1;
        rectframe.bottom=RectClient.bottom-1;
        CPen* poldpen;
        poldpen=pDC->SelectObject(&m_penframe);
        pDC->MoveTo(rectframe.TopLeft());
        pDC->LineTo(CPoint(rectframe.right,rectframe.top));
        pDC->LineTo(CPoint(rectframe.right,rectframe.bottom));
        pDC->LineTo(CPoint(rectframe.left,rectframe.bottom));
        pDC->LineTo(CPoint(rectframe.left,rectframe.top));
    pDC->SelectObject(poldpen);
    CRect rectfill;
        rectfill.left=rectframe.left+1;
        rectfill.top=rectframe.top+1;
        rectfill.right=rectframe.right;
        rectfill.bottom=rectframe.bottom;
        if(m_nProgressPos!=100)
                double temp1=m_nProgressPos*1.0;
                double temp2=temp1/100.0;
                int width=int(temp2*rectfill.Width());
                rectfill.right=rectfill.left+width;
        else
        pDC->FillSolidRect(rectfill,RGB(220,40,30));
//        penframe.DeleteObject();
        return true;
void CProgressCtrlEx::SetPos(int nPos)
    m_nProgressPos=nPos;
        Invalidate();
此帖出自WindowsCE论坛
如果开始运行的时候 是4K 4K慢慢增加,先不管它, 一般来说一个对象的建立和删除没有这么快,内存没有及时回收. 持续这样操作一段时间, 一两个小时后,还是一直增加就有问题了. 如果持续很长时间都是一直增加的问题就有问题.  详情 回复 发表于 2008-1-16 09:16
代码里看不出内存泄露。。。
找找其他原因
如果是4K泄露的,一般认为是对象使用完毕没有释放造成的。例如CPen 用完后没有Delete掉
此帖出自WindowsCE论坛
84
冰天雪地高空旋转720度直线下坠头朝下落地然后跪地裸求答复!!!
此帖出自WindowsCE论坛
81
发过来看看吧...+ msn wince.net@hotmail.com
此帖出自WindowsCE论坛
77
你有这能耐,厉害呀
此帖出自WindowsCE论坛
77
此帖出自WindowsCE论坛
开源项目 更多>>
