嵌入式工程师AI挑战营RV1106人脸识别+流水记录(7)PC推理
接上回,Y轴坐标偏移问题已找到,问题出在对输入图片的尺寸处理上
模型输入尺寸是640,640的,图片需要进行缩放后放入模型推理,得到输入结果后也需要按照原来图片的尺寸进行放大还原
import os
import sys
import urllib
import urllib.request
import time
import numpy as np
import cv2
import insightface
from insightface.app import FaceAnalysis
from common import Face
from image import get_image as ins_get_image
from math import ceil
from itertools import product as product
from rknn.api import RKNN
DATASET_PATH = './dataset.txt'
DEFAULT_QUANT = True
def letterbox_resize(image, size, bg_color):
letterbox_resize the image according to the specified size
:param image: input image, which can be a NumPy array or file path
:param size: target size (width, height)
:param bg_color: background filling data
:return: processed image
if isinstance(image, str):
image = cv2.imread(image)
target_width, target_height = size
image_height, image_width, _ = image.shape
# 计算调整后的图像尺寸
aspect_ratio = min(target_width / image_width, target_height / image_height)
new_width = int(image_width * aspect_ratio)
new_height = int(image_height * aspect_ratio)
# 使用 cv2.resize() 进行等比缩放
image = cv2.resize(image, (new_width, new_height), interpolation=cv2.INTER_AREA)
# 创建新的画布并进行填充
result_image = np.ones((target_height, target_width, 3), dtype=np.uint8) * bg_color
offset_x = (target_width - new_width) // 2
offset_y = (target_height - new_height) // 2
result_image[offset_y:offset_y + new_height, offset_x:offset_x + new_width] = image
return result_image, aspect_ratio, offset_x, offset_y
def PriorBox(image_size): #image_size Support (320,320) and (640,640)
anchors = []
min_sizes = [[16, 32], [64, 128], [256, 512]]
steps = [8, 16, 32]
feature_maps = [[ceil(image_size[0] / step), ceil(image_size[1] / step)] for step in steps]
for k, f in enumerate(feature_maps):
min_sizes_ = min_sizes[k]
for i, j in product(range(f[0]), range(f[1])):
for min_size in min_sizes_:
s_kx = min_size / image_size[1]
s_ky = min_size / image_size[0]
dense_cx = [x * steps[k] / image_size[1] for x in [j + 0.5]]
dense_cy = [y * steps[k] / image_size[0] for y in [i + 0.5]]
for cy, cx in product(dense_cy, dense_cx):
anchors += [cx, cy, s_kx, s_ky]
output = np.array(anchors).reshape(-1, 4)
print("image_size:",image_size," num_priors=",output.shape[0])
return output
def box_decode(loc, priors):
"""Decode locations from predictions using priors to undo
the encoding we did for offset regression at train time.
Args:
loc (tensor): location predictions for loc layers,
Shape: [num_priors,4]
priors (tensor): Prior boxes in center-offset form.
Shape: [num_priors,4].
variances: (list[float]) Variances of priorboxes
Return:
decoded bounding box predictions
variances = [0.1, 0.2]
boxes = np.concatenate((
priors[:, :2] + loc[:, :2] * variances[0] * priors[:, 2:],
priors[:, 2:] * np.exp(loc[:, 2:] * variances[1])), axis=1)
boxes[:, :2] -= boxes[:, 2:] / 2
boxes[:, 2:] += boxes[:, :2]
return boxes
def decode_landm(pre, priors):
"""Decode landm from predictions using priors to undo
Args:
pre (tensor): landm predictions for loc layers,
Shape: [num_priors,10]
Return:
decoded landm predictions
landmarks = np.concatenate((
priors[:, :2] + pre[:, :2] * variances[0] * priors[:, 2:],
priors[:, :2] + pre[:, 2:4] * variances[0] * priors[:, 2:],
priors[:, :2] + pre[:, 4:6] * variances[0] * priors[:, 2:],
priors[:, :2] + pre[:, 6:8] * variances[0] * priors[:, 2:],
priors[:, :2] + pre[:, 8:10] * variances[0] * priors[:, 2:]
), axis=1)
return landmarks
def nms(dets, thresh):
"""Pure Python NMS baseline."""
x1 = dets[:, 0]
y1 = dets[:, 1]
x2 = dets[:, 2]
y2 = dets[:, 3]
scores = dets[:, 4]
areas = (x2 - x1 + 1) * (y2 - y1 + 1)
order = scores.argsort()[::-1]
keep = []
while order.size > 0:
i = order[0]
keep.append(i)
xx1 = np.maximum(x1[i], x1[order[1:]])
yy1 = np.maximum(y1[i], y1[order[1:]])
xx2 = np.minimum(x2[i], x2[order[1:]])
yy2 = np.minimum(y2[i], y2[order[1:]])
w = np.maximum(0.0, xx2 - xx1 + 1)
h = np.maximum(0.0, yy2 - yy1 + 1)
inter = w * h
ovr = inter / (areas[i] + areas[order[1:]] - inter)
inds = np.where(ovr <= thresh)[0]
order = order[inds + 1]
return keep
def distance2bbox(points, distance, max_shape=None):
"""Decode distance prediction to bounding box.
Args:
points (Tensor): Shape (n, 2), [x, y].
distance (Tensor): Distance from the given point to 4
boundaries (left, top, right, bottom).
max_shape (tuple): Shape of the image.
Returns:
Tensor: Decoded bboxes.
x1 = points[:, 0] - distance[:, 0]
y1 = points[:, 1] - distance[:, 1]
x2 = points[:, 0] + distance[:, 2]
y2 = points[:, 1] + distance[:, 3]
if max_shape is not None:
x1 = x1.clamp(min=0, max=max_shape[1])
y1 = y1.clamp(min=0, max=max_shape[0])
x2 = x2.clamp(min=0, max=max_shape[1])
y2 = y2.clamp(min=0, max=max_shape[0])
return np.stack([x1, y1, x2, y2], axis=-1)
def distance2kps(points, distance, max_shape=None):
Args:
Returns:
preds = []
for i in range(0, distance.shape[1], 2):
px = points[:, i%2] + distance[:, i]
py = points[:, i%2+1] + distance[:, i+1]
px = px.clamp(min=0, max=max_shape[1])
py = py.clamp(min=0, max=max_shape[0])
preds.append(px)
preds.append(py)
return np.stack(preds, axis=-1)
def draw_on(img, faces):
import cv2
dimg = img.copy()
for i in range(len(faces)):
face = faces[i]
box = face.bbox.astype(int)
color = (0, 0, 255)
cv2.rectangle(dimg, (box[0], box[1]), (box[2], box[3]), color, 2)
if face.kps is not None:
kps = face.kps.astype(int)
#print(landmark.shape)
for l in range(kps.shape[0]):
color = (0, 0, 255)
if l == 0 or l == 3:
color = (0, 255, 0)
cv2.circle(dimg, (kps[l][0], kps[l][1]), 1, color,
2)
if face.gender is not None and face.age is not None:
cv2.putText(dimg,'%s,%d'%(face.sex,face.age), (box[0]-1, box[1]-4),cv2.FONT_HERSHEY_COMPLEX,0.7,(0,255,0),1)
#for key, value in face.items():
# if key.startswith('landmark_3d'):
# print(key, value.shape)
# print(value[0:10,:])
# lmk = np.round(value).astype(int)
# for l in range(lmk.shape[0]):
# color = (255, 0, 0)
# cv2.circle(dimg, (lmk[l][0], lmk[l][1]), 1, color,
# 2)
return dimg
if __name__ == '__main__':
# 创建RKNN对象
rknn = RKNN()
# 预处理设置
print('--> Config model')
rknn.config(mean_values=[[104, 117, 123]], std_values=[[1, 1, 1]], target_platform="rv1106b",
quantized_algorithm="normal",dynamic_input=[[[1,3,640,640]]], quant_img_RGB2BGR=True,remove_reshape=True,remove_weight=True,model_pruning=True) # mmse
rknn.config(mean_values=[[127.5, 127.5, 127.5]], std_values=[[128.0, 128.0, 128.0]], target_platform="rv1106b",
quant_img_RGB2BGR=False,remove_reshape=False,remove_weight=False,model_pruning=True) # mmse
print('done')
# 载入模型
print('--> Loading model')
ret = rknn.load_onnx(model="./det_10g.onnx")#,input_size_list=[[1,3,640,640]])
if ret != 0:
print('Load model failed!')
exit(ret)
print('done')
# 创建模型
print('--> Building model')
ret = rknn.build(do_quantization=True, dataset=DATASET_PATH)#,rknn_batch_size=1)
if ret != 0:
print('Build model failed!')
exit(ret)
print('done')
# 输入图像
img = cv2.imread('./test.jpg')
img_height, img_width, _ = img.shape
model_height, model_width = (640, 640)
letterbox_img, aspect_ratio, offset_x, offset_y = letterbox_resize(img, (model_height,model_width), 114) # letterbox缩放
infer_img = letterbox_img[..., ::-1] # BGR2RGB
infer_img = np.expand_dims(infer_img, 0)
print(infer_img.shape)
#img = cv2.cvtColor(img, cv2.COLOR_BGR2RGB)
img = cv2.resize(img,(640,640))
infer_img = np.expand_dims(img, 0)
input_size=(640,640)
im_ratio = float(img.shape[0]) / img.shape[1]
model_ratio = float(input_size[1]) / input_size[0]
if im_ratio>model_ratio:
new_height = input_size[1]
new_width = int(new_height / im_ratio)
else:
new_width = input_size[0]
new_height = int(new_width * im_ratio)
det_scale = float(new_height) / img.shape[0]
print(new_width,new_height)
resized_img = cv2.resize(img, (new_width, new_height))
det_img = np.zeros( (input_size[1], input_size[0], 3), dtype=np.uint8 )
det_img[:new_height, :new_width, :] = resized_img
infer_img=np.expand_dims(det_img, 0)
# 初始化运行时环境
print('--> Init runtime environment')
ret = rknn.init_runtime()
if ret != 0:
print('Init runtime environment failed!')
exit(ret)
print('done')
# 运行
print('--> Running model')
outputs = rknn.inference(inputs=[img], data_format=['nhwc'])
np.save('./onnx_resnet50v2_0.npy', outputs[0])
x = outputs[0]
output = np.exp(x)/np.sum(np.exp(x))
outputs = [output]
show_outputs(outputs)
print('done')
outputs = rknn.inference(inputs=[infer_img])#, data_format=['nhwc'])
#print (outputs)
scores_list = []
bboxes_list = []
kpss_list = []
print("forward-------------------")
input_height = 640
input_width = 640
fmc = 3
threshold=0.5
feat_stride_fpn=[8, 16, 32]
num_anchors = 2
for idx, stride in enumerate(feat_stride_fpn):
scores = outputs[idx]
bbox_preds = outputs[idx+fmc]
bbox_preds = bbox_preds * stride
kps_preds = outputs[idx+fmc*2] * stride
height = input_height // stride
width = input_width // stride
K = height * width
key = (height, width, stride)
center_cache = {}
if key in center_cache:
anchor_centers = center_cache[key]
else:
#solution-1, c style:
#anchor_centers = np.zeros( (height, width, 2), dtype=np.float32 )
#for i in range(height):
# anchor_centers[i, :, 1] = i
#for i in range(width):
# anchor_centers[:, i, 0] = i
#solution-2:
#ax = np.arange(width, dtype=np.float32)
#ay = np.arange(height, dtype=np.float32)
#xv, yv = np.meshgrid(np.arange(width), np.arange(height))
#anchor_centers = np.stack([xv, yv], axis=-1).astype(np.float32)
#solution-3:
anchor_centers = np.stack(np.mgrid[:height, :width][::-1], axis=-1).astype(np.float32)
#print(anchor_centers.shape)
anchor_centers = (anchor_centers * stride).reshape( (-1, 2) )
if num_anchors>1:
anchor_centers = np.stack([anchor_centers]*num_anchors, axis=1).reshape( (-1,2) )
if len(center_cache)<100:
center_cache[key] = anchor_centers
pos_inds = np.where(scores>=threshold)[0]
print(stride,pos_inds,scores,threshold)
bboxes = distance2bbox(anchor_centers, bbox_preds)
pos_scores = scores[pos_inds]
pos_bboxes = bboxes[pos_inds]
#print(stride,pos_inds,pos_bboxes)
scores_list.append(pos_scores)
bboxes_list.append(pos_bboxes)
kpss = distance2kps(anchor_centers, kps_preds)
#kpss = kps_preds
kpss = kpss.reshape( (kpss.shape[0], -1, 2) )
pos_kpss = kpss[pos_inds]
kpss_list.append(pos_kpss)
#self.forward
print("bboxes_list---------------")
print (bboxes_list)
print("scores_list---------------")
print (scores_list)
print (bboxes_list)
print("kpss_list-----------------")
print (kpss_list)
print("-----------------------")
det_scale=0.5
scores = np.vstack(scores_list)
scores_ravel = scores.ravel()
order = scores_ravel.argsort()[::-1]
bboxes = np.vstack(bboxes_list) / det_scale
kpss = np.vstack(kpss_list) / det_scale
pre_det = np.hstack((bboxes, scores)).astype(np.float32, copy=False)
pre_det = pre_det[order, :]
keep = nms(pre_det,0.4)
det = pre_det[keep, :]
kpss = kpss[order,:,:]
kpss = kpss[keep,:,:]
max_num = 0
print (max_num,det.shape[0])
if max_num > 0 and det.shape[0] > max_num:
area = (det[:, 2] - det[:, 0]) * (det[:, 3] -
det[:, 1])
img_center = img.shape[0] // 2, img.shape[1] // 2
offsets = np.vstack([
(det[:, 0] + det[:, 2]) / 2 - img_center[1],
(det[:, 1] + det[:, 3]) / 2 - img_center[0]
offset_dist_squared = np.sum(np.power(offsets, 2.0), 0)
if metric=='max':
values = area
else:
values = area - offset_dist_squared * 2.0 # some extra weight on the centering
bindex = np.argsort(
values)[::-1] # some extra weight on the centering
bindex = bindex[0:max_num]
det = det[bindex, :]
if kpss is not None:
kpss = kpss[bindex, :]
#self.det_model.detect
bboxes = det
kpss = kpss
print("bboxes-------------------")
print(bboxes)
print("kpss-------------------")
print(kpss)
if bboxes.shape[0] == 0:
return []
ret = []
for i in range(bboxes.shape[0]):
bbox = bboxes[i, 0:4]
det_score = bboxes[i, 4]
kps = None
kps = kpss[i]
face = Face(bbox=bbox, kps=kps, det_score=det_score)
for taskname, model in self.models.items():
if taskname=='detection':
continue
model.get(img, face)
#model.get(img, face)
ret.append(face)
print("ret---------------")
print (ret)
faces = ret
rimg = draw_on(img, faces)
cv2.imwrite("./ldh_output1.jpg", rimg)
#loc, conf, landmarks ,= outputs #获取输出数据
bboxes, kpss = outputs #获取输出数据
priors = PriorBox(image_size=(model_height, model_width)) # 获取先验框
boxes = box_decode(loc.squeeze(0), priors) # 解码输出数据
# letterbox
scale = np.array([model_width, model_height,
model_width, model_height])
boxes = boxes * scale // 1 # face box
boxes[...,0::2] =np.clip((boxes[...,0::2] - offset_x) / aspect_ratio, 0, img_width) #letterbox
boxes[...,1::2] =np.clip((boxes[...,1::2] - offset_y) / aspect_ratio, 0, img_height) #letterbox
scores = conf.squeeze(0)[:, 1] # 人脸检测的置信度
landmarks = decode_landm(landmarks.squeeze(
0), priors) # face keypoint data
scale_landmarks = np.array([model_width, model_height, model_width, model_height,
landmarks = landmarks * scale_landmarks // 1
landmarks[...,0::2] = np.clip((landmarks[...,0::2] - offset_x) / aspect_ratio, 0, img_width) #letterbox
landmarks[...,1::2] = np.clip((landmarks[...,1::2] - offset_y) / aspect_ratio, 0, img_height) #letterbox
# 丢弃置信度过低的部分
inds = np.where(scores > 0.5)[0]
boxes = boxes[inds]
landmarks = landmarks[inds]
scores = scores[inds]
boxes = boxes[order]
landmarks = landmarks[order]
scores = scores[order]
# 非极大值抑制
dets = np.hstack((boxes, scores[:, np.newaxis])).astype(
keep = nms(dets, 0.2)
dets = dets[keep, :]
landmarks = landmarks[keep]
dets = np.concatenate((dets, landmarks), axis=1)
# 画框标记
for data in dets:
if data[4] < 0.5:
continue
#print("face @ (%d %d %d %d) %f"%(data[0], data[1], data[2], data[3], data[4]))
text = "{:.4f}".format(data[4])
data = list(map(int, data))
cv2.rectangle(img, (data[0], data[1]),
(data[2], data[3]), (0, 0, 255), 2)
cx = data[0]
cy = data[1] + 12
cv2.putText(img, text, (cx, cy),
cv2.FONT_HERSHEY_DUPLEX, 0.5, (255, 255, 255))
# landmarks
cv2.circle(img, (data[5], data[6]), 1, (0, 0, 255), 5)
cv2.circle(img, (data[7], data[8]), 1, (0, 255, 255), 5)
cv2.circle(img, (data[9], data[10]), 1, (255, 0, 255), 5)
cv2.circle(img, (data[11], data[12]), 1, (0, 255, 0), 5)
cv2.circle(img, (data[13], data[14]), 1, (255, 0, 0), 5)
img_path = './result.jpg'
cv2.imwrite(img_path, img)
print("save image in", img_path)
# 释放
rknn.release()
至此,人脸识别并标注mark点就OK了
同样的方法,将insightface\python-package中文件放入rknn中,并将model_zoo文件中对于模型的初始化、推理等按照RKNN模型修改也能得到相同的结果
我测试了retinaface和arcface两个模型,将这两个模型对应的python文件进行修改,使用FaceAnalysis也是可以使用的
retinaface模型的python文件
# -*- coding: utf-8 -*-
# @Organization : insightface.ai
# [url=home.php?mod=space&uid=1315547]@author[/url] : Jia Guo
# [url=home.php?mod=space&uid=39660]@time[/url] : 2021-09-18
# [url=home.php?mod=space&uid=665173]@FUNCTION[/url] :
from __future__ import division
import datetime
import numpy as np
import onnx
import onnxruntime
import os
import os.path as osp
import cv2
import sys
def softmax(z):
assert len(z.shape) == 2
s = np.max(z, axis=1)
s = s[:, np.newaxis] # necessary step to do broadcasting
e_x = np.exp(z - s)
div = np.sum(e_x, axis=1)
div = div[:, np.newaxis] # dito
return e_x / div
Args:
Returns:
Args:
Returns:
preds = []
preds.append(px)
preds.append(py)
class RetinaFace:
def __init__(self, model_file=None, session=None):
import onnxruntime
self.model_file = model_file
self.session = session
self.taskname = 'detection'
if self.session is None:
assert self.model_file is not None
assert osp.exists(self.model_file)
self.session = onnxruntime.InferenceSession(self.model_file, None)
self.center_cache = {}
self.nms_thresh = 0.4
self.det_thresh = 0.5
self._init_vars()
def _init_vars(self):
input_cfg = self.session.get_inputs()[0]
input_shape = input_cfg.shape
print(input_shape)
if isinstance(input_shape[2], str):
self.input_size = None
else:
self.input_size = tuple(input_shape[2:4][::-1])
#print('image_size:', self.image_size)
input_name = input_cfg.name
self.input_shape = input_shape
outputs = self.session.get_outputs()
output_names = []
for o in outputs:
output_names.append(o.name)
self.input_name = input_name
self.output_names = output_names
self.input_mean = 127.5
self.input_std = 128.0
print(self.output_names)
#assert len(outputs)==10 or len(outputs)==15
self.use_kps = False
self._anchor_ratio = 1.0
self._num_anchors = 1
if len(outputs)==6:
self.fmc = 3
self._feat_stride_fpn = [8, 16, 32]
self._num_anchors = 2
elif len(outputs)==9:
self.fmc = 3
self.use_kps = True
elif len(outputs)==10:
self.fmc = 5
self._feat_stride_fpn = [8, 16, 32, 64, 128]
elif len(outputs)==15:
self.fmc = 5
self.use_kps = True
def prepare(self, ctx_id, **kwargs):
if ctx_id<0:
self.session.set_providers(['CPUExecutionProvider'])
nms_thresh = kwargs.get('nms_thresh', None)
if nms_thresh is not None:
self.nms_thresh = nms_thresh
det_thresh = kwargs.get('det_thresh', None)
if det_thresh is not None:
self.det_thresh = det_thresh
input_size = kwargs.get('input_size', None)
if input_size is not None:
if self.input_size is not None:
print('warning: det_size is already set in detection model, ignore')
else:
self.input_size = input_size
# 创建RKNN对象
self.rknn = RKNN()
# 预处理设置
self.rknn.config(mean_values=[[127.5, 127.5, 127.5]], std_values=[[128.0, 128.0, 128.0]], target_platform="rv1106b",quantized_algorithm="normal",dynamic_input=[[[1,3,640,640]]],quant_img_RGB2BGR=False,remove_reshape=False,remove_weight=False,model_pruning=True) # mmse
print('done')
# 载入模型
ret = self.rknn.load_onnx(model="./det_10g.onnx")#,input_size_list=[[1,3,640,640]])
if ret != 0:
exit(ret)
print('done')
# 创建模型
ret = self.rknn.build(do_quantization=True, dataset=DATASET_PATH)#,rknn_batch_size=1)
if ret != 0:
exit(ret)
print('done')
# 初始化运行时环境
ret = self.rknn.init_runtime()
if ret != 0:
exit(ret)
print('done')
def forward(self, img, threshold):
print("forward")
scores_list = []
bboxes_list = []
kpss_list = []
input_size = tuple(img.shape[0:2][::-1])
#net_outs = self.rknn.inference(inputs=[img])
blob = cv2.dnn.blobFromImage(img, 1.0/self.input_std, input_size, (self.input_mean, self.input_mean, self.input_mean), swapRB=True)
#net_outs = self.session.run(self.output_names, {self.input_name : blob})
infer_img=np.expand_dims(img, 0)
net_outs = self.rknn.inference(inputs=infer_img)
# 释放
self.rknn.release()
input_height = blob.shape[2]
input_width = blob.shape[3]
fmc = self.fmc
for idx, stride in enumerate(self._feat_stride_fpn):
scores = net_outs[idx]
bbox_preds = net_outs[idx+fmc]
if self.use_kps:
kps_preds = net_outs[idx+fmc*2] * stride
K = height * width
if key in self.center_cache:
anchor_centers = self.center_cache[key]
else:
#solution-2:
#solution-3:
if self._num_anchors>1:
anchor_centers = np.stack([anchor_centers]*self._num_anchors, axis=1).reshape( (-1,2) )
if len(self.center_cache)<100:
self.center_cache[key] = anchor_centers
if self.use_kps:
#kpss = kps_preds
return scores_list, bboxes_list, kpss_list
def detect(self, img, input_size = None, max_num=0, metric='default'):
assert input_size is not None or self.input_size is not None
input_size = self.input_size if input_size is None else input_size
else:
scores_list, bboxes_list, kpss_list = self.forward(det_img, self.det_thresh)
if self.use_kps:
keep = self.nms(pre_det)
if self.use_kps:
else:
kpss = None
det[:, 1])
if metric=='max':
values = area
else:
return det, kpss
def nms(self, dets):
thresh = self.nms_thresh
x1 = dets[:, 0]
y1 = dets[:, 1]
x2 = dets[:, 2]
y2 = dets[:, 3]
scores = dets[:, 4]
keep = []
i = order[0]
keep.append(i)
inter = w * h
return keep
def get_retinaface(name, download=False, root='~/.insightface/models', **kwargs):
print("get---------------------")
if not download:
assert os.path.exists(name)
return RetinaFace(name)
else:
from .model_store import get_model_file
_file = get_model_file("retinaface_%s" % name, root=root)
return retinaface(_file)
arcFace模型python文件
# @Author : Jia Guo
# @Time : 2021-05-04
# @Function :
import numpy as np
import cv2
import onnx
import onnxruntime
from ..utils import face_align
__all__ = [
'ArcFaceONNX',
class ArcFaceONNX:
assert model_file is not None
self.taskname = 'recognition'
find_sub = False
find_mul = False
model = onnx.load(self.model_file)
#print(self.model_file)
graph = model.graph
for nid, node in enumerate(graph.node[:8]):
#print(nid, node.name)
if node.name.startswith('Sub') or node.name.startswith('_minus'):
find_sub = True
if node.name.startswith('Mul') or node.name.startswith('_mul'):
find_mul = True
if find_sub and find_mul:
#mxnet arcface model
input_mean = 0.0
input_std = 1.0
else:
input_mean = 127.5
input_std = 127.5
self.input_mean = input_mean
self.input_std = input_std
#print('input mean and std:', self.input_mean, self.input_std)
output_names = []
for out in outputs:
output_names.append(out.name)
assert len(self.output_names)==1
self.output_shape = outputs[0].shape
if ctx_id<0:
# 创建RKNN对象
self.rknn = RKNN()
# 预处理设置
self.rknn.config(mean_values=[[self.input_mean, self.input_mean, self.input_mean]], std_values=[[self.input_std, self.input_std, self.input_std]], target_platform="rv1106b",quantized_algorithm="normal",dynamic_input=[[[1,3,112,112]]],quant_img_RGB2BGR=False,remove_reshape=False,remove_weight=False,model_pruning=True) # mmse
print('done')
# 载入模型
ret = self.rknn.load_onnx(model=self.model_file)#,input_size_list=[[1,3,640,640]])
if ret != 0:
exit(ret)
print('done')
# 创建模型
if ret != 0:
exit(ret)
print('done')
# 初始化运行时环境
if ret != 0:
exit(ret)
print('done')
def get(self, img, face):
aimg = face_align.norm_crop(img, landmark=face.kps, image_size=self.input_size[0])
#face.embedding = self.get_feat(aimg).flatten()
return face.embedding
def compute_sim(self, feat1, feat2):
from numpy.linalg import norm
feat1 = feat1.ravel()
feat2 = feat2.ravel()
sim = np.dot(feat1, feat2) / (norm(feat1) * norm(feat2))
return sim
def get_feat(self, imgs):
if not isinstance(imgs, list):
imgs = [imgs]
blob = cv2.dnn.blobFromImages(imgs, 1.0 / self.input_std, input_size,
net_out = self.session.run(self.output_names, {self.input_name: blob})[0]
infer_img=np.expand_dims(imgs, 0)
net_out = self.rknn.inference(inputs=infer_img)
net_outs=np.array(net_out).flatten()#.ravel()
return net_outs
def forward(self, batch_data):
#blob = (batch_data - self.input_mean) / self.input_std
#net_out = self.session.run(self.output_names, {self.input_name: blob})[0]
return net_out
rknn下insigtface测试文件
import os
import sys
import urllib
import time
import numpy as np
import cv2
import insightface
from insightface.data import get_image as ins_get_image
#from rknn.api import RKNN
# 运行
#outputs = rknn.inference(inputs=[infer_img])#, data_format=['nhwc'])
app = FaceAnalysis(allowed_modules=['detection'],providers=['CUDAExecutionProvider', 'CPUExecutionProvider'])
print("prepare::::")
app.prepare(ctx_id=0, det_size=(640, 640))
img = ins_get_image('t1') #不用带后缀,图片放到./insightface/python-package/insightface/data/images
faces = app.get(img)
print("size of faces:", len(faces))
img1 = ins_get_image('face1') #不用带后缀,图片放到./insightface/python-package/insightface/data/images
faces1 = app.get(img1)
print("size of faces1:", len(faces1))
#print("faces::::", faces)
#rimg = app.draw_on(img, faces)
#cv2.imwrite("./output1.jpg", rimg)
handler = insightface.model_zoo.get_model('/home/ubuntu/.insightface/models/buffalo_l/w600k_r50.onnx', providers=['CUDAExecutionProvider', 'CPUExecutionProvider'])
handler.prepare(ctx_id=0)
feature = handler.get(img, faces[0])
#print("size of feature:", len(feature))
print("feature:", feature)
sim = handler.compute_sim(feature,feature)
print("sim:", sim)
feature1 = handler.get(img1, faces1[0])
feature = handler.get(img, faces[i])
sim = handler.compute_sim(feature,feature1)
print("sim:", i,sim)
解压至/rknn-toolkit2/luckfox_rknn/scripts/luckfox_onnx_to_rknn/sim,配置好环境即可在PC上推理
