ARM板开发触摸屏程序,出现飘屏!急求解决办法!
我用ARM板测试一个触摸屏程序,偶尔出现飘屏!
源码如下:
- #include "def1.h"
- #include "2440addr.h"
- #include "2440lib.h"
- #include "config.h"
- #define REQCNT 30
- #define ADCPRS 9 //YH 0627
- #define LOOP 1
- void AdcTsAuto(void);
- int TouchPanelCnt=0; // 触摸屏次数的记录
- struct TouchLocation
- volatile int x;
- volatile int y;
- }TPxyLocation = {0,0};
- volatile int test_x;
- volatile int test_y;
- INT8U ts_status;//触摸屏的状态(校准还是测试)
- //static U16 ts_lefttop_x,ts_lefttop_y,ts_rightbot_x,ts_rightbot_y,ts_leftbot_x,
- //ts_leftbot_y,ts_righttop_x,ts_righttop_y;
- struct TouchLocation TestPoint[8] = {0};
- extern void AdcTsAuto_Handler(void);
- extern OS_EVENT *TP_m_box;
- //extern OS_EVENT *Cal_m_box;
- //extern OS_EVENT *Lag_m_box;
- //unsigned int buf[3][2];
- U16 Ptx[6],Pty[6],tmp[6] = {0,0,0,0,0,0};
- //U8 index = 0;
- int i;
- U32 saveAdcdly;
- if(rADCDAT0&0x8000)
- //Uart_Printf("\nStylus Up!!\n");
- rADCTSC&=0xff; // Set stylus down interrupt bit
- //else
- // Uart_Printf("\nStylus Down!!\n");
- rADCTSC=(1<<3)|(1<<2); //Pull-up disable, Seq. X,Y postion measure.
- saveAdcdly=rADCDLY;
- rADCDLY=40000; //Normal conversion mode delay about (1/50M)*40000=0.8ms
- rADCCON|=0x1; //start ADC
- for(i=0;i<5;i++)
- // rADCTSC = (1<<7)|(1<<6)|(0<<5)|(1<<4)|(1<<3)|(1<<2)|(0);
- rADCCON |= 0x1; //Start Auto conversion
- while(rADCCON & 0x1); //Check if Enable_start is low
- while(!(0x8000&rADCCON)); //Check ECFLG
- while(!(rSRCPND & (BIT_ADC))); //check if ADC is finished with interrupt bit
- Pty[i] = (0x3ff&rADCDAT1);
- Ptx[i] = (0x3ff&rADCDAT0);
- //OSPrintf("----- ========(%04d,%04d)=======\n",Ptx[i], Pty[i]);
- // buf[3][0] =((buf[0][0] + buf[1][0] + buf[2][0])/3)*10;
- //buf[3][1] =((buf[0][1] + buf[1][1] + buf[2][1])/3)*10;
- Ptx[5]=(Ptx[0]+Ptx[1]+Ptx[2]+Ptx[3]+Ptx[4])/5;
- Pty[5]=(Pty[0]+Pty[1]+Pty[2]+Pty[3]+Pty[4])/5;
- OSPrintf(" ========(%04d,%04d)=======\n",Ptx[5], Pty[5]);
- //OSPrintf("----- ========(%04d,%04d)=======\n",TPxyLocation.x,TPxyLocation.y);
- TPxyLocation.x=Ptx[5]*10;
- TPxyLocation.y=Pty[5]*10;
- //TPxyLocation.x=TPxyLocation.x*10;
- // TPxyLocation.y=TPxyLocation.y*10;
- //OSMboxPost(TP_m_box,(void*)1);
- //YH 0627, To check Stylus Up Interrupt.
- rSUBSRCPND|=BIT_SUB_TC;
- ClearPending(BIT_ADC);
- rINTSUBMSK&=~(BIT_SUB_TC);
- rINTMSK&=~(BIT_ADC);
- rADCTSC =0xd3; //Waiting for interrupt
- rADCTSC=rADCTSC|(1<<8); // Detect stylus up interrupt signal.
- while(1) //to check Pen-up state
- if(rSUBSRCPND & (BIT_SUB_TC)) //check if ADC is finished with interrupt bit
- //Uart_Printf("Stylus Up Interrupt~!\n");
- break; //if Stylus is up(1) state
- //Uart_Printf("count=%03d XP=%04d, YP=%04d\n", TouchPanelCnt++, TPxyLocation.x, TPxyLocation.y); //X-position Conversion data
- OSMboxPost(TP_m_box,(void*)1);
- rADCDLY=saveAdcdly;
- rADCTSC=rADCTSC&~(1<<8); // Detect stylus Down interrupt signal.
- rINTSUBMSK &=~(BIT_SUB_TC); // Unmask sub interrupt (TC)
- void Test_Touchpanel(void)
- //OSPrintf("ADC touch screen test\n");
- //OSPrintf("[1] calibration touch screen \n");
- // OSPrintf("Please touch the location of left top \n");
- //ts_status = TS_JUSTIFY_LEFTTOP;
- rADCDLY=50000; //Normal conversion mode delay about (1/3.6864M)*50000=13.56ms
- rADCCON=(1<<14) | (ADCPRS<<6);//| (0<<3) | (0<<2) | (0<<1) | (0);
- //ADCPRS En, ADCPRS Value
- rADCTSC=0xd3; //Wfait,XP_PU,XP_Dis,XM_Dis,YP_Dis,YM_En
- // pISR_ADC = (uint32)AdcTsAuto_Handler;
- pISR_ADC = (int)AdcTsAuto;
- rINTMSK &= ~BIT_ADC; //ADC Touch Screen Mask bit clear
- rINTSUBMSK &= ~(BIT_SUB_TC);
复制代码
谁能帮我看看这段代码有问题麽!
