1848|1
441
【兆易GD32H759I-EVAL】 移植GDemWin [复制链接]
学习在兆易GD32H759I-EVAL开发板上移植emWin。
最新的emWin版本支持GD32芯片,在GD官网也有GDemWin软件包下载链接。
一、下载GDemWin
官网的版本是emWin6.38
下载地址:https://www.gd32mcu.com/cn/download/7?kw=GD32H7
下面在此版本的基础上进行移植和修改。
二、移植代码
移植代码实在freeRTOS系统的基础上进行移植。
FreeRTOS移植参考帖子:https://bbs.eeworld.com.cn/thread-1281628-1-1.html
2.1、添加GDemWin638代码到项目工程中
2.2、主要移植的代码部分
2.2.1、DisplayDriver\GUIDRV_Template.c
这部分参考之前的版本文件进行的移植。
*          Portions COPYRIGHT 2015 STMicroelectronics                *
*          Portions SEGGER Microcontroller GmbH & Co. KG             *
*        Solutions for real time microcontroller applications        *
*        (c) 1996 - 2015  SEGGER Microcontroller GmbH & Co. KG       *
*        Internet: www.segger.com    Support:  support@segger.com    *
** emWin V5.28 - Graphical user interface for embedded applications **
All  Intellectual Property rights  in the Software belongs to  SEGGER.
emWin is protected by  international copyright laws.  Knowledge of the
source code may not be used to write a similar product.  This file may
only be used in accordance with the following terms:
The  software has  been licensed  to STMicroelectronics International
N.V. a Dutch company with a Swiss branch and its headquarters in Plan-
les-Ouates, Geneva, 39 Chemin du Champ des Filles, Switzerland for the
purposes of creating libraries for ARM Cortex-M-based 32-bit microcon_
troller products commercialized by Licensee only, sublicensed and dis_
tributed under the terms and conditions of the End User License Agree_
ment supplied by STMicroelectronics International N.V.
Full source code is available at: www.segger.com
We appreciate your understanding and fairness.
File        : GUIDRV_Template.c
Purpose     : Template driver, could be used as starting point for new
              simple display drivers supporting only one color depth.
---------------------------END-OF-HEADER------------------------------
  * @attention   *
  * Licensed under MCD-ST Liberty SW License Agreement V2, (the "License");
  * You may not use this file except in compliance with the License.
  * You may obtain a copy of the License at:
  *        http://www.st.com/software_license_agreement_liberty_v2
  * Unless required by applicable law or agreed to in writing, software
  * distributed under the License is distributed on an "AS IS" BASIS,
  * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
  * See the License for the specific language governing permissions and
  * limitations under the License.
#include "main.h"
#include <stddef.h>
#include "LCD_Private.h"
#include "GUI_Private.h"
#include "LCD_SIM.h"
#include "LCD_ConfDefaults.h"
#define emWin_Optimize   0 /* used for emWin optimize */
*       Defines
*       Macros for MIRROR_, SWAP_ and LUT_
#if (!defined (LCD_LUT_COM) && !defined(LCD_LUT_SEG))
  #if   (!LCD_MIRROR_X && !LCD_MIRROR_Y && !LCD_SWAP_XY)
    #define LOG2PHYS_X(x, y) x
    #define LOG2PHYS_Y(x, y) y
  #elif (!LCD_MIRROR_X && !LCD_MIRROR_Y &&  LCD_SWAP_XY)
    #define LOG2PHYS_X(x, y) y
    #define LOG2PHYS_Y(x, y) x
  #elif (!LCD_MIRROR_X &&  LCD_MIRROR_Y && !LCD_SWAP_XY)
    #define LOG2PHYS_Y(x, y) LCD_YSIZE - 1 - (y)
  #elif (!LCD_MIRROR_X &&  LCD_MIRROR_Y &&  LCD_SWAP_XY)
    #define LOG2PHYS_Y(x, y) LCD_XSIZE - 1 - (x)
  #elif ( LCD_MIRROR_X && !LCD_MIRROR_Y && !LCD_SWAP_XY)
    #define LOG2PHYS_X(x, y) LCD_XSIZE - 1 - (x)
  #elif ( LCD_MIRROR_X && !LCD_MIRROR_Y &&  LCD_SWAP_XY)
    #define LOG2PHYS_X(x, y) LCD_YSIZE - 1 - (y)
  #elif ( LCD_MIRROR_X &&  LCD_MIRROR_Y && !LCD_SWAP_XY)
  #elif ( LCD_MIRROR_X &&  LCD_MIRROR_Y &&  LCD_SWAP_XY)
  #endif
#else
  #if   ( defined (LCD_LUT_COM) && !defined(LCD_LUT_SEG))
    #define LOG2PHYS_Y(x, y) LCD__aLine2Com0[y]
  #elif (!defined (LCD_LUT_COM) &&  defined(LCD_LUT_SEG))
    #define LOG2PHYS_X(x, y) LCD__aCol2Seg0[x]
  #elif ( defined (LCD_LUT_COM) &&  defined(LCD_LUT_SEG))
  #endif
#endif
*       Types
typedef struct {
  U32 VRAMAddr;
  int xSize, ySize;
  int vxSize, vySize;
  int vxSizePhys;
  int BitsPerPixel;
} DRIVER_CONTEXT_TEMPLATE;
*       Static functions
*       _SetPixelIndex
* Purpose:
*   Sets the index of the given pixel. The upper layers
*   calling this routine make sure that the coordinates are in range, so
*   that no check on the parameters needs to be performed.
static void _SetPixelIndex(GUI_DEVICE * pDevice, int x, int y, LCD_PIXELINDEX PixelIndex) {
  #ifdef WIN32
    LCDSIM_SetPixelIndex(x, y, PixelIndex, pDevice->LayerIndex);
  #else
    // Convert logical into physical coordinates (Dep. on LCDConf.h)
    #if (LCD_MIRROR_X == 1) || (LCD_MIRROR_Y == 1) || (LCD_SWAP_XY == 1)
      int xPhys, yPhys;
      xPhys = LOG2PHYS_X(x, y);
      yPhys = LOG2PHYS_Y(x, y);
    #else
      #define xPhys x
      #define yPhys y
    #endif
    GUI_USE_PARA(pDevice);
    GUI_USE_PARA(x);
    GUI_USE_PARA(y);
    GUI_USE_PARA(PixelIndex);
      // Write into hardware ... Adapt to your system
      // TBD by customer...
        LCDDrawPoint(xPhys, yPhys, PixelIndex);
    #if (LCD_MIRROR_X == 0) && (LCD_MIRROR_Y == 0) && (LCD_SWAP_XY == 0)
      #undef xPhys
      #undef yPhys
    #endif
  #endif
*       _GetPixelIndex
* Purpose:
*   Returns the index of the given pixel. The upper layers
static LCD_PIXELINDEX _GetPixelIndex(GUI_DEVICE * pDevice, int x, int y) {
  unsigned int PixelIndex;
  #ifdef WIN32
    PixelIndex = LCDSIM_GetPixelIndex(x, y, pDevice->LayerIndex);
  #else
      int xPhys, yPhys;
    #else
      #define xPhys x
      #define yPhys y
    #endif
    GUI_USE_PARA(x);
    GUI_USE_PARA(y);
	  PixelIndex = LCDReadPoint(xPhys, yPhys);
      #undef xPhys
      #undef yPhys
    #endif
  #endif
  return PixelIndex;
*       _XorPixel
static void _XorPixel(GUI_DEVICE * pDevice, int x, int y) {
  LCD_PIXELINDEX PixelIndex;
  LCD_PIXELINDEX IndexMask;
  PixelIndex = _GetPixelIndex(pDevice, x, y);
  IndexMask  = pDevice->pColorConvAPI->pfGetIndexMask();
  _SetPixelIndex(pDevice, x, y, PixelIndex ^ IndexMask);
*       _DrawHLine
static void _DrawHLine  (GUI_DEVICE * pDevice, int x0, int y,  int x1) {
  LCD_PIXELINDEX ColorIndex;
  if (GUI_pContext->DrawMode & LCD_DRAWMODE_XOR) {
    for (; x0 <= x1; x0++) {
      _XorPixel(pDevice, x0, y);
  } else {
	  #if emWin_Optimize
		ColorIndex = LCD__GetColorIndex();
		LCDDrawLine(x0, y, x1, y, ColorIndex);
	  #else
		  _SetPixelIndex(pDevice, x0, y, ColorIndex);
	  #endif
*       _DrawVLine, not optimized
static void _DrawVLine  (GUI_DEVICE * pDevice, int x, int y0,  int y1) {
    for (; y0 <= y1; y0++) {
      _XorPixel(pDevice, x, y0);
  } else {
    #if emWin_Optimize
		LCDDrawLine(x, y0, x, y1, ColorIndex);
	#else
	      _SetPixelIndex(pDevice, x, y0, ColorIndex);
	#endif
*       _FillRect
static void _FillRect(GUI_DEVICE * pDevice, int x0, int y0, int x1, int y1) {
	int x;
			for (x = x0; x <= x1; x++)
	else
	  /* 选择进行优化 */
	#if emWin_Optimize
		LCDDrawRectangle(x0,  y0,  x1,  y1,  ColorIndex);
	#else
			_DrawHLine(pDevice, x0, y0, x1);
	#endif
*       Draw Bitmap 1 BPP
static void _DrawBitLine1BPP(GUI_DEVICE * pDevice, int x, int y, U8 const * p, int Diff, int xsize, const LCD_PIXELINDEX * pTrans) {
  LCD_PIXELINDEX IndexMask, Index0, Index1, Pixel;
  Index0 = *(pTrans + 0);
  Index1 = *(pTrans + 1);
  x += Diff;
  switch (GUI_pContext->DrawMode & (LCD_DRAWMODE_TRANS | LCD_DRAWMODE_XOR)) {
  case 0:
    do {
      _SetPixelIndex(pDevice, x++, y, (*p & (0x80 >> Diff)) ? Index1 : Index0);
      if (++Diff == 8) {
        Diff = 0;
        p++;
    } while (--xsize);
    break;
  case LCD_DRAWMODE_TRANS:
    do {
      if (*p & (0x80 >> Diff))
        _SetPixelIndex(pDevice, x, y, Index1);
      x++;
      if (++Diff == 8) {
        Diff = 0;
        p++;
    } while (--xsize);
    break;
  case LCD_DRAWMODE_XOR | LCD_DRAWMODE_TRANS:
  case LCD_DRAWMODE_XOR:
    do {
      if (*p & (0x80 >> Diff)) {
        Pixel = _GetPixelIndex(pDevice, x, y);
        _SetPixelIndex(pDevice, x, y, Pixel ^ IndexMask);
      x++;
      if (++Diff == 8) {
        Diff = 0;
        p++;
    } while (--xsize);
    break;
*       Draw Bitmap 2 BPP
static void  _DrawBitLine2BPP(GUI_DEVICE * pDevice, int x, int y, U8 const * p, int Diff, int xsize, const LCD_PIXELINDEX * pTrans) {
  LCD_PIXELINDEX Pixels, PixelIndex;
  int CurrentPixel, Shift, Index;
  Pixels = *p;
  CurrentPixel = Diff;
  x += Diff;
  case 0:
    if (pTrans) {
      do {
        Shift = (3 - CurrentPixel) << 1;
        Index = (Pixels & (0xC0 >> (6 - Shift))) >> Shift;
        PixelIndex = *(pTrans + Index);
        _SetPixelIndex(pDevice, x++, y, PixelIndex);
        if (++CurrentPixel == 4) {
          CurrentPixel = 0;
          Pixels = *(++p);
      } while (--xsize);
    } else {
      do {
        _SetPixelIndex(pDevice, x++, y, Index);
          CurrentPixel = 0;
          Pixels = *(++p);
      } while (--xsize);
    break;
    if (pTrans) {
      do {
        if (Index) {
          _SetPixelIndex(pDevice, x, y, PixelIndex);
        x++;
          CurrentPixel = 0;
          Pixels = *(++p);
      } while (--xsize);
    } else {
      do {
        if (Index) {
          _SetPixelIndex(pDevice, x, y, Index);
        x++;
          CurrentPixel = 0;
          Pixels = *(++p);
      } while (--xsize);
    break;
*       Draw Bitmap 4 BPP
static void  _DrawBitLine4BPP(GUI_DEVICE * pDevice, int x, int y, U8 const * p, int Diff, int xsize, const LCD_PIXELINDEX * pTrans) {
  Pixels = *p;
  x += Diff;
  case 0:
    if (pTrans) {
      do {
        Shift = (1 - CurrentPixel) << 2;
        Index = (Pixels & (0xF0 >> (4 - Shift))) >> Shift;
        if (++CurrentPixel == 2) {
          CurrentPixel = 0;
          Pixels = *(++p);
      } while (--xsize);
    } else {
      do {
          CurrentPixel = 0;
          Pixels = *(++p);
      } while (--xsize);
    break;
    if (pTrans) {
      do {
        if (Index) {
        x++;
          CurrentPixel = 0;
          Pixels = *(++p);
      } while (--xsize);
    } else {
      do {
        if (Index) {
        x++;
          CurrentPixel = 0;
          Pixels = *(++p);
      } while (--xsize);
    break;
*       Draw Bitmap 8 BPP
static void  _DrawBitLine8BPP(GUI_DEVICE * pDevice, int x, int y, U8 const * p, int xsize, const LCD_PIXELINDEX * pTrans) {
  LCD_PIXELINDEX Pixel;
  case 0:
    if (pTrans) {
      for (; xsize > 0; xsize--, x++, p++) {
        Pixel = *p;
        _SetPixelIndex(pDevice, x, y, *(pTrans + Pixel));
    } else {
        _SetPixelIndex(pDevice, x, y, *p);
    break;
    if (pTrans) {
        Pixel = *p;
        if (Pixel) {
    } else {
        Pixel = *p;
        if (Pixel) {
          _SetPixelIndex(pDevice, x, y, Pixel);
    break;
*       Draw Bitmap 16 BPP, not optimized
* Purpose:
*   Drawing of 16bpp high color bitmaps.
*   Only required for 16bpp color depth of target. Should be removed otherwise.
static void _DrawBitLine16BPP(GUI_DEVICE * pDevice, int x, int y, U16 const * p, int xsize) {
#if emWin_Optimize
	//LCDDrawLine(x, y, xsize, y, (uint16_t *)p);
#else
	for (;xsize > 0; xsize--, x++, p++)
#endif
*       Draw Bitmap 32 BPP, not optimized
* Purpose:
*   Drawing of 32bpp true color bitmaps.
*   Only required for 32bpp color depth of target. Should be removed otherwise.
static void _DrawBitLine32BPP(GUI_DEVICE * pDevice, int x, int y, U32 const * p, int xsize) {
#if emWin_Optimize
#else
#endif
*       _DrawBitmap
static void _DrawBitmap(GUI_DEVICE * pDevice, int x0, int y0,
                       int xSize, int ySize,
                       int BitsPerPixel,
                       int BytesPerLine,
                       const U8 * pData, int Diff,
  int i;
  switch (BitsPerPixel) {
  case 1:
    for (i = 0; i < ySize; i++) {
      _DrawBitLine1BPP(pDevice, x0, i + y0, pData, Diff, xSize, pTrans);
      pData += BytesPerLine;
    break;
  case 2:
      _DrawBitLine2BPP(pDevice, x0, i + y0, pData, Diff, xSize, pTrans);
    break;
  case 4:
      _DrawBitLine4BPP(pDevice, x0, i + y0, pData, Diff, xSize, pTrans);
    break;
  case 8:
      _DrawBitLine8BPP(pDevice, x0, i + y0, pData, xSize, pTrans);
    break;
  // Only required for 16bpp color depth of target. Should be removed otherwise.
  case 16:
      _DrawBitLine16BPP(pDevice, x0, i + y0, (const U16 *)pData, xSize);
    break;
  // Only required for 32bpp color depth of target. Should be removed otherwise.
  case 32:
      _DrawBitLine32BPP(pDevice, x0, i + y0, (const U32 *)pData, xSize);
    break;
*       _InitOnce
* Purpose:
*   Allocates a fixed block for the context of the driver
* Return value:
*   0 on success, 1 on error
static int _InitOnce(GUI_DEVICE * pDevice) {
  DRIVER_CONTEXT_TEMPLATE * pContext;
  if (pDevice->u.pContext == NULL) {
    pDevice->u.pContext = GUI_ALLOC_GetFixedBlock(sizeof(DRIVER_CONTEXT_TEMPLATE));
    pContext = (DRIVER_CONTEXT_TEMPLATE *)pDevice->u.pContext;
    pContext->BitsPerPixel = LCD__GetBPP(pDevice->pColorConvAPI->pfGetIndexMask());
  return pDevice->u.pContext ? 0 : 1;
*       _GetDevProp
static I32 _GetDevProp(GUI_DEVICE * pDevice, int Index) {
  switch (Index) {
  case LCD_DEVCAP_XSIZE:
    return pContext->xSize;
  case LCD_DEVCAP_YSIZE:
    return pContext->ySize;
  case LCD_DEVCAP_VXSIZE:
    return pContext->vxSize;
  case LCD_DEVCAP_VYSIZE:
    return pContext->vySize;
  case LCD_DEVCAP_BITSPERPIXEL:
    return pContext->BitsPerPixel;
  case LCD_DEVCAP_NUMCOLORS:
    return 0;
  case LCD_DEVCAP_XMAG:
    return 1;
  case LCD_DEVCAP_YMAG:
    return 1;
  case LCD_DEVCAP_MIRROR_X:
    return 0;
  case LCD_DEVCAP_MIRROR_Y:
    return 0;
  case LCD_DEVCAP_SWAP_XY:
    return 0;
  return -1;
*       _GetDevData
static void * _GetDevData(GUI_DEVICE * pDevice, int Index) {
  #if GUI_SUPPORT_MEMDEV
    switch (Index) {
    case LCD_DEVDATA_MEMDEV:
      return (void *)&GUI_MEMDEV_DEVICE_16; // TBD: Has to be adapted to the right memory device depending on the used color depth!
  #else
    GUI_USE_PARA(Index);
  #endif
  return NULL;
*       _GetRect
static void _GetRect(GUI_DEVICE * pDevice, LCD_RECT * pRect) {
  pRect->x0 = 0;
  pRect->y0 = 0;
  pRect->x1 = pContext->vxSize - 1;
  pRect->y1 = pContext->vySize - 1;
*       _SetOrg
static void _SetOrg(GUI_DEVICE * pDevice, int x, int y) {
  LCD_X_SETORG_INFO Data = {0};
  Data.xPos = x;
  Data.yPos = y;
  LCD_X_DisplayDriver(pDevice->LayerIndex, LCD_X_SETORG, (void *)&Data);
*       Static code: Functions available by _GetDevFunc()
*       _SetVRAMAddr
static void _SetVRAMAddr(GUI_DEVICE * pDevice, void * pVRAM) {
  LCD_X_SETVRAMADDR_INFO Data = {0};
  _InitOnce(pDevice);
  if (pDevice->u.pContext) {
    pContext->VRAMAddr = (U32)pVRAM;
    Data.pVRAM = pVRAM;
    LCD_X_DisplayDriver(pDevice->LayerIndex, LCD_X_SETVRAMADDR, (void *)&Data);
*       _SetVSize
static void _SetVSize(GUI_DEVICE * pDevice, int xSize, int ySize) {
  _InitOnce(pDevice);
    pContext->vxSize = xSize;
    pContext->vySize = ySize;
    pContext->vxSizePhys = xSize;
*       _SetSize
static void _SetSize(GUI_DEVICE * pDevice, int xSize, int ySize) {
  LCD_X_SETSIZE_INFO Data = {0};
  _InitOnce(pDevice);
    pContext->vxSizePhys = (pContext->vxSizePhys == 0) ? xSize : pContext->vxSizePhys;
    pContext->xSize = xSize;
    pContext->ySize = ySize;
    Data.xSize = xSize;
    Data.ySize = ySize;
    LCD_X_DisplayDriver(pDevice->LayerIndex, LCD_X_SETSIZE, (void *)&Data);
*       _Init
static int  _Init(GUI_DEVICE * pDevice) {
  int r;
  r = _InitOnce(pDevice);
  r |= LCD_X_DisplayDriver(pDevice->LayerIndex, LCD_X_INITCONTROLLER, NULL);
  return r;
*       _On
static void _On (GUI_DEVICE * pDevice) {
  LCD_X_DisplayDriver(pDevice->LayerIndex, LCD_X_ON, NULL);
*       _Off
static void _Off (GUI_DEVICE * pDevice) {
  LCD_X_DisplayDriver(pDevice->LayerIndex, LCD_X_OFF, NULL);
*       _SetLUTEntry
static void _SetLUTEntry(GUI_DEVICE * pDevice, U8 Pos, LCD_COLOR Color) {
  LCD_X_SETLUTENTRY_INFO Data = {0};
  Data.Pos   = Pos;
  Data.Color = Color;
  LCD_X_DisplayDriver(pDevice->LayerIndex, LCD_X_SETLUTENTRY, (void *)&Data);
*       _GetDevFunc
static void (* _GetDevFunc(GUI_DEVICE ** ppDevice, int Index))(void) {
  GUI_USE_PARA(ppDevice);
  switch (Index) {
  case LCD_DEVFUNC_SET_VRAM_ADDR:
    return (void (*)(void))_SetVRAMAddr;
  case LCD_DEVFUNC_SET_VSIZE:
    return (void (*)(void))_SetVSize;
  case LCD_DEVFUNC_SET_SIZE:
    return (void (*)(void))_SetSize;
  case LCD_DEVFUNC_INIT:
    return (void (*)(void))_Init;
  case LCD_DEVFUNC_ON:
    return (void (*)(void))_On;
  case LCD_DEVFUNC_OFF:
    return (void (*)(void))_Off;
  case LCD_DEVFUNC_SETLUTENTRY:
    return (void (*)(void))_SetLUTEntry;
  return NULL;
*       Public data
*       GUI_DEVICE_API structure
const GUI_DEVICE_API GUIDRV_Template_API = {
  // Data
  DEVICE_CLASS_DRIVER,
  // Drawing functions
  _DrawBitmap,
  _DrawHLine,
  _DrawVLine,
  _FillRect,
  _GetPixelIndex,
  _SetPixelIndex,
  _XorPixel,
  // Set origin
  _SetOrg,
  // Request information
  _GetDevFunc,
  _GetDevProp,
  _GetDevData,
  _GetRect,
/*************************** End of file ****************************/
2.2.2、GUI_X_FreeRTOS.c
*                        SEGGER Software GmbH                        *
*               (c) 1996 - 2023  SEGGER Software GmbH                *
** emWin V6.38 - Graphical user interface for embedded applications **
The software has been licensed to  GigaDevice Semiconductor Inc. whose
registered office is situated at  Building No.8, IC Park, No.9 Fenghao
East Road, Haidian, Beijing, China solely for the purposes of creating
libraries  for  ARM Cortex-M processor-based  devices, sublicensed and
distributed  under  the  terms  and conditions of the End User License
Agreement supplied by GigaDevice Semiconductor Inc.
Licensing information
Licensor:                 SEGGER Software GmbH
Licensed to:              GigaDevice Semiconductor Inc., Building No.8, IC Park, No.9 Fenghao East Road, Beijing Haidian, , CHINA
Licensed SEGGER software: emWin
License number:           GUI-00918
License model:            Buyout SRC [Buyout Source Code License], according to Buyout Agreement signed Sep. 12th 2023 by Ivo Geilenbruegge and Aug. 31th 2023 by Guangyi Jin
Licensed product:         Any
Licensed platform:        Cortex-M
Licensed number of seats: -
Support and Update Agreement (SUA)
SUA period:               2023-08-11 - 2024-11-28
Contact to extend SUA:    sales@segger.com
File        : GUI_X_FreeRTOS.c
Purpose     : Config / System dependent externals for GUI
#include <stdio.h>
#include "FreeRTOS.h"
#include "semphr.h"
#include "task.h"
#include "GUI.h"
*       Static data
//static SemaphoreHandle_t _Semaphore;
//static StaticSemaphore_t _Semaphore_Memory;
static xSemaphoreHandle xQueueMutex;
static xSemaphoreHandle xSemaTxDone;
*       Public code
*      Timing:
*                 GUI_GetTime()
*                 GUI_Delay(int)
  Some timing dependent routines require a GetTime
  and delay funtion. Default time unit (tick), normally is
  1 ms.
int GUI_X_GetTime(void) {
  //return xTaskGetTickCount() * portTICK_PERIOD_MS;
	return ((int) xTaskGetTickCount());
void GUI_X_Delay(int Period) {
  //vTaskDelay(pdMS_TO_TICKS(Period));
	vTaskDelay( Period );
*       GUI_X_ExecIdle()
void GUI_X_ExecIdle(void) {
  //vTaskDelay(pdMS_TO_TICKS(1));
*      Multitasking:
*                 GUI_X_InitOS()
*                 GUI_X_GetTaskId()
*                 GUI_X_Lock()
*                 GUI_X_Unlock()
* Note:
*   The following routines are required only if emWin is used in a
*   true multi task environment, which means you have more than one
*   thread using the emWin API.
*   In this case the
*                       #define GUI_OS 1
*  needs to be in GUIConf.h
void GUI_X_InitOS(void)
	//_Semaphore = xSemaphoreCreateCountingStatic (1, 0, &_Semaphore_Memory);
	/* Create Mutex lock */
  xQueueMutex = xSemaphoreCreateMutex();
  configASSERT (xQueueMutex != NULL);
  /* Queue Semaphore */
  vSemaphoreCreateBinary( xSemaTxDone );
  configASSERT ( xSemaTxDone != NULL );
void GUI_X_Unlock(void)
		//xSemaphoreGive(_Semaphore);
		xSemaphoreGive( xQueueMutex );
void GUI_X_Lock(void)
		//xSemaphoreTake(_Semaphore, 0);
	if(xQueueMutex == NULL)
    GUI_X_InitOS();
  xSemaphoreTake( xQueueMutex, portMAX_DELAY );
U32  GUI_X_GetTaskId(void)
	return (U32)xTaskGetCurrentTaskHandle();
void GUI_X_WaitEvent (void)
  while( xSemaphoreTake(xSemaTxDone, portMAX_DELAY ) != pdTRUE );
void GUI_X_SignalEvent (void)
  xSemaphoreGive( xSemaTxDone );
*      Logging: OS dependent
Note:
  Logging is used in higher debug levels only. The typical target
  build does not use logging and does therefor not require any of
  the logging routines below. For a release build without logging
  the routines below may be eliminated to save some space.
  (If the linker is not function aware and eliminates unreferenced
  functions automatically)
//#define OS_SendString(s) GUI_USE_PARA(s)
//void GUI_X_Log     (const char *s) { GUI_USE_PARA(s); }
//void GUI_X_Warn    (const char *s) { GUI_USE_PARA(s); }
//void GUI_X_ErrorOut(const char *s) { GUI_USE_PARA(s); }
void GUI_X_Log     (const char *s) {   }
void GUI_X_Warn    (const char *s) {   }
void GUI_X_ErrorOut(const char *s) {   }
*      GUI_X_Init()
* Note:
*   This routine is called from GUI_Init() in any case whether there
*   is an RTOS or not. You can use it for additional initializations
*   needed.
void GUI_X_Init(void) {
2.2.3、main.c
#include "main.h"
void cache_enable(void);
int main(void)
	cache_enable();
	systick_config();
	init_usart(115200);
	gd_eval_lcd_init();
	task_create();
	while(1)
    /* enable i-cache */
    SCB_EnableICache();
    /* enable d-cache */
    SCB_EnableDCache();
2.2.4、fun_task.c
#include "main.h"
#define START_TASK_PRO		1
#define START_STK_SIZE		128
TaskHandle_t StartTask_Handler;
#define GUI_TASK_PRIO      3
#define GUI_TASK_STK_SIZE  512
static TaskHandle_t            guiTask_Task_Handler = NULL;
#define TOUCH_TASK_PRIO      4
#define TOUCH_TASK_STK_SIZE  512
static TaskHandle_t            touchTask_Task_Handler = NULL;
#define USER_TASK_PRIO      5
#define USER_TASK_STK_SIZE  128
static TaskHandle_t            userTask_Task_Handler = NULL;
void start_task(void *pvParameters);
void gui_task(void *pvParameters);
void touch_task(void *pvParameters);
void user_task(void *pvParameters);
void task_create(void)
	//start_task
	xTaskCreate((TaskFunction_t )start_task,
							(const char*    )"start_task",
							(uint16_t       )START_STK_SIZE,
							(void*          )NULL,
							(UBaseType_t    )START_TASK_PRO,
							(TaskHandle_t*  )&StartTask_Handler);
	vTaskStartScheduler();
	taskENTER_CRITICAL();
	//touch_task
	xTaskCreate((TaskFunction_t )touch_task,
							(const char*    )"touch_task",
							(uint16_t       )TOUCH_TASK_STK_SIZE,
							(void*          )NULL,
							(UBaseType_t    )TOUCH_TASK_PRIO,
							(TaskHandle_t*  )&touchTask_Task_Handler);
	//gui_task
	xTaskCreate((TaskFunction_t )gui_task,
							(const char*    )"gui_task",
							(uint16_t       )GUI_TASK_STK_SIZE,
							(void*          )NULL,
							(UBaseType_t    )GUI_TASK_PRIO,
							(TaskHandle_t*  )&guiTask_Task_Handler);
	//user_task
	xTaskCreate((TaskFunction_t )user_task,
							(const char*    )"user_task",
							(uint16_t       )USER_TASK_STK_SIZE,
							(void*          )NULL,
							(UBaseType_t    )USER_TASK_PRIO,
							(TaskHandle_t*  )&userTask_Task_Handler);
	taskEXIT_CRITICAL();
	vTaskDelete(StartTask_Handler);
//touch_task
	//GUI_CURSOR_Show();
	while (1)
			GUI_TOUCH_Exec();
			vTaskDelay(5);
//gui_task
		MainTask();
    while (1)
        vTaskDelay(5);
	while (1)
			printf("user_task run ...\r\n");
			vTaskDelay(500);
三、运行结果
移植完成后,下载代码到开发板,运行视频如下:
GDemWin
拍摄的视频超出上传文件上限,截取视频的前面部分。
四、附件
项目源码:
gd32h759_freertos_emwin_prj_20240520.rar (8.94 MB, 下载次数: 55)
在最后的视频看,移植emWin是成功的   详情 回复 发表于 2024-5-21 07:34
点赞(1) 关注
6802
在最后的视频看,移植emWin是成功的
推荐帖子
推荐:读大学究竟为了什么 电子书
5781 还不错,没事可以看看!
谁可以仔细讲一讲51单片机复位电路的工作原理 ?
09年全国电子设计大赛题目下载网站
为保证届时题目下载顺利进行,全国竞赛组委会秘书处定于2009年7月16日(周四)上午8:30开始,在上述八个网站上载竞赛模拟题目(2 ...
【赛题大汇总】(5.23更新)2011全国各省市、高校“电子设计”选拔赛、校内赛题目汇总
24Cxx 系列EEPROM通用程序及应用(STM32 应用函数文件)
(论坛到现在对chrome的支持还是非常不好,上传附件失败以及把排版弄乱等,使得我不得不编辑了好几次,幸好还不是用lin ...
SimpleLink无晶振无线MCU助您轻松实现无晶体化
半导体行业的创新往往是在现有产品的基础上加以改进,但在设计方面则追求“少即是多”的理念。在德州仪器,我们研究 ...
求助一下这张图稍微详细一点的解析
496947这张图是关于噪声的讲解,频域这边的图看不明白,左上角那个图个人觉得应该是这样的496948;还有频谱密度曲线是怎么通过上 ...
有奖直播|网络研讨会-高速接口测试:PCIe5.0测试方案
随着处理器技术发展,个人计算机以及工作服务器,在互连网领域对高速数据传输质量要求的与日俱增,采用差分信号进行串行通信的 P ...
AD在PCB里连接引脚然后再更新到原理图有什么好的办法吗?
我有一块引脚比较多的芯片,为了方便走线我想在PCB里把外设的引脚和它连接,然后再更新到原理图里。比如主芯片U1,和U2连接,U2 ...
【玄铁杯第三届RISC-V应用创新大赛】Lichee PI 4A 之编译ncnn&测试simplepose demo
本帖最后由 小默叔叔 于 2023-12-6 20:18 编辑 # 【玄铁杯第三届RISC-V应用创新大赛】Lichee PI 4A 之编译ncnn&测试simplepos ...
