1010|9
441
【兆易GD32H759I-EVAL】串口printf测试 [复制链接]
这篇来测试下串口printf功能。
一、硬件电路
开发板串口硬件电路图部分,串口 USART0 连接到CH340E端口。
二、程序部分
2.1、usart.c
#include "main.h"
/* retarget the C library printf function to the USART */
int fputc(int ch, FILE *f)
    usart_data_transmit(EVAL_COM, (uint8_t)ch);
    while(RESET == usart_flag_get(EVAL_COM, USART_FLAG_TBE));
    return ch;
void init_usart(uint32_t buad)
    /* enable GPIO clock */
    rcu_periph_clock_enable(EVAL_COM_GPIO_CLK);
    /* enable USART clock */
    rcu_periph_clock_enable(EVAL_COM_CLK);
    /* connect port to USART0 TX */
    gpio_af_set(EVAL_COM_GPIO_PORT, EVAL_COM_AF, EVAL_COM_TX_PIN);
    /* connect port to USART0 RX */
    gpio_af_set(EVAL_COM_GPIO_PORT, EVAL_COM_AF, EVAL_COM_RX_PIN);
    /* configure USART TX as alternate function push-pull */
    gpio_mode_set(EVAL_COM_GPIO_PORT, GPIO_MODE_AF, GPIO_PUPD_PULLUP, EVAL_COM_TX_PIN);
    gpio_output_options_set(EVAL_COM_GPIO_PORT, GPIO_OTYPE_PP, GPIO_OSPEED_60MHZ, EVAL_COM_TX_PIN);
    /* configure USART RX as alternate function push-pull */
    gpio_mode_set(EVAL_COM_GPIO_PORT, GPIO_MODE_AF, GPIO_PUPD_PULLUP, EVAL_COM_RX_PIN);
    gpio_output_options_set(EVAL_COM_GPIO_PORT, GPIO_OTYPE_PP, GPIO_OSPEED_60MHZ, EVAL_COM_RX_PIN);
    /* USART configure */
    usart_deinit(EVAL_COM);
    usart_word_length_set(EVAL_COM, USART_WL_8BIT);
    usart_stop_bit_set(EVAL_COM, USART_STB_1BIT);
    usart_parity_config(EVAL_COM, USART_PM_NONE);
    usart_baudrate_set(EVAL_COM, buad);
    usart_receive_config(EVAL_COM, USART_RECEIVE_ENABLE);
    usart_transmit_config(EVAL_COM, USART_TRANSMIT_ENABLE);
    usart_enable(EVAL_COM);
2.2、usart.h
#ifndef _USART_H
#define _USART_H
#include "stdint.h"
/* eval board low layer COM */
#define COMn                             1U
/* definition for COM, connected to USART0 */
#define EVAL_COM                         USART0
#define EVAL_COM_CLK                     RCU_USART0
#define EVAL_COM_TX_PIN                  GPIO_PIN_9
#define EVAL_COM_RX_PIN                  GPIO_PIN_10
#define EVAL_COM_GPIO_PORT               GPIOA
#define EVAL_COM_GPIO_CLK                RCU_GPIOA
#define EVAL_COM_AF                      GPIO_AF_7
void init_usart(uint32_t buad);
#endif
2.3、main.c
#include "main.h"
void cache_enable(void);
int main(void)
	cache_enable();
	systick_config();
	init_usart(115200);
	init_led();
	while(1)
		led1_tog();
		printf("GD32H759 usart0 printf test! \r\n");
		delay_1ms(500);
    /* enable i-cache */
    SCB_EnableICache();
    /* enable d-cache */
    SCB_EnableDCache();
2.4、选择Use MicroLIB
三、程序运行
下载程序复位开发板后,串口输出内容。
本帖最后由 lugl4313820 于 2024-5-13 07:31 编辑 [attach]808129[/attach][attach]808130[/attach]    我这里向楼主提一个建议,你所帖出来的代码,最好的main.h也给帖出来,printf是必须的<stdio.h>也许是楼主大佬放在main.h中集中引用了,但是对于printf的示例工程中,最好把这个<stdio.h>放在这里,以免在其他人“抄”了你的代码后,会报头文件引用的错误。   详情 回复 发表于 2024-5-13 07:14
9803
24
美国艺术是啥意思?
什么美国艺术  详情 回复 发表于 2024-5-10 11:10
441
littleshrimp 发表于 2024-5-10 06:46 美国艺术是啥意思?
什么美国艺术
帖子里的内容  详情 回复 发表于 2024-5-10 11:15
6107
这芯片目前是兆易最好的芯片了。
H7的性能比较强  详情 回复 发表于 2024-5-10 14:39
9803
24
TL-LED 发表于 2024-5-10 11:10 什么美国艺术
帖子里的内容
奇怪,我这边看着都正常  详情 回复 发表于 2024-5-10 14:40
441
damiaa 发表于 2024-5-10 11:14 这芯片目前是兆易最好的芯片了。
H7的性能比较强
441
奇怪,我这边看着都正常
是我的手机浏览器自动给翻译了  详情 回复 发表于 2024-5-10 14:49
9803
24
TL-LED 发表于 2024-5-10 14:40 奇怪,我这边看着都正常
是我的手机浏览器自动给翻译了
个人签名虾扯蛋,蛋扯虾,虾扯蛋扯虾
7063
好的  详情 回复 发表于 2024-5-13 08:23
441
lugl4313820 发表于 2024-5-13 07:14    我这里向楼主提一个建议,你所帖出来的代码,最好的main.h也给帖出来,printf是必须的< ...
好的
