1205|1
441
okmx6q -- platform方式的led驱动测试 [复制链接]
platform方式的led驱动测试。
一、驱动程序
1.1、leddevice.c
#include <linux/types.h>
#include <linux/kernel.h>
#include <linux/delay.h>
#include <linux/ide.h>
#include <linux/init.h>
#include <linux/module.h>
#include <linux/errno.h>
#include <linux/gpio.h>
#include <linux/cdev.h>
#include <linux/device.h>
#include <linux/of_gpio.h>
#include <linux/semaphore.h>
#include <linux/timer.h>
#include <linux/irq.h>
#include <linux/wait.h>
#include <linux/poll.h>
#include <linux/fs.h>
#include <linux/fcntl.h>
#include <linux/platform_device.h>
#include <asm/mach/map.h>
#include <asm/uaccess.h>
#include <asm/io.h>
 * 寄存器地址定义
#define IOMUXC_SW_MUX_CTL_PAD_EIM_ADDR17_BASE 	(0X020E00F0)
#define IOMUXC_SW_PAD_CTL_PAD_EIM_ADDR17_BASE 	(0X020E0404)
#define GPIO2_DR_BASE							(0X020A0000)
#define GPIO2_GDIR_BASE							(0X020A0004)
#define REGISTER_LENGTH				4
/* [url=home.php?mod=space&uid=1068364]@description[/url] : 释放flatform设备模块的时候此函数会执行
 * @param - dev 	: 要释放的设备
 * [url=home.php?mod=space&uid=784970]@return[/url] : 无
static void	led_release(struct device *dev)
	printk("led device released!\r\n");
 * 设备资源信息,也就是LED0所使用的所有寄存器
static struct resource led_resources[] = {
	[0] = {
		.start	= IOMUXC_SW_MUX_CTL_PAD_EIM_ADDR17_BASE,
		.end	= (IOMUXC_SW_MUX_CTL_PAD_EIM_ADDR17_BASE + REGISTER_LENGTH - 1),
		.flags	= IORESOURCE_MEM,
	[1] = {
		.start	= IOMUXC_SW_PAD_CTL_PAD_EIM_ADDR17_BASE,
		.end	= (IOMUXC_SW_PAD_CTL_PAD_EIM_ADDR17_BASE + REGISTER_LENGTH - 1),
	[2] = {
		.start	= GPIO2_DR_BASE,
		.end	= (GPIO2_DR_BASE + REGISTER_LENGTH - 1),
	[3] = {
		.start	= GPIO2_GDIR_BASE,
		.end	= (GPIO2_GDIR_BASE + REGISTER_LENGTH - 1),
 * platform设备结构体
static struct platform_device leddevice = {
	.name = "imx6q-led",
	.id = -1,
	.dev = {
		.release = &led_release,
	.num_resources = ARRAY_SIZE(led_resources),
	.resource = led_resources,
 * @description	: 设备模块加载
 * @param 		: 无
 * @return 		: 无
static int __init leddevice_init(void)
	return platform_device_register(&leddevice);
 * @description	: 设备模块注销
 * @param 		: 无
 * @return 		: 无
static void __exit leddevice_exit(void)
	platform_device_unregister(&leddevice);
module_init(leddevice_init);
module_exit(leddevice_exit);
MODULE_LICENSE("GPL");
MODULE_AUTHOR("ZZK");
1.2、leddriver.c
#include <asm/io.h>
#define LEDDEV_CNT		1			/* 设备号长度 	*/
#define LEDDEV_NAME		"platled"	/* 设备名字 	*/
#define LEDOFF 			0
#define LEDON 			1
/* 寄存器名 */
static void __iomem *SW_MUX_GPIO2_IO21;
static void __iomem *SW_PAD_GPIO2_IO21;
static void __iomem *GPIO2_DR;
static void __iomem *GPIO2_GDIR;
/* leddev设备结构体 */
struct leddev_dev{
	dev_t devid;			/* 设备号	*/
	struct cdev cdev;		/* cdev		*/
	struct class *class;	/* 类 		*/
	struct device *device;	/* 设备		*/
	int major;				/* 主设备号	*/
struct leddev_dev leddev; 	/* led设备 */
 * @description		: LED打开/关闭
 * @param - sta 	: LEDON(0) 打开LED,LEDOFF(1) 关闭LED
 * @return 			: 无
void led0_switch(u8 sta)
	u32 val = 0;
	if(sta == LEDON){
		val = readl(GPIO2_DR);
		val &= ~(1 << 21);
		writel(val, GPIO2_DR);
	}else if(sta == LEDOFF){
		val|= (1 << 21);
 * @description		: 打开设备
 * @param - inode 	: 传递给驱动的inode
 * @param - filp 	: 设备文件,file结构体有个叫做private_data的成员变量
 * 					  一般在open的时候将private_data指向设备结构体。
 * @return 			: 0 成功;其他 失败
static int led_open(struct inode *inode, struct file *filp)
	filp->private_data = &leddev; /* 设置私有数据  */
	return 0;
 * @description		: 向设备写数据
 * @param - filp 	: 设备文件,表示打开的文件描述符
 * @param - buf 	: 要写给设备写入的数据
 * @param - cnt 	: 要写入的数据长度
 * @param - offt 	: 相对于文件首地址的偏移
 * @return 			: 写入的字节数,如果为负值,表示写入失败
static ssize_t led_write(struct file *filp, const char __user *buf, size_t cnt, loff_t *offt)
	int retvalue;
	unsigned char databuf[1];
	unsigned char ledstat;
	retvalue = copy_from_user(databuf, buf, cnt);
	if(retvalue < 0) {
		return -EFAULT;
	ledstat = databuf[0];		/* 获取状态值 */
	if(ledstat == LEDON) {
		led0_switch(LEDON);		/* 打开LED灯 */
	}else if(ledstat == LEDOFF) {
		led0_switch(LEDOFF);	/* 关闭LED灯 */
	return 0;
/* 设备操作函数 */
static struct file_operations led_fops = {
	.owner = THIS_MODULE,
	.open = led_open,
	.write = led_write,
 * @description		: flatform驱动的probe函数,当驱动与
 * 					  设备匹配以后此函数就会执行
 * @param - dev 	: platform设备
 * @return 			: 0,成功;其他负值,失败
static int led_probe(struct platform_device *dev)
	int i = 0;
	int ressize[5];
	u32 val = 0;
	struct resource *ledsource[5];
	printk("led driver and device has matched!\r\n");
	/* 1、获取资源 */
	for (i = 0; i < 4; i++) {
		ledsource[i] = platform_get_resource(dev, IORESOURCE_MEM, i); /* 依次MEM类型资源 */
		if (!ledsource[i]) {
			dev_err(&dev->dev, "No MEM resource for always on\n");
			return -ENXIO;
		ressize[i] = resource_size(ledsource[i]);
	/* 2、初始化LED */
	/* 寄存器地址映射 */
 	//IMX6U_CCM_CCGR1 = ioremap(ledsource[0]->start, ressize[0]);
	SW_MUX_GPIO2_IO21 = ioremap(ledsource[0]->start, ressize[0]);
  	SW_PAD_GPIO2_IO21 = ioremap(ledsource[1]->start, ressize[1]);
	GPIO2_DR = ioremap(ledsource[2]->start, ressize[2]);
	GPIO2_GDIR = ioremap(ledsource[3]->start, ressize[3]);
	/* 设置GPIO2_IO21复用功能,将其复用为GPIO2_IO21 */
	writel(5, SW_MUX_GPIO2_IO21);
	writel(0x10B0, SW_PAD_GPIO2_IO21);
	/* 设置GPIO2_IO21为输出功能 */
	val = readl(GPIO2_GDIR);
	val &= ~(1 << 21);			/* 清除以前的设置 */
	val |= (1 << 21);			/* 设置为输出 */
	writel(val, GPIO2_GDIR);
	/* 默认关闭LED1 */
	val |= (1 << 21) ;
	/* 注册字符设备驱动 */
	/*1、创建设备号 */
	if (leddev.major) {		/*  定义了设备号 */
		leddev.devid = MKDEV(leddev.major, 0);
		register_chrdev_region(leddev.devid, LEDDEV_CNT, LEDDEV_NAME);
	} else {						/* 没有定义设备号 */
		alloc_chrdev_region(&leddev.devid, 0, LEDDEV_CNT, LEDDEV_NAME);	/* 申请设备号 */
		leddev.major = MAJOR(leddev.devid);	/* 获取分配号的主设备号 */
	/* 2、初始化cdev */
	leddev.cdev.owner = THIS_MODULE;
	cdev_init(&leddev.cdev, &led_fops);
	/* 3、添加一个cdev */
	cdev_add(&leddev.cdev, leddev.devid, LEDDEV_CNT);
	/* 4、创建类 */
	leddev.class = class_create(THIS_MODULE, LEDDEV_NAME);
	if (IS_ERR(leddev.class)) {
		return PTR_ERR(leddev.class);
	/* 5、创建设备 */
	leddev.device = device_create(leddev.class, NULL, leddev.devid, NULL, LEDDEV_NAME);
	if (IS_ERR(leddev.device)) {
		return PTR_ERR(leddev.device);
	return 0;
 * @description		: platform驱动的remove函数,移除platform驱动的时候此函数会执行
static int led_remove(struct platform_device *dev)
	//iounmap(IMX6U_CCM_CCGR1);
	iounmap(SW_MUX_GPIO2_IO21);
	iounmap(SW_PAD_GPIO2_IO21);
	iounmap(GPIO2_DR);
	iounmap(GPIO2_GDIR);
	cdev_del(&leddev.cdev);/*  删除cdev */
	unregister_chrdev_region(leddev.devid, LEDDEV_CNT); /* 注销设备号 */
	device_destroy(leddev.class, leddev.devid);
	class_destroy(leddev.class);
	return 0;
/* platform驱动结构体 */
static struct platform_driver led_driver = {
	.driver		= {
		.name	= "imx6q-led",			/* 驱动名字,用于和设备匹配 */
	.probe		= led_probe,
	.remove		= led_remove,
 * @description	: 驱动模块加载函数
 * @param 		: 无
 * @return 		: 无
static int __init leddriver_init(void)
	return platform_driver_register(&led_driver);
 * @description	: 驱动模块卸载函数
 * @param 		: 无
 * @return 		: 无
static void __exit leddriver_exit(void)
	platform_driver_unregister(&led_driver);
module_init(leddriver_init);
module_exit(leddriver_exit);
1.3、Makefile
KERNELDIR := ~/okmx6q-c/linux-4.1.15
CURRENT_PATH := $(shell pwd)
obj-m := leddevice.o leddriver.o
build: kernel_modules
kernel_modules:
	$(MAKE) -C $(KERNELDIR) M=$(CURRENT_PATH) modules
clean:
	$(MAKE) -C $(KERNELDIR) M=$(CURRENT_PATH) clean
二、编译及运行
2.1、编译驱动模块
root@ThinkPad:~/okmx6q-c/app/platform# make ARCH=arm
root@ThinkPad:~/okmx6q-c/app/platform# cp leddevice.ko leddriver.ko /nfs_rootfs/imx6qdl-rootfs/lib/modules/4.1.15
2.2、加载驱动模块
2.3、测试运行
使用上篇的测试程序运行
LED闪烁运行。
此帖出自ARM技术论坛
platform方式的led驱动测试的完美   详情 回复 发表于 2024-4-20 07:28
点赞 关注(1)
6802
此帖出自ARM技术论坛
