本周对于N32A455的PWM产生进行了测试,首先连接接线图如下:
使用的示波器为PicoScope的3205,利用电脑查看波形,将探头使用探针夹夹在PA6上,地与板子的GND连接,接下来将下列代码下载至板子上:
#include "main.h"
TIM_TimeBaseInitType TIM_TimeBaseStructure;
OCInitType TIM_OCInitStructure;
uint16_t CCR1_Val = 333;
uint16_t CCR2_Val = 249;
uint16_t CCR3_Val = 166;
uint16_t CCR4_Val = 83;
uint16_t PrescalerValue = 0;
void RCC_Configuration(void);
void GPIO_Configuration(void);
int main(void)
RCC_Configuration();
GPIO_Configuration();
PrescalerValue = (uint16_t)(SystemCoreClock / 24000000) - 1;
TIM_InitTimBaseStruct(&TIM_TimeBaseStructure);
TIM_TimeBaseStructure.Period = 665;
TIM_TimeBaseStructure.Prescaler = PrescalerValue;
TIM_TimeBaseStructure.ClkDiv = 0;
TIM_TimeBaseStructure.CntMode = TIM_CNT_MODE_UP;
TIM_InitTimeBase(TIM3, &TIM_TimeBaseStructure);
TIM_InitOcStruct(&TIM_OCInitStructure);
TIM_OCInitStructure.OcMode = TIM_OCMODE_PWM1;
TIM_OCInitStructure.OutputState = TIM_OUTPUT_STATE_ENABLE;
TIM_OCInitStructure.Pulse = CCR1_Val;
TIM_OCInitStructure.OcPolarity = TIM_OC_POLARITY_HIGH;
TIM_InitOc1(TIM3, &TIM_OCInitStructure);
TIM_ConfigOc1Preload(TIM3, TIM_OC_PRE_LOAD_ENABLE);
TIM_OCInitStructure.Pulse = CCR2_Val;
TIM_InitOc2(TIM3, &TIM_OCInitStructure);
TIM_ConfigOc2Preload(TIM3, TIM_OC_PRE_LOAD_ENABLE);
TIM_OCInitStructure.Pulse = CCR3_Val;
TIM_InitOc3(TIM3, &TIM_OCInitStructure);
TIM_ConfigOc3Preload(TIM3, TIM_OC_PRE_LOAD_ENABLE);
TIM_OCInitStructure.Pulse = CCR4_Val;
TIM_InitOc4(TIM3, &TIM_OCInitStructure);
TIM_ConfigOc4Preload(TIM3, TIM_OC_PRE_LOAD_ENABLE);
TIM_ConfigArPreload(TIM3, ENABLE);
TIM_Enable(TIM3, ENABLE);
while (1)
RCC_EnableAPB1PeriphClk(RCC_APB1_PERIPH_TIM3, ENABLE);
RCC_EnableAPB2PeriphClk(
RCC_APB2_PERIPH_GPIOA | RCC_APB2_PERIPH_GPIOB | RCC_APB2_PERIPH_GPIOC | RCC_APB2_PERIPH_AFIO, ENABLE);
GPIO_InitType GPIO_InitStructure;
/* GPIOA Configuration:TIM3 Channel1, 2, 3 and 4 as alternate function push-pull */
GPIO_InitStruct(&GPIO_InitStructure);
GPIO_InitStructure.Pin = GPIO_PIN_6 | GPIO_PIN_7;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitPeripheral(GPIOA, &GPIO_InitStructure);
GPIO_InitStructure.Pin = GPIO_PIN_0 | GPIO_PIN_1;
GPIO_InitPeripheral(GPIOB, &GPIO_InitStructure);
#ifdef USE_FULL_ASSERT
void assert_failed(const uint8_t* expr, const uint8_t* file, uint32_t line)
while (1)
#endif
该设置将PWM时钟设置为72MHz,PA6占空比为50%,PA7占空比为37.5%,PB0占空比为25%,PB1占空比为12.5%。相应波形如下:
PA6:
PA7:
PB0:
PB1:
可以看出按照相应地占空比输出了PWM波形。测试过程较为顺利。
